  4. Unable to calculate route
58 Posts 12 Posters 13.8k Views 5 Watching
  • David Rudgleyundefined Offline
    David Rudgley
    Yep, had this behaviour many times exactly as you have described it @Aiello-antonino with all of the pre-requisites done i.e. Maps updated, routes sync'd, off line mode activated.... I basically solved it by either riding until I got a signal or the app just seemingly sprang back into life.
    Android Pixel 9 Pro XL
    TomTomGo as backup
    KTM 1290 Super Adventure S
    Quad Lock + Phone +Carpuride W702
    KTM 790 Duke
    Quad Lock + Phone
    Aiello antoninoundefined 1 Reply Last reply
    • Aiello antoninoundefined Aiello antonino
      Sto tornando qui perché è successo di nuovo oggi... cosa fai quando non c'è modo di far calcolare il percorso dall'app quando sei offline?
      I have all the Italian maps downloaded, I was in an area where there was no signal and the app couldn't calculate the route... I checked all the waypoints before leaving and they were all positioned perfectly, despite all this, suddenly it decides to stop working... I tried it now at home and everything is fine... I don't know at this point if I'm incompetent or if there's some problem...
      @Aiello-antonino, If you enable "Offline navigation" from the app's settings menu, does it calculate then? If it does not, I would update/redownload your maps. This message is a clear indications of missing (or corrupt) maps. Can you show us a screenshot of the downloaded Italian map segments?
      • Aiello antoninoundefined Offline
        #39
        Of course, and sorry for only replying at this hour, these are the maps. After what happened yesterday, I went to check the maps. The ones for the area I was in, namely Emilia Romagna and Tuscany, were checked. I noticed that 3 maps from northern Italy were missing, but I'm sure I downloaded them because I had downloaded all of Italy the first time I did it, so I don't know why they weren't checked with the flag, so I downloaded them all again...
        I tried to enable offline browsing but it still doesn't work.
        At home, trying to put it on airplane mode and trying to recreate the conditions, everything worked perfectly.IMG_3057.png IMG_3056.png
        • David Rudgleyundefined David Rudgley
          @David-Rudgley Yes, I understand what you mean, but I take very complex routes, and I don't remember all the turns. Maybe I would start and, until I found the signal, I would have traveled many kilometers, maybe I would have had to turn back. Yesterday I was at the end of the tour in an area where there was no signal for perhaps more than 10 km, a really closed valley, I didn't even have a phone signal, not just an internet signal.
          David Rudgleyundefined 1 Reply Last reply
            #41
            I'll also leave the link to the route if it's useful...
            https://www.myrouteapp.com/it/social/route/12655724?mode=share
            • b0hd1undefined Offline
              wrote on last edited by b0hd1
              #42
              Hi! What exactly is the problem? I've loaded the route in both the planner and the browser and it hasn't given me any problems.
              Grettings!
              • https://t.me/MRa_by_b0hd1
              • YouTube: @demco17
                @Aiello-antonino said in Unable to calculate route:
                Yes that's exactly what I thought...
                I have seen this often, and seems to be about interrupted map updates. Therefore I made it a habit of checking my maps after each update, to make sure all is checked. To be completely honest, the update mechanism could profit from some TLC.
                • Hubert Thoringundefined Online
                  My experience is to set the whole thing to offline navigation in such regions!
                  This is the translated text from the app and the picture to it ..
                  Offline navigation
                  Route calculation and turn-by-turn instructions are calculated without using the Internet. We recommend using this setting if you are driving in a place with poor internet reception. To use this, the region must be downloaded offline.
                  iPad 9. Gen iOS 26.5.2/ iPhone 16e iOS 26.5/ Navi iPhone Xr iOS 18.7.9 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                    #45
                    For offline, of course, all maps for the region must be loaded, I always load all of Europe… 😉
                    It is important not to interrupt the download, the screen of the store must be active all the time, which is very important, even if it takes longer.
                      wrote on last edited by white.mouse
                      #46
                      Still the best is to check all your offline maps after the update!
                      I have encountered the issue a few times that one or more cards were still missing after the update. Please do not ask me why.
                        #47
                        @Con-Hennekens @white.mouse
                        Thanks for this info, I haven't had the problem so far,...
