  4. Offline Navigation
Offline Navigation
4 Posts 3 Posters 501 Views 1 Watching
  • Lex K Franks 0
    Lex K Franks 0
    Lex K Franks 0
    Does the navigation app default to offline maps(if installed)automatically if you find yourself out of a cell?
    I have my regional area offline maps installed but was unsure whether I had to change manually or is there an auto setting which takes over.
    Lex Franks
    • Lex K Franks 0 Lex K Franks 0
      Lex Franks
      @Lex-K-Franks-0 The app will switch automatically if you have your routes synced too. To sync (download) your routes, open the app and tap Routes and tracklogs, now tap the 3 dots top right and select Sync all my routes.
        Lex Franks
        The app defaults to offline maps ALWAYS when they are available on your device, whether you have signal or not 😉
          I don't understand the relevance of synced routes against the use of offline maps?
          And maybe this topic should be moved to some self help category.
          Lex K Franks 0
          Lex K Franks 0
          • F014 WP Numbering illogical
          • Map colours and side roads
          • OSM Routing with MRA
          • F013 Facilities/POIs – A search function covering the entire map is unfortunately missing here.
          • GPX POI Editor
            Pierre c
            Pierre c
          • Route MRA importeren in Google Maps
