  4. Display multiple routes on one screen??
7 Posts 3 Posters 2.6k Views 2 Watching
  • Exrm193
    Exrm193
    Exrm193
    I've just changed from Garmin's Basecamp to MRA. One of the things I miss is to be able to display multiple routes on one screen...Day 1-7 for example.....
    Is this possible?? If so, how do you do it??
    Cheers
    Rob Verhoeff Nick Carthew 2 Replies Last reply
    • Exrm193 Exrm193
      Cheers
      @Simon-q Use Suggested many times before you and already on the wishlist... use the search engine on the forum and see for yourself.
      There is a workaround available. If you open a route in the planner, you can add multiple routes in the route menu, and they will also be displayed in your original route.
      • Exrm193 Exrm193
        Cheers
        @Simon-q Yes this is possible: https://forum.myrouteapp.com/topic/7533/further-route-overview-improvements
        • Exrm193
          Exrm193
          Exrm193
          I know it's possible to "Join" routes....but to see them totally separate in different colours would be useful...
          • Exrm193 Exrm193
            @Simon-q You view the routes before adding them. A maximum of 20 can be viewed at one time.
            • Exrm193 Exrm193
              @Simon-q
                @Simon-q
                @Nick-Carthew That is merely a workaround for the feature that BC inherently has, without the need to load a route first! What TS is referring to here is BC's functionality to display all your routes, or a selection of them, on the screen at the same time before loading one. And I actually agree with that. It's a great feature that has been mentioned before. I sincerely hope it will be included in the website overhaul!
                Exrm193
                Exrm193
                • Trips in Commercial Clubs?
                  Mike West
                  Mike West
                  guenniguenzelsen
                  guenniguenzelsen
                  736
                • Storage of tracklogs
                • 'Geen adres bekend'
                  Polle Glockske Claeys
                • Route calculation between newly added POIs on the map
                • Trajectcontrole: visuele kleurindicatie gemiddelde snelheid
