  4. Unable to calculate route
58 Posts 12 Posters 13.8k Views 5 Watching
  • Aiello antoninoundefined Offline
    Aiello antonino
    wrote on last edited by Aiello antonino
    #41
    I'll also leave the link to the route if it's useful...
    https://www.myrouteapp.com/it/social/route/12655724?mode=share
    • b0hd1undefined Offline
      b0hd1
      wrote on last edited by b0hd1
      #42
      Hi! What exactly is the problem? I've loaded the route in both the planner and the browser and it hasn't given me any problems.
      Grettings!
      • https://t.me/MRa_by_b0hd1
      • YouTube: @demco17
      Aiello antoninoundefined 1 Reply Last reply
      • Aiello antoninoundefined Aiello antonino
        Of course, and sorry for only replying at this hour, these are the maps. After what happened yesterday, I went to check the maps. The ones for the area I was in, namely Emilia Romagna and Tuscany, were checked. I noticed that 3 maps from northern Italy were missing, but I'm sure I downloaded them because I had downloaded all of Italy the first time I did it, so I don't know why they weren't checked with the flag, so I downloaded them all again...
        I tried to enable offline browsing but it still doesn't work.
        At home, trying to put it on airplane mode and trying to recreate the conditions, everything worked perfectly.IMG_3057.png IMG_3056.png
        @Aiello-antonino said in Unable to calculate route:
        Yes that's exactly what I thought...
        I have seen this often, and seems to be about interrupted map updates. Therefore I made it a habit of checking my maps after each update, to make sure all is checked. To be completely honest, the update mechanism could profit from some TLC.
        • Hubert Thoringundefined Online
          My experience is to set the whole thing to offline navigation in such regions!
          This is the translated text from the app and the picture to it ..
          Offline navigation
          Route calculation and turn-by-turn instructions are calculated without using the Internet. We recommend using this setting if you are driving in a place with poor internet reception. To use this, the region must be downloaded offline.
          iPad 9. Gen iOS 26.5.2/ iPhone 16e iOS 26.5/ Navi iPhone Xr iOS 18.7.9 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
            #45
            For offline, of course, all maps for the region must be loaded, I always load all of Europe… 😉
            It is important not to interrupt the download, the screen of the store must be active all the time, which is very important, even if it takes longer.
            • white.mouseundefined Offline
              white.mouse
              wrote on last edited by white.mouse
              #46
              Still the best is to check all your offline maps after the update!
              I have encountered the issue a few times that one or more cards were still missing after the update. Please do not ask me why.
              de Garmin Zumo XT en M.R.A. in combinatie met de Carpuride W702 (voor Android op de Motor!)
                #47
                @Con-Hennekens @white.mouse
                Thanks for this info, I haven't had the problem so far,...
                  @David-Rudgley Yes, I understand what you mean, but I take very complex routes, and I don't remember all the turns. Maybe I would start and, until I found the signal, I would have traveled many kilometers, maybe I would have had to turn back. Yesterday I was at the end of the tour in an area where there was no signal for perhaps more than 10 km, a really closed valley, I didn't even have a phone signal, not just an internet signal.
                  David Rudgleyundefined Offline
                  David Rudgley
                  @Aiello-antonino Yes I appreciate I presented a simplistic solution but I too have had exactly the same experience where I leave a stop and the app has refused work as expected on a complex route through a city for example.
                  Another thing I try to do now is when I stop I look to see if there's WiFi available, I then connect, check that I'm synched and maps are all up to date, I start the route again in online mode, just before I set off I go into offline mode and it all works again.
                  MRA Gold Planner + App + Navigation Next user
                  Android Pixel 9 Pro XL
                  TomTomGo as backup
                  KTM 1290 Super Adventure S
                  Quad Lock + Phone +Carpuride W702
                  KTM 790 Duke
                  Quad Lock + Phone
                    Aiello antonino
                    #49
                    @Con-Hennekens So, even if the missing maps weren't for the area I was in, could that have caused the problem?
                    • b0hd1undefined b0hd1
                      Grettings!
                      Aiello antonino
                      @b0hd1 If you've read the discussion from the beginning, you understand what this is about: not being able to calculate the route when you have no data connection...
                      b0hd1undefined 1 Reply Last reply
                        b0hd1
                        @Aiello-antonino okk!!
