  4. Creating a new route while offline
11 Posts 4 Posters 3.0k Views 2 Watching
  • John S Parry
    I have experience creating routes while online (Web or Next), and then setting things up for offline use. Meaning, map and route are downloaded to enable riding anywhere. I've done this many times, and the function works as advertised. No issues there.
    My question is about creating a new route in Next when I'm 50 miles from any civilization -- no cell/data connection exists. Can I get off the bike, sit down, and create a new route in this scenario? I suspect not, but maybe the capability exists.
    I tried numerous searches to a get a specific yes/no, but I couldn't find anything. Thanks in advance for input.
    • John S Parry John S Parry
      @John-S-Parry No, that is not possible at the moment. The planner is web-based. You use the logic on the website. No data connection? Then no planning either. Perhaps in the (near) future, that functionality will be available. Especially if you lack an internet connection but still want to plan, some form of synchronization would be useful once you are back online. In the meantime, you can continue working offline.
        wrote on last edited by John S Parry
        @Rob-Verhoeff Thanks Rob. Again, I suspected that was the answer. It's consistent with most other navigation phone app functionality.
        And it's not something that's needed most of the time. But there are always exceptions. I was recently riding across the Southern Sierra in California (no cell service) when I hit an unexpected road closure. It's an area of snaking side roads not well marked, and definitely not a situation to simply pick one out and hope for the best. I instinctively went into my dedicated GPS (Trip Planner app on my Garmin Zumo XT) and was able to quickly route my way out of that hole. I didn't think about looking at MRA Next at the time, but it got thinking, and therefore this inquiry.
        Thanks again.
        • paul69
          paul69
          paul69
          wrote on last edited by paul69
          hi @John-S-Parry
          forgive my ignorance here, but i am sure the new route planner with the next app allows for route planning with no internet access.
          please correct me if i am wrong @Rob-Verhoeff
          i have tried planning routes on the next app with no internet access and planning of a route and navigation is possible.
          to achieve, we must first attemptโœŒ๏ธ
          K1600 GTL
          iPhone 13 Pro, carpuride 702b
          • paul69 paul69
            hi @John-S-Parry
            @paul69 said in Creating a new route while offline:
            Since the app-planner (Routelab on the website) is web-based you do need an internetconnection for cereating and changing routes. You can simply test that yourself by killing the internetconnection on your device.
            paul69 1 Reply Last reply
              paul69
              paul69
              paul69
              @Rob-Verhoeff
              i totally agree๐Ÿ‘ , but the OP was enquiring about the next app, which does have the ability to plan and navigate routes with no internet connection.
              at least in my experience
              K1600 GTL
              • Nick Carthew
                An offline route planner for the app is currently being tested in BETA - watch this space ๐Ÿ˜Š
                paul69 Rob Verhoeff 2 Replies Last reply
                • paul69 paul69
                  @Rob-Verhoeff
                  @paul69 I completely turned off Internet access on my iPhone. @Rob-Verhoeff is correct -- you can't create a route when offline. In Next, you get a message "No Internet" when you attempt to do so. I should have done this test before reaching out. ๐Ÿ˜Š
                  @Nick-Carthew thanks for the update.
                    paul69
                    paul69
                    paul69
                    @Nick-Carthew said in Creating a new route while offline:
                    hi @Nick-Carthew
                    that would explain why i am able to plan and navigate a route with no internet access.
                    benefits of being a beta tester i suppose,
                    sorry @John-S-Parry for the duff info i wasn't aware it was not available to all
                    K1600 GTL
                    • John S Parry
                      @paul69 No problem. It's all about getting to the right answer. Thanks for your input.
                        Iโ€™m pretty confinced thatโ€™s not true (yetโ€ฆ). ๐Ÿ˜‰
                        paul69
                        paul69
                          Alderweireld Rudi 0
                          Alderweireld Rudi 0
                        • Map movement
