  3. [App-Beta] Announcements
  4. Translations in the app
26 Posts 12 Posters 781 Views
    @Matthew-Wiacek Thanks for the input! I do believe their law restricts users from using such devices. So regardless of the name, it just is not allowed.
    You can turn these warnings off in the app which means we as MRA comply. The user on their end should do so if required by law.
    I always keep it on 😉
    Herko ter Horst
    Herko ter Horst
    Herko ter Horst
    #21
    @Corjan-Meijerink I think it's unwise to make statements about the law (especially of another country), unless you're a lawyer or judge, because it's easy to get wrong. BTW, not only France has these laws (since 2012), it's also forbidden in Switzerland, Germany and a number of other countries (all with potentially different rules and consequences).
    I don't think what you are saying is true (for France):
    • while it does not matter what it's called, it does matter how it implemented. For example: a zone warning (a warning about a section of road instead of an exact location) is likely compliant, while a camera-warning is not.
    • a switch to turn it off does not necessarily make MRA compliant as far as I know, unless the switch completely and permanently removes the functionality from the app.
    See also what TomTom says about this.
      @Herko-ter-Horst Thanks! We do cooperate with HERE on these matters so I guess we'll do some more talking about this subject 🙂
      • Giuseppe Marino
        Giuseppe Marino
        Giuseppe Marino
        for the Italian language there are some errors. where it is written STAI BENE you must write SVOLTA A DESTRA and the same will be SVOLTA A SINISTRA while where it is written LUCE ROSSA you must write TELECAMERA AL SEMAFORO.
        Travel hours are normally indicated with the letter H and not with the letter O
        then, as already indicated, the arrow is barely seen (under the indication of the speed limit) and often loses the gps connection even in open areas
        • Òscar
          Small correction 😋. If it is more than one, in Spanish it must be in the plural (horas).
          • https://t.me/MRa_by_b0hd1
          • YouTube: @demco17
          • Matt
            Matt
            Matt
            Hello MRA Team.
            Here something to the translation in German.
            You mix here personal and formal speech (in German "Du" and Sie").
            Correct is:
            Entscheide Dich
            Möchtest Du diese Route...
            IMG_2234.PNG bolded text
              @Matthew-Wiacek My TomTom still refers to them as Speed Cameras. You are correct about the French law not allowing precise locations of individual revenue 😉 cameras, they have opted for safety zones, meaning anywhere between two given points of a safety zone could contain a camera. As far as I know, the data for precise locations of French cameras is not available.
              Drabslab
              Drabslab
              Drabslab
              @Nick-Carthew said in Translations in the app:
              that is correct, and many camera's do NOT appear as safety zone either...
              • Corjan Meijerink Corjan Meijerink unpinned this topic on
              Hans Kremers
              Hans Kremers
              Drabslab
              Drabslab
              Giuseppe Marino
              Giuseppe Marino
              Herko ter Horst
              Herko ter Horst
              Matthew Wiacek
              Matthew Wiacek
              Vlad Popovici 0
              Vlad Popovici 0
              Matt
              Matt
              John Davies 2
              John Davies 2
                Will Brooks
                Will Brooks
                3.0k
                Adrian Avram
                Adrian Avram
                1.0k
                Will Brooks
                Will Brooks
                Marcel Versluis
                Marcel Versluis
              • Exporting GPX
                Will Brooks
                Will Brooks
