  2. MRA Routeplanner Next Beta
  4. Segment function with the HERE map
8 Posts 4 Posters 37 Views 2 Watching
  • Emanuele 5
    Emanuele 5
    Emanuele 5
    wrote last edited by
    Could the option to select a "curviness" level for a route segment—similar to how it works in the TomTom routing engine—be implemented for the HERE map/routing engine?
    I ask because when using the TomTom engine, the map becomes cluttered with a large number of grey waypoints, making it difficult to see them clearly or locate the specific one you need; for a motorcyclist, scrolling through such a long list is certainly not very convenient.
    The segment-based functionality in the HERE engine is not as customizable as it is in the other engines.
    Is it possible to consider further development in this regard?
      Unfortunately not. HERE does not support it
      • Emanuele 5 Emanuele 5
        @Emanuele-5, A pretty easy workaround is to plan on the TT engine, use the compare function in the toolkit (yes the toolkit, NOT the compare in the menu itself!) make HERE equal an then switch the engine to HERE. This function adds shaping points automatically, in order to make the routes equal on both (or all three) engines.
        Emanuele 5 2 Replies Last reply
          Emanuele 5
          Emanuele 5
          Emanuele 5
          This post is deleted!
            Emanuele 5
            Emanuele 5
            Emanuele 5
            @motocon
            Thanks for your reply MotoCon. I was actually testing this just last night; however, when you go to navigate the route using the Navigator app (which uses HERE maps), you end up with a very long list of shaping points (in gray). If you need to view a specific waypoint from the waypoint menu, it becomes quite inconvenient to scroll through that list—especially while riding a motorcycle.
            Do you follow my line of reasoning?
              @motocon
              @Emanuele-5 You missed the last part of @motocon instructions. After you have finished using the TT engine, switch back to HERE.
                @motocon
                @Emanuele-5, What Nick said 😉
                Emanuele 5 1 Reply Last reply
                  Emanuele 5
                  Emanuele 5
                  Emanuele 5
                  @MotoCon I followed your advice to switch the routing engine back to HERE, but when I start navigating a route with the Navigator app, I notice that it has created a very long list of shaping points—doesn't this happen to you too?
                  Emanuele 5
                  Emanuele 5
                  • Log in
                    Rod Sydenham
                    Rod Sydenham
                    38
                    394
                  • Restriction on scenic length?
                    Jeroen ekkel c
                    Jeroen ekkel c
                    Andy Beviere
                    Andy Beviere
                    1.7k
                  • AI pricing is too high
                  • Library Structure
                    John Matthews 0
                    John Matthews 0
                    Juudje39
                    Juudje39
                  • Allow the last entered point to be set as a via point
