  4. Track beginning far away
7 Posts 4 Posters 2.2k Views 3 Watching
  • Thomas Neumeyer
    Thomas Neumeyer
    Thomas Neumeyer
    Hi there,
    I planned a track with the MRA route planner. As I am living in Finland and the track starts in Germany until Italy it behaves unecpected . When I want to start it on the MyRoute-app it tells something like "its not defined for this kind of vehicle". After 2 minutes the map shows up, the app reacts very slow and in the left top corner a sign like a circle with a drop inside shows up but it is not starting to navigate. Cant figure out whats wrong. With a Garmin it is calculating to the first waypoint and continues. I also selected not to use my current location.
    Regards Thomas
    • Thomas Neumeyer Thomas Neumeyer
      Hi there,
      Regards Thomas
      @Thomas-Neumeyer seems like you've done something wrong with the settings, choice of profile and maybe the map itself
        Hi there,
        Regards Thomas
        @Thomas-Neumeyer, to start with, MRA Route planner plans routes not tracks. As it stands (in the web planner) you can only convert a route to a track by exporting it to gpx and re-import it as a route-track.
        My guess is that you are trying to navigate a route with the MRA App that was planned in a map other than the HERE map, and with a vehicle selection that is not compatible with the HERE map.
        You can share the route URL here (set it to public first!), then I wil take a look at it.
        Thomas Neumeyer 1 Reply Last reply
          Thomas Neumeyer
          Thomas Neumeyer
          Thomas Neumeyer
          wrote on last edited by Thomas Neumeyer
          @Con-Hennekens Hello Con, thanks for the feedback. I compared iPhone with Android Active Tab were I had the issue. The settings were different. I removed "Route as a Track" and now the behavior is ok and with fast response of the app. Before the app has been stopping to work. Just wonder where the advantage is in this situation?
          Regards Thomas
            Regards Thomas
            Thomas Neumeyer
            Thomas Neumeyer
            Thomas Neumeyer
            @Thomas-Neumeyer Hello, anybody a idea why the setting is making that problem? Maybe it is not present when I am closer to the route?
            Regards
            Thomas
            MotoCon Dave J 0 2 Replies Last reply
              Regards
              Thomas
              @Thomas-Neumeyer, no I have no idea. I can only say that navigation of routes as tracks works really well for me.
                Regards
                Thomas
                @Thomas-Neumeyer I have been testing on both iOS 18 and Android 15 and usually set 'Route as Track' on my Android device. Not experienced any issues with this setting except when I have a weak signal and the app is calculating the conversion of the route to track. The calculation can take a little more time than usual when offline and, as the videos have explained, the track may not always be exactly calculated to the route when 'offline' - there can be deviations. As @Con-Hennekens has suggested, it would be useful to see the route you have been trying to use for the 'route to track' to provide us with a little more context.
                Ducati Multistrada V4 Rally
                iPhone 18 Pro
                CHIGEE AIO-6 LTE
                Google Pixel 6 Pro
                Thomas Neumeyer
                Thomas Neumeyer
                  Hagedorn Hans-Jürgen
                • Newsletter optimisation
                  Kudee
                  Kudee
                • Walking route options
                • Trekking tool: sun/shade
