  4. Here kaart lelijk en traag
29 Posts 13 Posters 11.9k Views 3 Watching
  • Dikke Wim Dikke Wim
    @Lynchy67
    I do exactly the same.
    In my experience it is in between 30-40 kmh. specially in the UK on narrow roads without a view.
    I'm curious, what is your average speed on those roads?
    Lynchy67
    Lynchy67
    Lynchy67
    #21
    @Dikke-Wim
    My speed on the Country Lanes is based on how far I can see ahead.
    In the UK many of these Country Lanes are set to 60 mph but I rarely reach that speed unless it is a straight road.
    There are far to many hazards on the country lanes!
    :Horses (I always stop and switch off the engine), Walkers (I slow down), Dogs not on leads (I Stop), blind bends, boy racers, Cyclists, delivery vans and my favourite is Suicidal Pheasants!
    Snapshot 02-02-2024 08:52.jpeg
    Snapshot 02-02-2024 08:51.jpeg
    Corjan Meijerink TorqueRider 2 Replies Last reply
    • Lynchy67 Lynchy67
      @Dikke-Wim
      @Lynchy67 Hahaha, thanks for sharing that!
      And as @nick-carthew would add: trees fallen over and blocking your path πŸ˜‰
      • Lynchy67 Lynchy67
        @Dikke-Wim
        #23
        @Lynchy67 said in Here kaart lelijk en traag:
        Country Lanes are set to 60 mph.....
        Yes, and then I think; how??? πŸ€” πŸ˜‰
        • TorqueRider TorqueRider
          Well it is not a minimum speed is it πŸ˜‰
            you surprise me
            If only I knew that sooner.
            • pieter v
              pieter v
              pieter v
              wrote on last edited by pieter v
              #26
              Ja, inderdaad. Vandaag route gemaakt en here kaarten laden zeer traag
              • hvdv hvdv
                @smuiger
                Klopt, is inderdaad een Here dingetje. Persoonlijk leg ik er de OSM kaartlaar overheen
                Bart Geerts
                Bart Geerts
                Bart Geerts
                @MRA-C Hoe doe je dat? een OSM kaartlaag er overheen leggen? ik kan niet vinden waar en hoe ik dat moet doen.
                alvast bedankt voor de reply!
                TorqueRider nomko 2 Replies Last reply
                • Bart Geerts Bart Geerts
                  #28
                  @Bart-Geerts
                  Op het icoontje rechtsboven in de getoonde kaart klikken (dus niet in een menu). En dan kun je kiezen tussen verschillende kaarten.
                  Handleiding kaartlagen
                    nomko
                    nomko
                    nomko
                    Banned
                    wrote on last edited by nomko
                    #29
                    @Bart-Geerts said in Here kaart lelijk en traag:
                    In deze menu tem selecteer je de standaard kaart lay-out:
                    En met de knop zoals met de rode pijl in de screenshot aangegeven selecteer je de overlay kaart:
                    En zoals je kan zien in de laatste screenshot heb ik nu de HERE kaart als standaard kaart lay-out en gebruik ik de OpenStreetMap kaart als overlay kaart.
                    Let wel op:
                    Het kan gebeuren dat de route die je aanmaakt op een HERE kaart kan afwijken van bv de OpenStreetMap kaart. Dan moet je bv denken aan dat op de HERE map de routelijn precies over de wegen valt die je hebt geselecteerd, maar op de OSM kaart/overlay dat de routelijn er net naast ligt. Niks van aantrekken, de kaart die als standaard is ingesteld is leidend hierin.
                    Dit heb ik wel eens meegemaakt met het maken/aanpassen van routes op bepaalde stukken dat alles netjes staat op de HERE kaart, maar als ik dan OSM inschakel als overlay, dat de route dan net naast de weg valt (in de berm zeg maar).
                    Hieronder zie je een voorbeeld van hoe de ene kaart de andere kaart niet volgt qua route:
                    Drabslab
                    Drabslab
                    Dikke Wim
                    Dikke Wim
                    nomko
                    nomko
                    hvdv
                    hvdv
                    pieter v
                    pieter v
                    Lynchy67
                    Lynchy67
                    smuiger
                    smuiger
                    Bart Geerts
                    Bart Geerts
                    • MyRoute-app offline
                      55.4k
                    • Control screen font size
                      Bouke Ent
                      Bouke Ent
                    • Map colours and side roads
                    • MRA Studio export speed
