  4. Route Optimisation
Route Optimisation
16 Posts 6 Posters 7.2k Views 2 Watching
  • Ben Harrison-Graham
    Ben Harrison-Graham
    Ben Harrison-Graham
    Under Routing Options, when using Here, I get three options; Avoid, Disable seasonal closures and Offroad. I would to also like to have Route Optimisation. How do I get that option?
    Ben
    Routeplanner Gold Lifetime
    Navigation Next
    nomko 1 Reply Last reply
    • HABVEN aka MrMRA
      Change the profile in from motor to auto
      • Ben Harrison-Graham Ben Harrison-Graham
        nomko
        nomko
        nomko
        Banned
        @Ben-Harrison-Graham said in Route Optimisation:
        As said, use the transport profile for Cars (Auto) instead of Motor. This avoids some of the issues.
        Looking at your options available, are you a Gold/Silver member? Or a basic member?
        As a basic member you cannot use the HERE map. But it confuses me looking at your options. Mentioning HERE you should be a Silver/Gold member...???
        In HERE, before you start plotting a route, set Route optimization to shortest (or short) (in Dutch: Kortste route). With this set to shortest, you will also solve some issues.
          Ben Harrison-Graham
          Ben Harrison-Graham
          Thanks for your help. I have now resolved this. I am a gold member. The options I get under Route Optimisation are Shortest and Fastest. I understand that you recommend I select Shortest.
          Ben
          Navigation Next
          • Travellexxie
            wrote on last edited by Travellexxie
            It depends on your what you want. Shortest means every little s***street available or streets through large cities will be in your route. But you can try both possibilities and decide what comes closest to your needs.
            MRA Lifetime Gold
              Ben Harrison-Graham
              Ben Harrison-Graham
              OK thanks for the help
              Ben
              Navigation Next
              • Travellexxie Travellexxie
                nomko
                nomko
                nomko
                Banned
                @Lex.Kloet.RX said in Route Optimisation:
                Lex, thats really harsh to put it like this!
                It's not only streets but also ferry's and so on.
                A lot of users who keeps optimization on fastest experience problems like crossing a river with ferry.
                Why?. And this is wat @Lex.Kloet.RX dors not explain to you:
                Having optimization on fastest means that MRA calculate the fastest route which might not be the route you want.
                As example: getting from A to B might take 60 minutes with a ferry and MRA set on shortest while having MRA set to fastest takes 50 minutes using a bridge further down the river. Guess which route MRA will choose when optimization set to fastest although you wanna cross the river using the ferry.....
                It is recommended to set optimization to shortest to utilize MRA fully.
                MotoCon Travellexxie 2 Replies Last reply
                  Ben Harrison-Graham
                  Ben Harrison-Graham
                  OK thanks again guys.
                  Ben
                  Navigation Next
                    Ben Harrison-Graham
                    Ben Harrison-Graham
                    I have found fastest to be more suitable for a day's ride I've just planned. Shortest and fastest did what they say.
                    Thanks
                    Ben
                    Navigation Next
                      Thanks
                      @Ben-Harrison-Graham jep, me too. You can always correct the route with a few shapingpoints. Shortest and a big city ahead, is not funny.
                      MRA Lifetime Gold
                      • nomko nomko
                        @Nomko-Nomden said in Route Optimisation:
                        This may be recommended by @Nomko-Nomden, but certainly not by everyone.
                        @Nomko-Nomden please stop pushing YOUR preferences as generally advised.
                        • nomko nomko
                          @Nomko-Nomden stay with your preferences and I will stay with mine. There is no need to get personal...
                          MRA Lifetime Gold
                            nomko
                            nomko
                            nomko
                            Banned
                            @Lex.Kloet.RX
                            Als jij het persoonlijk neemt is het jouw eigen probleem. Maar je staat vanaf nu op negeren bij mij dus reageren op mijn berichten heeft geen zin meer.
                              nomko
                              nomko
                              nomko
                              Banned
                              @Con-Hennekens said in Route Optimisation:
                              Were did i said it was generally advised????
                              Ook jij gaat bij op blokkeren...
                              • nomko nomko
                                Je had eerder al beloofd dat je mij had geblokkeerd 😉
                                Zoals ik hierboven al heb aangehaald:
                                DAT is dus een advies dat doet voorkomen alsof dat algemeen gedragen wordt. En dat is niet zo.
                                It is advised = algemeen
                                I advise = wat JIJ adviseert
                                Ik ga jou NIET op blokkeren zetten, want het is veel te belangrijk dat sommige van jouw uitspraken gecorrigeerd worden. Dat kun je irritant vinden, maar dan kun je het beter laten. Niemand hier zit te wachten op desinformatie.
                                • Nick Carthew
                                  I am locking this topic as the original question has been answered and the replies are becoming personal. The route optimisation tool is like any tool in the toolkit, how you choose to use it is a personal thing. Some people prefer to use a hammer instead of a screwdriver, that is their choice!
                                  • Nick Carthew Nick Carthew locked this topic on
                                  nomko
                                  nomko
                                  Ben Harrison-Graham
                                  Ben Harrison-Graham
                                  • reis in concept kopieren
                                  • Suggestion: Route Auto Name
                                  • Trips, interaction with Clubs
                                    Andy Nicholson
                                    Andy Nicholson
                                  • Globale inhoud van een update en mogelijk wijzigingen.
                                    Peter 12m
                                    Peter 12m
                                  • Move Google Maps up the list
                                    JP d
                                    JP d
                                  • Measurement units setting is global and not according to the country why the route is planned.
