  2. MRA Routeplanner Next Beta
  4. RouteXpert display on the map
9 Posts 4 Posters 60 Views 2 Watching
  • Corrado Miniati 0
    Corrado Miniati 0
    Corrado Miniati 0
    wrote last edited by
    Hello,
    When I select the option in the planner to display RouteXpert routes on the map, they appear as faint purple lines—sometimes more intense, and at other times much less visible.
    Is this the correct way for them to be displayed?
    What do the varying intensities of the purple lines signify?
    Thanks a lot
      wrote last edited by MotoCon
      That's a heat map. The more intense the colour, the more a route goes there. What is the relation to the routeXpert route? I suspect you are looking at a selected folder with routes, not a single route?
      Corrado Miniati 0 1 Reply Last reply
        Corrado Miniati 0
        Corrado Miniati 0
        Corrado Miniati 0
        @MotoCon
        Hello, and thanks for the feedback.
        Let me try to explain more clearly, in the RouteXpert folder within the planner, I found this route, which was shared by a team member:
        However, when I open the planner and view that same area on the map, if I enable the RouteXpert option in the map layers I only see the heat map (in purple) but the route shared by the team member does not appear.
        What am I doing wrong?
        • Corrado Miniati 0 Corrado Miniati 0
          @MotoCon
          @Corrado-Miniati-0, Alright, so the color of the map overlay is almost equal to the route line itself...
          Try these settings in the editor settings (3-dot menu next to the export button).
          • Corrado Miniati 0
            Corrado Miniati 0
            Corrado Miniati 0
            I tried making changes, but nothing happens.
            When RouteXpert is enabled in the map layers, the routes do not appear.
              @Corrado-Miniati-0 Can you share the link to the RouteXpert route please.
              • Corrado Miniati 0
                Corrado Miniati 0
                Corrado Miniati 0
                Sure:
                https://beta.myrouteapp.com/plan/30b105ab-e995-4761-85ae-513e9a623dab
                However, I don't see any RouteXpert routes on the map, even when selecting the corresponding option in the map layers.
                Thanks a lot
                  It’s built as rough indication of where they are. Not exactly one on one.
                    Corrado Miniati 0
                    Corrado Miniati 0
                    Corrado Miniati 0
                    wrote last edited by Corrado Miniati 0
                    Hi Corjan, thanks for the feedback.
                    However, compared to the previous version of the planner, there is a significant difference in how RouteXpert routes are displayed, even with the same layers selected.
                    Below, you can see screenshots from the old and new planner; previously, the routes were clearly visible, but in the new planner, they are unrecognizable at least, I can’t make them out.
                    Corrado Miniati 0
                    Corrado Miniati 0
                      David McCoy
                      David McCoy
                      18
                      29
                      177
                      Emanuele 5
                      Emanuele 5
                      15
                      30
                      1.8k
                    • Here Terrain maps style
                      257
                    • Kaart niet zichtbaar
                      119
                    • RouteXpert display on the map
                      Corrado Miniati 0
                      Corrado Miniati 0
                    • Comparison route remains on map
                      Parantapa
                      Parantapa
                      62
                    • Hello
