  4. Upcoming road not updating
carplaynext road
2 Posts 1 Posters 1.1k Views 1 Watching
  • Ton Machielsen
    Ton Machielsen
    Ton Machielsen
    I noticed on my CarPlay device that the Upcoming road is not updating while the map continues to show correctly.
    Because I don’t know under which conditions this happens and therefore cannot reproduce I will not open a support ticket.
    Stopping the app, starting the app, re-navigating the route and manually skipping the waypoints until you are where you are in the tour solves the problem.
    Ton Machielsen 1 Reply Last reply
    • Ton Machielsen Ton Machielsen
      Ton Machielsen
      Ton Machielsen
      Ton Machielsen
      Ok, I have some more information from today. This behaviour happens when for some reason you lose connection between the CarPlay device and the phone. Let me explain:
      At some point my phone ran out of battery. I stopped, turned off the bike and therefore disconnected the CarPlay device. Put the phone under my seat where I have a charger. The phone never switched off, the CarPlay device did.
      When I started the bike, and therefore disconnected the CarPlay device, the device reconnected to the phone and recalculated the route from my current position.
      This is what happens: The route gets recalculated correctly. The Next Turn widget get updated once. The stats widget in the bottom left also updates once. After that moment, both widgets don’t get updated anymore, the (main) route screen however, continues to work correctly.
      This issue got reproduced at the next stop where I had to take gas. CarPlay device switched off and later on again, phone reconnects, the two left widgets get updated once and never again.
      I hope this helps finding the issue.
      Ton Machielsen
      Ton Machielsen
        63
      • Question on Beta access
        335
      • Guida Libera
      • Totaaltijd veranderd niet
        Gerard Caspers
        Gerard Caspers
        BMcG
        BMcG
