  4. Automatic download of offline maps
9 Posts 8 Posters 1.7k Views 4 Watching
  • stuart marritt
    stuart marritt
    stuart marritt
    wrote last edited by
    Just a suggestion if it could be made possible.
    Could the app be configured to check all your currently installed offline maps and notify you of an update upon starting the app?
    I ride with a few people that always fail to update maps and in some cases don't even know how to do it!
    It would be good if you are notified of an update automatically and able to update the installed offline maps once notified.
    Nick Carthew TomOnTour 2 Replies Last reply
      This could be done easily but honestly updating once or twice per year is fine. Informing users about updates will result in more issues than satisfaction 🙂
      If you get an update notification while on vacation on poor wifi you will click it. If the update never completes you are off worse.
        @stuart-marritt I fully agree with Corjan, it is easy to become fixated with having the latest map, when in reality most updates will not have any effect on your route.
        • Jörg Neudert
          Jörg Neudert
          Jörg Neudert
          If a roundabout suddenly appears where you were expecting an intersection, things get a bit tricky... 😉
            TomOnTour
            TomOnTour
            TomOnTour
            @stuart-marritt Same here Stuart,
            I know your point very well, but as any map update is not only an file that have to be downloaded and is available from several sources with high transfer rates, an update might cause you sometimes sevral hous till it will be finished.
            I am sure you don't want to be in exactly this situation while you are on a trip.
            I am rpetty careful about map updates and plan them up front to be sure that they don't impact my tours or plans.
            MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
            MRA Navigation Next (Lifetime Gold)
            MRA Routeplanner NEXT beta (Lifetime early access)
            using iPad Pro (iPadOS 27.2.1) and Macbook Air (macOS 27.2.1)
            Jeroen ekkel c 1 Reply Last reply
            • TomOnTour TomOnTour
              Jeroen ekkel c
              Jeroen ekkel c
              Jeroen ekkel c
              Ligt er aan hoevveel kaartupdates het moet doen, de updates zal alleen de landen nemen die je hebt geselcteerd heb je bijv maar 1 land geselecteerd je eigen land gaat vrij vlot dan wel een gebied van je eigen land.
              heb je meerdere landen dan gaat het zeker heel lang duren die alles dan gaat downloaden.
              • stuart marritt
                stuart marritt
                stuart marritt
                wrote last edited by stuart marritt
                Thanks all for the replies
                I do get where you are coming from with updates if you're on a tour etc.
                I just think it should be easier for some users to know updates are available.
                As I say so e of the people I ride with are a bit technology challenged!
                • Jörg Neudert Jörg Neudert
                  wrote last edited by a white mouse on the motorbike
                  This can happen at any time! It’s not just down to updating the offline maps, but also to whether or not the map has already been updated.
                  On a separate note, before you set off on a longer trip, always make sure to update the maps yourself!
                  @stuart-marritt
                  Well, you just need to offer them some support! It’s quite simple, as you know. Just get together a few days before the trip and sort this out together! That way, you can go over the trip straight away!
                    HERE updates map versions every week, and a higher version is by no means an indication that updates have been done on the map tiles relevant for you. That being said, the handling of map updates is very much improved in V6. But an indicator at start of app is not one of the improvements 😉
                    Jeroen ekkel c
                    Jeroen ekkel c
                    Jörg Neudert
                    Jörg Neudert
                    TomOnTour
                    TomOnTour
                    stuart marritt
                    stuart marritt
                    • Elevation profile: cursor that follows the route on the map
                      63
                    • Question on Beta access
                      334
                    • Guida Libera
                    • Totaaltijd veranderd niet
                      Gerard Caspers
                      Gerard Caspers
                    • Route Opacity Viewing Existing Routes in Library
                    • Device Limit – There Are Limits to My Understanding
                      BMcG
                      BMcG
                    • A to B Navigation with Extra Stop.