                          David Rudgley
                          @Aiello-antonino Yes I appreciate I presented a simplistic solution but I too have had exactly the same experience where I leave a stop and the app has refused work as expected on a complex route through a city for example.
                          Another thing I try to do now is when I stop I look to see if there's WiFi available, I then connect, check that I'm synched and maps are all up to date, I start the route again in online mode, just before I set off I go into offline mode and it all works again.
                          TomTomGo as backup
                          KTM 790 Duke
                          Quad Lock + Phone
                            #49
                            @Con-Hennekens So, even if the missing maps weren't for the area I was in, could that have caused the problem?
                            • b0hd1undefined b0hd1
                              Grettings!
                              @b0hd1 If you've read the discussion from the beginning, you understand what this is about: not being able to calculate the route when you have no data connection...
                              b0hd1undefined 1 Reply Last reply
                                @Aiello-antonino okk!!
                                • YouTube: @demco17
                                • Lluis Arasanzundefined Offline
                                  #52
                                  @Aiello-antonino
                                  I've been testing with two devices (iOS and Android), and I'd almost say it's a problem with using offline maps.
                                  Make sure all the areas along the route are downloaded (just in case a small section of the route passes through an area you don't have). This is essential.
                                  On the other hand, even with the areas downloaded, I've been getting errors when I use airplane mode. It was resolved when I activated offline navigation while still having an internet connection. It's as if the first time you use offline mode, it needs to be activated via an online connection. 🙄
                                  Once you enter offline navigation (while still connected), you can exit and use it offline without any further problems. 😊
                                  It sounds strange, I know. But once I got past the error (with a connection and offline navigation enabled), the error doesn't recur even if I change routes. However, the map is still essential, or it will continue to malfunction.
                                  • BMW F750GS
                                  Con Hennekensundefined Aiello antoninoundefined 2 Replies Last reply
                                  • Lluis Arasanzundefined Lluis Arasanz
                                    @Aiello-antonino
                                    @Lluis-Arasanz, the only thing I can think of looking a little bit what you describe, is when you disabled offline navigation. In that case you will get a massage asking you to go offline, since it cannot access a live connection. But that is not the same as "Cannot calculate". If you think it is different than this, could you place a screenshot?
                                    Lluis Arasanzundefined 1 Reply Last reply
                                      #54
                                      The message to return to "online navigation" is a different thing. This message is shown, yes, but after it, the error "cannot calculate route" appears again.
                                      At this moment I can't reproduce it, because once I went to offline maps with internet connection, phone (or app) remembers this decision and works fine. Perhaps, in other moment I'll try with iPad that is not ever user to navigate any route (and even less, a offline one)
                                      That's (sure) why you can't reproduce this behavior with your app, 'cause is already "in working state" 😊
                                      • BMW F750GS
                                        @Aiello-antonino
                                        @Lluis-Arasanz I had downloaded all the maps, I had downloaded the whole of Italy, when it happened I checked all the maps, 3 did not have the flag, but they were still grayed out, as if they were physically on the phone, however they were regions distant from where I was, I was in Tuscany, while the missing maps were Trentino, Veneto and another one in the north that I don't remember... do you think it could have influenced the problem?
                                          @Aiello-antonino
                                          Not really. You only need t'he maps where the route is defined.
                                          Have you tried to set “offline navigation” in settings while connected to internet before navigate?. If no, try it. The route must start with offline symbol on time pad.
                                          After that, stop navigation and exit MRA. When done, set airplane mode and close WiFi. Open MRA again and start route.
                                          Works?
                                          • BMW F750GS
                                          Nick Carthewundefined
                                          Peter Zehentreiterundefined
                                          M. Schrijverundefined
                                          Travellexxieundefined
                                          b0hd1undefined
                                          David Rudgley
                                          • Mi spiegate che problemi ha ???
                                            256
                                          • Can't get MRA to use a ection of N20 road near Merens-les-Vals, France to Andorra
                                            Steve Kelly 0undefined
                                            Steve Kelly 0
                                          • Add screen lock to free drive
                                            maurizio 0undefined
                                            maurizio 0
                                          • Starting navigation to favorite via CarPlay always fails first time
                                            John S Parryundefined
                                          • Most basic introduction for a newbie group
                                            435
                                          • Which is the best GPX version to send to a TomTom Go user?
                                            Adrian Avramundefined
                                          • BMW Wonderwheel Android Auto zoom