                        • YouTube: @demco17
                        • Lluis Arasanzundefined Offline
                          wrote on last edited by Lluis Arasanz
                          #52
                          @Aiello-antonino
                          I've been testing with two devices (iOS and Android), and I'd almost say it's a problem with using offline maps.
                          Make sure all the areas along the route are downloaded (just in case a small section of the route passes through an area you don't have). This is essential.
                          On the other hand, even with the areas downloaded, I've been getting errors when I use airplane mode. It was resolved when I activated offline navigation while still having an internet connection. It's as if the first time you use offline mode, it needs to be activated via an online connection. 🙄
                          Once you enter offline navigation (while still connected), you can exit and use it offline without any further problems. 😊
                          It sounds strange, I know. But once I got past the error (with a connection and offline navigation enabled), the error doesn't recur even if I change routes. However, the map is still essential, or it will continue to malfunction.
                          • BMW F750GS
                          Con Hennekensundefined Aiello antoninoundefined 2 Replies Last reply
                          • Lluis Arasanzundefined Lluis Arasanz
                            @Aiello-antonino
                            @Lluis-Arasanz, the only thing I can think of looking a little bit what you describe, is when you disabled offline navigation. In that case you will get a massage asking you to go offline, since it cannot access a live connection. But that is not the same as "Cannot calculate". If you think it is different than this, could you place a screenshot?
                            Lluis Arasanzundefined 1 Reply Last reply
                              #54
                              The message to return to "online navigation" is a different thing. This message is shown, yes, but after it, the error "cannot calculate route" appears again.
                              At this moment I can't reproduce it, because once I went to offline maps with internet connection, phone (or app) remembers this decision and works fine. Perhaps, in other moment I'll try with iPad that is not ever user to navigate any route (and even less, a offline one)
                              That's (sure) why you can't reproduce this behavior with your app, 'cause is already "in working state" 😊
                              Regards
                              • BMW F750GS
                                @Aiello-antonino
                                Aiello antonino
                                @Lluis-Arasanz I had downloaded all the maps, I had downloaded the whole of Italy, when it happened I checked all the maps, 3 did not have the flag, but they were still grayed out, as if they were physically on the phone, however they were regions distant from where I was, I was in Tuscany, while the missing maps were Trentino, Veneto and another one in the north that I don't remember... do you think it could have influenced the problem?
                                  @Aiello-antonino
                                  Not really. You only need t'he maps where the route is defined.
                                  Have you tried to set “offline navigation” in settings while connected to internet before navigate?. If no, try it. The route must start with offline symbol on time pad.
                                  After that, stop navigation and exit MRA. When done, set airplane mode and close WiFi. Open MRA again and start route.
                                  Works?
                                  • BMW F750GS
                                    Aiello antonino
                                    When I got back I re-downloaded all the Italy maps, I did a few tests to recreate the situation that had happened, but it worked perfectly... so I don't know if at this point there was some corrupt map or something else, it seemed to work anyway.…🤦‍♂️🤷‍♂️
                                      @Aiello-antonino
                                      Glad to hear that.
                                      Enjoy!
                                      • BMW F750GS
                                      Aiello antonino
                                      Marinus van Deudekomundefined
                                      Nick Carthewundefined
                                      Peter Zehentreiterundefined
                                      M. Schrijverundefined
                                      Travellexxieundefined
                                      white.mouse
                                      b0hd1undefined
                                      b0hd1
                                      David Rudgley
                                      • Mi spiegate che problemi ha ???
                                        Aiello antonino
                                        257
                                      • Can't get MRA to use a ection of N20 road near Merens-les-Vals, France to Andorra
                                        Steve Kelly 0undefined
                                        Steve Kelly 0
                                      • Add screen lock to free drive
                                        maurizio 0undefined
                                        maurizio 0
                                      • Starting navigation to favorite via CarPlay always fails first time
                                      • Another Erratic Routing Incident
                                        John S Parryundefined
                                      • Most basic introduction for a newbie group
                                        436
                                      • Which is the best GPX version to send to a TomTom Go user?
                                        Adrian Avramundefined
                                        Adrian Avram
                                      • BMW Wonderwheel Android Auto zoom
