<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RouteXpert display on the map]]></title><description><![CDATA[<p dir="auto">Hello,<br />
When I select the option in the planner to display RouteXpert routes on the map, they appear as faint purple lines—sometimes more intense, and at other times much less visible.<br />
Is this the correct way for them to be displayed?<br />
What do the varying intensities of the purple lines signify?</p>
<p dir="auto"><img src="/assets/uploads/files/1793703049213-53472143-b0ac-40d9-bec0-871bc4006233-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="1041" height="940" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12173/routexpert-display-on-the-map</link><generator>RSS for Node</generator><lastBuildDate>Tue, 03 Nov 2026 18:22:43 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12173.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2026 10:50:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RouteXpert display on the map on Tue, 03 Nov 2026 16:36:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/motocon" aria-label="Profile: MotoCon">@<bdi>MotoCon</bdi></a><br />
Hello, and thanks for the feedback.<br />
Let me try to explain more clearly, in the RouteXpert folder within the planner, I found this route, which was shared by a team member:</p>
<p dir="auto"><img src="/assets/uploads/files/1793723439216-routexpert.jpg" alt="RouteXpert.jpg" class=" img-fluid img-markdown" width="1221" height="1014" /></p>
<p dir="auto">However, when I open the planner and view that same area on the map, if I enable the RouteXpert option in the map layers I only see the heat map (in purple) but the route shared by the team member does not appear.<br />
What am I doing wrong?</p>
<p dir="auto"><img src="/assets/uploads/files/1793723702131-si-routexpert.jpg" alt="Si RouteXpert.jpg" class=" img-fluid img-markdown" width="1745" height="1139" /></p>
]]></description><link>https://forum.myrouteapp.com/post/87031</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87031</guid><dc:creator><![CDATA[Corrado Miniati 0]]></dc:creator><pubDate>Tue, 03 Nov 2026 16:36:34 GMT</pubDate></item><item><title><![CDATA[Reply to RouteXpert display on the map on Tue, 03 Nov 2026 13:04:03 GMT]]></title><description><![CDATA[<p dir="auto">That's a heat map. The more intense the colour, the more a route goes there. What is the relation to the routeXpert route? I suspect you are looking at a selected folder with routes, not a single route?</p>
]]></description><link>https://forum.myrouteapp.com/post/86902</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/86902</guid><dc:creator><![CDATA[MotoCon]]></dc:creator><pubDate>Tue, 03 Nov 2026 13:04:03 GMT</pubDate></item></channel></rss>
