  4. Offline Maps and view of the entire path
12 Posts 6 Posters 3.8k Views 2 Watching
  • Davide i
    Davide i
    Davide i
    wrote last edited by
    I would like to know why if I use offline maps I can't receive online map updates and vice versa.
    Let me explain, I have the offline map loaded, but I'm using the online maps. My route takes me to an area where cellular reception is missing (in the mountains or otherwise). MRA isn't working well because there's no signal. The management of Online/Offline maps should be automatic so that it works at its best.
    In the navigation screen, there is a view of the entire route missing. It would be nice if, by pressing the compass, you could switch from the north view, dynamic view, top view, to the full route view.
    Thanks
    • RetiredWingMan
      If your maps are downloaded then they are always used for navigation. If data service is not available MRA switches to offline mode. If you know you are going to be in areas with poor coverage I suggest you switch to fully offline operation. To see the entire route long press the compass or select full route in the menus.
      • stuart marritt
        stuart marritt
        stuart marritt
        I have no issues with online/offline modes.
        I have offline maps downloaded and also connected online and it switches between online and offline automatically
        • Parantapa
          Parantapa
          Parantapa
          It switches to offline mode automatically for me too when there’s no signal.
          • Guzzist
            at my end, it's not automatically. Ther is a popup message, I have to switch to offline in such cases. I need to quit the message, then I should be able to change to offline manually - but after quitting the message, this message pops up immediately! Again an again - it's a nightmare...
            • RetiredWingMan
              What version is your MRA and what device are you using to navigate? Auto switching between offline and online has not been an issue for a long time. If you switch to offline before starting you're route do you still have problems?
              Guzzist 1 Reply Last reply
              • Davide i Davide i
                Thanks
                If you HAVE offline maps, you ARE USING offline maps if they cover your location. Offline maps and offline navigation are separate things. There is no management of using offline maps or online maps at all. There is management of offline navigation, for cases where you lose internet connection, and in my opinion that works just fine.
                It does exactly that... for full route view long press the compass...
                Your questions sound sound like you are using an entirely different app 😉
                Davide i 1 Reply Last reply
                  I used version 6.0.0 - 515 and I had downloaded the offline map of the region I drove.
                  But by the last comment from @motocon , now I'm a bit confused about:
                  offline- versus online maps
                  offline- versus online navigation
                  But I believe, with the upgrade to "Next" and all the new stuff, it's not necessary to discuss such old issues...
                  • Guzzist Guzzist
                    @Guzzist, my comment is not intended to raise confusion but to eliminate it 😉
                    Like I said, Offline maps and Offline navigation are separate things.
                    Offline maps is intended to prevent the need for downloading map tiles on the go. You can download them in advance, so there is no need to download them while riding. Therefore, whenever available, your offline maps will be used. If not available, they will be downloaded on route afterall.
                    Offline navigation tells the app to do navigational calculations by itself, without help from online (Here) services. Of course to be able to calculate navigational routes depends on the availability of offline maps, but it is not mutual exclusive.
                    So:
                    You can navigate online, without the need for offline maps
                    You can navigate online, including the use of offline maps.
                    You can navigate offline, completely depending on pre-downloaded maps.
                      So:
                      Davide i
                      Davide i
                      Davide i
                      @MotoCon
                      Ah ok, now is clear.
                      Anyway, I tried MRA version 6 and it works much better. Well done.
                        Davide i
                        Davide i
                        Davide i
                        @MotoCon
                        I see the problem with CarPlay. There we don't have the compass and I only see the button fir full view of the route. With CarPlay I can't select the dynamic view or the north view.
                        Maybe I'm wrong about something?
                        • Davide i Davide i
                          @MotoCon
                          @Davide-i, yes you can set your preferred view, tap the screen, the gear icon. I don't remember the exact words, but it is in there.
                          No the compass is not visible on carplay. The V6 app has a nice new feature though. Mount it next to your AA/CP screen and select the complementary AA/CP screen. There you see the buttons and more, that are missing on the carplay (or Android Auto) screen itself 😉
                          Parantapa
                          Parantapa
                          stuart marritt
                          stuart marritt
                          Davide i
                          Davide i
                          • Elevation profile: cursor that follows the route on the map
                            63
                          • Question on Beta access
                            334
                          • Guida Libera
                          • Totaaltijd veranderd niet
                            Gerard Caspers
                            Gerard Caspers
                          • Route Opacity Viewing Existing Routes in Library
                          • Device Limit – There Are Limits to My Understanding
                            BMcG
                            BMcG
                          • A to B Navigation with Extra Stop.
