  4. Account Profil Change without motor home
10 Posts 6 Posters 3.2k Views 1 Watching
  • Jörgen
    Moin,
    just made changes to my account and I am then asked to give the dimensions for a motor home, although I have set motorbike? 🙄
    I can not save it until I give some values.
    Workaround is just put it something, but why is this query?
    Herko ter Horst Travellexxie 2 Replies Last reply
    • Jörgen Jörgen
      Moin,
      @Jörgen You can just clear out the values. Then they will show up as a greyed-out 0. I can then save my profile just fine.
      Note there's actually no value entered in those fields, so I didn't actually enter '0'. That's just the placeholder value shown when the field is empty.
      • Jörgen
        @Jörgen said in Account Profil Change without motor home:
        I wrote already "Workaround is just put it something".
        But the question should not come when I change to motorbike.
        This part should be ignored.
        Anyway just a hint to make MRA better. 🙂
        • Jörgen Jörgen
          @Jörgen You don't actually "change to motorbike", it's just the default setting for new routes you create. And what I'm saying is not "just put something", I'm saying: you don't have to put anything (clear out the fields). If you put something, it has to match some rules apparently (50kg motorhomes do not exist).
            I’ll have a look later 🙂
            • Corjan Meijerink Corjan Meijerink moved this topic from [App-Beta] Problems, Bugs and other Issues on
            • Jörgen Jörgen
              Moin,
              @Jörgen I think these are default setting, IF you use a motorhome.
              To be honest, I think alike, these settings should disappear when you change the driversprofile. Somewhat the same happens in the menu of the route itself d7c2686b-85b2-4868-9a2c-811e8124d528-image.png When you select another profile, the Camper issue should disappear.
              MRA Lifetime Gold
              • Jörgen
                I think I am being misunderstood here. (maybe lost in translation)
                To explain something to someone here in the forum, I changed the language to English. When I tried to save this, everything was already set to 50 as default (see screenshot above) and I couldn't save it without changing it to something.
                But since I had set the motorbike above, I was surprised that the setting wanted to have the values for a motorhome.
                The correct logic would be to query this setting only for motorhomes when you select motorhome and not for motorbikes.
                • Jörgen Jörgen
                  I disagree. What you are setting there is a default profile. It's perfectly sensible to have a default profile of motorcycle, while also using the campermode incidentally. You can leave the default camper settings alone if you don't use them.
                    This issue will be fixed tomorrow!
                      Rob Veerman
                      Rob Veerman
                      Rob Veerman
                      @Corjan-Meijerink That's the best answer to end this discussion.
                      • Rob Verhoeff Rob Verhoeff referenced this topic on
                      Rob Veerman
                      Rob Veerman
                        Tegel Werner
                        Tegel Werner
                      • Béta to no-béta
                        LE DIZES Freddy
                        LE DIZES Freddy
                      • eCharger and Range
                      • Stopover expiration time notification
                      • MyRouteApp on the Tracer 9 GT+ Display. Works! :)
