  2. Routes & Tracks
  3. IRAN planning problems
12 Posts 4 Posters 4.2k Views 1 Watching
  • DANIELZ77
    DANIELZ77
    DANIELZ77
    Hi, i am trying to prepare tracks for Iran
    example: https://www.myrouteapp.com/it/social/route/10647187?mode=share
    it doesn't work properly and i do not understand why. I need to export in GARMIN XT and i know i have to use here maps.
    Open street shows me better maps but finally doesn't works.
    In garmin i will use openstreets Iran map normal or DEM.
    2nd problem roads names are in arabic is there a tips to see in english?
    Rob Veerman MotoCon 3 Replies Last reply
    • DANIELZ77 DANIELZ77
      @DANIELZ77 Have you tried changing the profile of the route to car? I rode almost the same route in October 2024 using an OSM map on a Garmin ZUMO XT.
        @DANIELZ77 I used the OSM map that I downloaded from BBBike and it showed a lot of Latin names that sometimes were translated in a bit crooked way, but still understandable.
          @DANIELZ77, maybe not everyone knows this, but it is perfectly possible to load OSM maps to your Garmin device. If you do that, also the advised map to use in the planner is the OSM map.
          Check out https://garmin.bbbike.org/ if you are interested in this.
          DANIELZ77 1 Reply Last reply
            DANIELZ77
            DANIELZ77
            DANIELZ77
            @Con-Hennekens Ty in advance for your precious help. But my problem is not on my garmin xt device but in myrouteappweb.... the planner doesn't work on Iran map using openstreet or here maps. I don't know what's wrong.
            • DANIELZ77
              DANIELZ77
              DANIELZ77
              @Con-Hennekens i used bbbike and i know i can load on garmin those open maps. My problem is on myrouteweb planner that doesn't works on any map with iran.
                @DANIELZ77, commercial providers like TomTom lack an enormous amount of detail, I can see that, probably not allowed by the regime. The OSM map seems to be pretty detailed, though in Arabic. I opened your route and I can plan without problem. What exactly makes it unusable for you?
                  DANIELZ77
                  DANIELZ77
                  DANIELZ77
                  @Con-Hennekens i send 2 simple waypoints and the route is illogic ….. it goes inside the airport 😂 and the hotel destination is unavaiable. I dont know what to do
                    @DANIELZ77, if this is what you mean:
                    I don't see why this is illogical. just a road that goes near an airport. If you wat another route, just add shaping points.
                      DANIELZ77
                      DANIELZ77
                      DANIELZ77
                      This is the problem. waypoints not respected and i must pass inside airport 🙂 i think that iranias will shot me 🙂
                      • Tony 13
                        Tony 13
                        Tony 13
                        tried it on my Web browser, Firefox and all seemed to work OK. Weypoints in sensible places and route line followed the road. But only when using OSM, which aligns with Google satelite. HERE and Tom Tom looked useless. The HERE route does go through the airport, but not on the line shown in your screen shot
                        • Tony 13 Tony 13
                          DANIELZ77
                          DANIELZ77
                          DANIELZ77
                          @Tony-13 said in IRAN planning problems:
                          so considering that I have to create tracks that will have to run on the garmin XT.... what should I do? how should I set up myroute? thank you for your help
                          Tony 13
                          Tony 13
                          DANIELZ77
                          DANIELZ77
                          • Map Layers
                            Martin White
                            Martin White
                            Michael 2v
                            Michael 2v
