  4. Account Profil Change without motor home
10 Posts 6 Posters 3.1k Views 1 Watching
    Moin,
    just made changes to my account and I am then asked to give the dimensions for a motor home, although I have set motorbike? 🙄
    I can not save it until I give some values.
    Workaround is just put it something, but why is this query?
    Herko ter Horst Travellexxie 2 Replies Last reply
      Moin,
      Herko ter Horst
      Herko ter Horst
      Herko ter Horst
      @Jörgen You can just clear out the values. Then they will show up as a greyed-out 0. I can then save my profile just fine.
      Note there's actually no value entered in those fields, so I didn't actually enter '0'. That's just the placeholder value shown when the field is empty.
        @Jörgen said in Account Profil Change without motor home:
        I wrote already "Workaround is just put it something".
        But the question should not come when I change to motorbike.
        This part should be ignored.
        Anyway just a hint to make MRA better. 🙂
          Herko ter Horst
          Herko ter Horst
          Herko ter Horst
          @Jörgen You don't actually "change to motorbike", it's just the default setting for new routes you create. And what I'm saying is not "just put something", I'm saying: you don't have to put anything (clear out the fields). If you put something, it has to match some rules apparently (50kg motorhomes do not exist).
            I’ll have a look later 🙂
            • Corjan Meijerink Corjan Meijerink moved this topic from [App-Beta] Problems, Bugs and other Issues on
              Moin,
              @Jörgen I think these are default setting, IF you use a motorhome.
              To be honest, I think alike, these settings should disappear when you change the driversprofile. Somewhat the same happens in the menu of the route itself d7c2686b-85b2-4868-9a2c-811e8124d528-image.png When you select another profile, the Camper issue should disappear.
              MRA Lifetime Gold
                I think I am being misunderstood here. (maybe lost in translation)
                To explain something to someone here in the forum, I changed the language to English. When I tried to save this, everything was already set to 50 as default (see screenshot above) and I couldn't save it without changing it to something.
                But since I had set the motorbike above, I was surprised that the setting wanted to have the values for a motorhome.
                The correct logic would be to query this setting only for motorhomes when you select motorhome and not for motorbikes.
                  I disagree. What you are setting there is a default profile. It's perfectly sensible to have a default profile of motorcycle, while also using the campermode incidentally. You can leave the default camper settings alone if you don't use them.
                    This issue will be fixed tomorrow!
                      @Corjan-Meijerink That's the best answer to end this discussion.
                      Herko ter Horst
                      Herko ter Horst
                      • My feedback on the AI planner
                        1.3k
                      • Website update - Club files, a heatmap that counts your rides, the calculator on the map and more
                      • Routelijn transparantie
                        Mark Vroomen
                        Mark Vroomen
                      • AI Planner - AI requests: suggestion from MRA
                      • AI Planner: missing number of planned days in Library
                      • Stay gemaakt in " Mijn verblijven" naar community
                        Hanza 0
                        Hanza 0
