  4. "Spily your route" window
6 Posts 3 Posters 2.4k Views 2 Watching
  • Spili
    Spili
    Spili
    Make this window moveable.
    It covers a route.
    It will be easier to drag this window to the side and see map with points.
    Perfect will be to make map still active for zooming when this window is open.
    Nick Carthew BMcG 2 Replies Last reply
    • Spili Spili
      It covers a route.
      @Spili Make sure that you name the route points where you need to split the route with recognisable names, Hotel for example, then you don’t need to see the route.
      BMcG 1 Reply Last reply
        BMcG
        BMcG
        BMcG
        wrote on last edited by BMcG
        @Nick-Carthew it has been requested before but it would be so much easier if in the list of points, the background area for each point was highlighted with the colours assigned to the points in the map
        would be an even bigger bonus if any icon associated with a point, like hotel or beer was also visible in the split list 😁
        BlackView BV7100, Android 12
        • Spili Spili
          It covers a route.
          BMcG
          BMcG
          BMcG
          hi @Spili I think my suggestion above would be a relatively simple & quick fix
          I do however like your suggestion as it would allow for a more flexible user experience, I think it would just take more work to implement
          one possibility could be for the "split your route" window not to appear as an independent window but fill/takeover the zone used by the waypoints, the split list would replace the waypoints list & be scroll-able & the map would be moveable just like it is now when the waypoint list is shown
          • BMcG BMcG
            @Brian-McG The last sentence of your first reply is basically what my method is, only my method needs no changes to the system.
            You said: “it would be an even bigger bonus if any icon associated with a point, like hotel or beer was also visible in the split list”
            Adding the word Hotel or stop or even split to the route point title is not only easy to do but it makes finding your split points easy too and after splitting the title could be adjusted.
            I’m a firm believer in keeping things simple.
              BMcG
              BMcG
              BMcG
              Sorry @Nick-Carthew yes your method is simple & doable with the current system
              but IMO just naming the points with a keyword does not make that particular point stand out enough
              especially if you have a long route with near the maximum number of points, which is exactly the type of route you will be wanting to use the split tool
              BMcG
              BMcG
              Spili
              Spili
                95
              • Route exporteren uit beta
                68
                BMcG
                BMcG
              • Startpunt wijzigen
              • V6 - Track Navigation
                Thomas Schäfer
                Thomas Schäfer
                1.7k
