  4. Question to iPhone user and voice settings
11 Posts 5 Posters 3.2k Views 3 Watching
    Hi, one question to iPhone user and the instruction voice used in MRA.
    I am not sure if this is standard or happened with some settings I made because of the "Homograph" problem in German voice.
    MRA is using a different voice than the Siri voice, it sounds more like a computer voice than a real one.
    I wonder if this is normal or happened through some changes I made in the settings of the iPhone. Other navigation Apps are using the Siri voice.
      @Jörgen
      Maybe I know
      I occasionally do some support for iPhone users and sometimes have to change the language of the iPhone.
      You can switch on a different voice per language setting.
      Settings -> Accessibilty -> VoiceOver -> Speech
      • TorqueRider TorqueRider
        @Jörgen
        Maybe I know
        @Jack-van-Tilburg said in Question to iPhone user and voice settings:
        To be complete: Settings > Accessibilty > VoiceOver > Speech > Voice > (change your voice here).
        One page back and you can change the pitch-settings.
          @Rob-Verhoeff good addition.
          Jorgen would never have found that out if he entered that screen.
            We are actually planning to allow changing this directly from the app! 🙂
            Jörgen 1 Reply Last reply
              @Corjan-Meijerink What is the current default voice? The clear and good Siri voice or something that sound like a computer voice?
              I can't remember, maybe I may have miss adjusted something in the iPhone setting while looking for none "Homograph" voice.
                @Jack-van-Tilburg , @Rob-Verhoeff as written, I played around with the setting and maybe I miss adjusted something.
                Before I try to find the right setting, I need to know what the current default voice is.
                  @Jörgen the computer voice 😉
                  So on iOS the Siri voice is installed by default but apps cannot programatically select this voice (logical choice by Apple).
                  In the settings as shared in the thread, users can select their desired voice (or download new ones). This is then the voice used for all apps by default 🙂
                    Ok, thank you. 👍
                      Ok, thank you. 👍
                      @Jörgen :
                      Das ändern wird jetzt in der MRA auch sauer übernommen ..
                      Bei mir ist das „VoiceOver“ auf Aus gestellt !!
                      Also nach dem ändern der Stimme am iPhone kann man das über „Hörbeispiel“ in der MRA anhören.
                      Stimme dort ändern: Beispiel für Deutsche siehe = „Stimmen“ s. dazu die Bilder unten ..
                      Von Deutsch Viktor auf Siri Stimme 2 als Test
                      iPad 9. G iOS 27.2.1/iPhone 16e iOS 27.2.1/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
                        Ok danke schön!
                        • Real-time traffic
                          Andy Nicholson
                          Andy Nicholson
                        • Navigatie met DMD tablet
                          Arjan de Vries
                          Arjan de Vries
                        • HERE map not calibrated
                        • Myrouteappstay
                        • Show on the maps's button
