  4. Audio language change not takling effect
11 Posts 6 Posters 4.3k Views 2 Watching
  • Makro
    Makro
    Makro
    In the Android app, I set the audio language to English.
    Afterwards I select a route or Favorite and start navigation.
    To my surprise, the app voice talking does not match the previously selected voice. In fact it's not even a native English speaker.
    I have repeated this with different English voices, but not once was the selected voice used for navigation.
    Best regards, Makro
    • Makro Makro
      @Makro witch audio engine did you select and what kind of phone are you using
      Makro 1 Reply Last reply
      • JP d
        JP d
        JP d
        I have the same problem. Oneplus 12. Voice engine is Google.Android which is the only TTS engine Avaliable.
        I set mine to Australian English and it defaults back to British English which I don't mind but it isn't working correctly.
          Makro
          Makro
          Makro
          I have two engines available, a Google and a Samsung. Switching between them does not solve it, so I don't think it's related to the speech engine.
          BTW, same result using my Samsung Active tab 3 and my Samsung Galaxy s24+.
          Best regards, Makro
          • Makro Makro
            @Makro use the Google Android engine. Can you choose a deferent cvoice overthere?
              Makro
              Makro
              Makro
              Yes I tried various voices with both the Google and the Samsung engine. All my efforts are ignored.
              Another bug is that the app writes in Dutch instead of English, but that's a minor issue, not related to the voice issue.
              Best regards, Makro
              Marinus van Deudekom Leike Lodiers 2 Replies Last reply
              • Makro Makro
                @Makro I think you’ve done the wright steps. Maybe @Corjan-Meijerink can something smart about your problem
                • Makro Makro
                  Leike Lodiers
                  Leike Lodiers
                  Leike Lodiers
                  @Makro Yep same here, selected Belgium voice to check. The voice stays Dutch same as on the mobile phone.
                  • Leike Lodiers Leike Lodiers
                    @Leike-Lodiers, I have been mentioning this before, also in our test group, but got no response. So I thought is was my phone's problem. I think the voice settings are not honored anymore since some versions, and the app defaults to the system voice. @Corjan-Meijerink?
                      I'll need to investigate this issue! Sorry for the inconvenience.
                      • Makro Makro referenced this topic on
                        Issue is solved in the 4.3.9 update 🙂
                        JP d
                        JP d
                        Leike Lodiers
                        Leike Lodiers
                        Makro
                        Makro
                        • MRA Studio export speed
                        • Map colours and side roads
                        • geeft routepunt niet weer
                        • route bug
                          671
