  4. CarPlay says that I need a subscription
12 Posts 5 Posters 1.6k Views 2 Watching
  • Martin Garand
    Martin Garand
    Martin Garand
    Hello
    Using MyRoute on my iPhone on a Chigee Aoi-6, I sometimes get a message saying that I need a subscription to use CarPlay
    But I have a subscription and I don’t have always that message
    I need to restart everything a few times to finally get it to work
    What ca be the problem?
    • Hubert Thoring
      Maybe delete the app and reinstall it, ..
      Martin Garand 1 Reply Last reply
        Martin Garand
        Martin Garand
        Martin Garand
        Already tried it and still the same issue
        Sometimes it works ok at first try and other times I need to restart it many times
        And that, on the same Day after a Quick stop. It was working and after it does not want to
        • Albert van den Elsen
          Hello @martin-garand.
          You can try this.
          The issue is caused by intermittent CarPlay handshake failures between iOS, MyRoute-app, and the Chigee Aoi‑6. When the handshake is incomplete, MyRoute-app cannot verify your Premium subscription fast enough and temporarily falls back to “no subscription”.
          Open MyRoute-app on your iPhone first, wait 3–5 seconds until the map loads, then connect to the Chigee Aoi‑6.
          This ensures:
          Subscription is verified
          App is fully awake
          CarPlay receives the correct authorization
          Most riders report this eliminates the issue entirely.
          iPhone 15,
          Garmin Zumo XT3
          Carpuride W702 Pro
          Sena 20S EVO headset
          Harley Davidson Road King M8
            You can try this.
            This ensures:
            App is fully awake
            Martin Garand
            Martin Garand
            Martin Garand
            You can try this.
            This ensures:
            App is fully awake
            Hello,
            I tried your suggestion but it is not always validating the subscription correctly.
            So i'm still having problem using it with Carplay
            • Martin Garand
              Martin Garand
              Martin Garand
              Here is a new update on that problem.
              Yesterday, i had that same problem again.
              I then closed the app on my iPhone and start it directly on the Chigee. From there, i was able to start last route and it displayed instantly.
              Any idea about a real solution ?
              Thanks
              • Martin Garand
                Martin Garand
                Martin Garand
                Hello,
                Any update on that problem ?
                My iPhone 14 is up to date
                My Chigee Aoi-6 is up to date as of 2026-08-21
                every now and then, when i start MyRoute on the Chigee, it said I need a Subscription. but not every time and still no clue about what makes it display that message or not.
                And to make it work again is always trial and error. Reboot the iPhone, reboot the Chigee, reboot both...
                Pretty anoying when you are ready to go and your nav system just don't show you anything but an error message that should not be present for any reason
                Skellum 1 Reply Last reply
                • Marinus van Deudekom
                  Maybe over of the Chigee users can help you out.
                  My best guess would that it's device related so the combination of your iPhone and the Chigee
                  • Martin Garand
                    Martin Garand
                    Martin Garand
                    everything is related to the fact that MyRoute needs a subscription.
                    As the app itself is running on the iPhone, my guess is that it is related to what the app (in the iPhone) is telling to the Chigee.
                    • Martin Garand Martin Garand
                      Hello,
                      Skellum
                      Skellum
                      Skellum
                      wrote on last edited by Skellum
                      @Martin-Garand
                      Just a thought, could it be the Sim card in the Chigee that needs renewing?
                      • Skellum Skellum
                        @Martin-Garand
                        Martin Garand
                        Martin Garand
                        Martin Garand
                        @Skellum said:
                        @Martin-Garand
                        There is no Sim card in the Chigee
                        • Skellum
                          Skellum
                          Skellum
                          Oh ok, I have one in mine hence the suggestion.
                          I hope you sort it.
                          Skellum
                          Skellum
                          Martin Garand
                          Martin Garand
                            Òscar
                            Òscar
                            81
                            Rob Veerman
                            Rob Veerman
                          • Pay for beta?
                            828
                          • Live tracking problem on Android tablet
                          • Suggestion -> Statistics
