  4. suggestion: New Options for RoutePlanner
4 Posts 4 Posters 1.3k Views 3 Watching
  • Lluis Arasanz
    Hi,
    When I plan a route, I miss some options I think can be a must:
    • The option of disable/enable Waypoints in a route.
      The primary reason for that is to see how a route changes without move or delete points I put before, I think this could be a good extra for planning. Also it could help to use calculator to see variations on distance and time.
    • Calculator on alternate window or in menu:
      When you use calculator, it blocks actual editing window, so you need to "remember" which points you want to check. Is calculator is always visible is better to see differences in route. Also, it must track or have in mind "disabled" waypoints...
    Also I know there is a WebPlanner makeup plan, perhaps this items can be have in mind.
    Regards
    • BMW F750GS
      Thanks for sharing!
      Erdna 1 Reply Last reply
        Thanks for sharing!
        wrote on last edited by Erdna
        Good points. Regarding the calculator I would like to add something else: if someone uses color markings for the waypoints (which I use a lot!^^)... wouldn´t it be nice if those colors would be shown in the calculator, too? That would make things like checking distance between stops for e.g. refueling a lot more comfortable... no high gain,but a quality of life feature.^^
        I give names to that points anyway, but for me, that would be nice b/c of better overview.
        Some example planning of mine: https://www.myrouteapp.com/de/social/route/10786405?mode=share
        Regards from Austria,
        André
        Guzzist 1 Reply Last reply
        • Erdna Erdna
          André
          hmmm - I'm sorry, but I don't understand the necessity. If I check the linked route, I can see (as usually) - in Route Planer as well as in Navigation - distances between RoutePoints in time and mileage. So, between first and second fuel stop, there are 296 Km. What more do you need?
          Nothing is impossible ;-)
            paul69
            paul69
            457
            Rory Burke
            Rory Burke
