  4. Question to iPhone user and voice settings
11 Posts 5 Posters 2.0k Views 3 Watching
  • Jörgenundefined Offline
    Hi, one question to iPhone user and the instruction voice used in MRA.
    I am not sure if this is standard or happened with some settings I made because of the "Homograph" problem in German voice.
    MRA is using a different voice than the Siri voice, it sounds more like a computer voice than a real one.
    I wonder if this is normal or happened through some changes I made in the settings of the iPhone. Other navigation Apps are using the Siri voice.
    • Jörgenundefined Jörgen
      Jack van Tilburg
      @Jörgen
      Maybe I know
      I occasionally do some support for iPhone users and sometimes have to change the language of the iPhone.
      You can switch on a different voice per language setting.
      Settings -> Accessibilty -> VoiceOver -> Speech
        @Jörgen
        Maybe I know
        Rob Verhoeffundefined Offline
        @Jack-van-Tilburg said in Question to iPhone user and voice settings:
        To be complete: Settings > Accessibilty > VoiceOver > Speech > Voice > (change your voice here).
        One page back and you can change the pitch-settings.
        BMW K1600GT-P (2013) | Nolan N100-5 with Sena 30K
        iOS on iPhone 13 & 16 (mounted on Quadlock or AliExpress extention on BMW-cradle)
        Apple CarPlay in VW T-Roc
          Jack van Tilburg
          @Rob-Verhoeff good addition.
          Jorgen would never have found that out if he entered that screen.
            We are actually planning to allow changing this directly from the app! 🙂
              @Corjan-Meijerink What is the current default voice? The clear and good Siri voice or something that sound like a computer voice?
              I can't remember, maybe I may have miss adjusted something in the iPhone setting while looking for none "Homograph" voice.
                @Jack-van-Tilburg , @Rob-Verhoeff as written, I played around with the setting and maybe I miss adjusted something.
                Before I try to find the right setting, I need to know what the current default voice is.
                  @Jörgen the computer voice 😉
                  So on iOS the Siri voice is installed by default but apps cannot programatically select this voice (logical choice by Apple).
                  In the settings as shared in the thread, users can select their desired voice (or download new ones). This is then the voice used for all apps by default 🙂
                    Ok, thank you. 👍
                      Ok, thank you. 👍
                      @Jörgen :
                      Das ändern wird jetzt in der MRA auch sauer übernommen ..
                      Bei mir ist das „VoiceOver“ auf Aus gestellt !!
                      Also nach dem ändern der Stimme am iPhone kann man das über „Hörbeispiel“ in der MRA anhören.
                      Stimme dort ändern: Beispiel für Deutsche siehe = „Stimmen“ s. dazu die Bilder unten ..
                      Von Deutsch Viktor auf Siri Stimme 2 als Test
                        Ok danke schön!
                        Jack van Tilburg
                          39
                          1.9k
                        • Route draait terug
                          Kris Lemaireundefined
                          Kris Lemaire
                        • Check a road using Google Maps street view.
                        • Route omkeren
                          Ewout Dundefined
                          Ewout D
                        • Coloured Routes options
                          Hanso7oundefined
                          Hanso7o
                        • Use Silverfox C1 to skip waypoints
                          Makroundefined
                          Makro
                        • Cameraknop
                          Arjan de Vriesundefined
                          Arjan de Vries
                        • Android auto en geluid
                          M. Schrijverundefined
