  4. GPX route transfer to Zumo XT not working
27 Posts 6 Posters 14.5k Views 2 Watching
  • Don Stauffer Don Stauffer
    @Hans-van-de-Ven-MRA-Master Certainly.
    https://www.myrouteapp.com/en/social/route/7863171?mode=share
    Thanks for your time and attention!
    @Don-Stauffer
    Hi Don,
    Always place the waypoints on the route line.
    See also points 6 and 10
    Then try again
    Don Stauffer 1 Reply Last reply
      @Don-Stauffer
      Hi Don,
      Then try again
      Don Stauffer
      Don Stauffer
      Don Stauffer
      @Hans-van-de-Ven-MRA-Master Route has been updated, the start and finish were based on actual street addresses, but I moved them to an on-street location. I fixed the other off-route waypoint as well.
      But still no change in the transfer to the Zumo, the track imported, but the route failed.
        @Don-Stauffer
        mmm, strange.
        Have you linked Garmin Explore in the app?
        Yes, then uninstall the App, reinstall it and skip the Garmin Explore step.
        If it still doesn't work, then reset the XT to factory settings.
        Don Stauffer 2 Replies Last reply
        • paul69
          paul69
          paul69
          hi @Don-Stauffer
          I had a similar issue a while back.
          try this ir worked for me. Uninstall the drive app from you device.
          after you reinstall the drive app, and start to go through the process, when you get to the page that asks about installing explore click "maybe later"
          this works for me
          K1600 GTL
          Oukitel RT3
          iPhone 13 Pro, carpuride 702b
            @Don-Stauffer
            mmm, strange.
            Don Stauffer
            Don Stauffer
            Don Stauffer
            @Hans-van-de-Ven-MRA-Master Interesting. I uninstalled Explore and Drive. I restarted the phone just on general principles. I then re-installed Drive, logged in using my Garmin account username and password.
            During the re-install, I was not prompted to install Explore. I do not see that it automatically loaded without asking.
            Anyway, the end result was the same, tracks transferred, route failed. I repeated the same test with my Samsung tablet, which did have Explore installed. With the same result.
            For testing, I have been using the route I shared, but the transfer has been failing with every route I have tried in the past couple of months.
            Thanks to all for suggestions, I'll reset the Garmin Zumo as a next step.
              @Don-Stauffer
              mmm, strange.
              Don Stauffer
              Don Stauffer
              Don Stauffer
              @Hans-van-de-Ven-MRA-Master Success! I reset the Zumo to factory default settings and cleared all user data. The Route and Track info are now downloading to the Zumo as before using the Garmin Drive app.
              I re-installed Explore on the phone as a test, and it did not affect my ability to download routes.
              Many thanks to Hans, and to all who helped me resolve this issue. User support is a great benefit to using MyRoute-App!
              Best Regards;
              Don Stauffer
                Best Regards;
                Don Stauffer
                @Don-Stauffer
                Good to hear that it is solved.
                I will close this topic now.
                • HABVEN aka MrMRA HABVEN aka MrMRA locked this topic on
                Don Stauffer
                Don Stauffer
                MTC-Zeilberg
                MTC-Zeilberg
                paul69
                paul69
                • MyRoute-app offline
                  Rob Kelley
                  Rob Kelley
                  44.5k
                • route bug
                • Tekst Startpunt blijft in beeld
                • Hiya from UK
                • Kaart loopt achter op de anwijzingen
                • Pay for beta?
                • Friends synchronisation?
                • wegnummers / aanduiding wel heel erg klein!
