  4. Upgrading from Zumo XT to XT2
49 Posts 11 Posters 8.0k Views 4 Watching
    @John-S-Parry said:
    At the physical device level. The Garmin doesn't overheat. It can tolerate Death Valley USA level heat and other abuses that a phone can't. Additionally, the Garmin screen is completely readable in glare, while the phone isn't.
    This is largely depends on the choice of phone. Mine is military specced with a 3000 Nits brightness. More than enough to be used with a matte screenprotector to reduce glare.
    And on the Android side, the rugged versions of phones I've researched don't provide the full functionality of regular phones for everyday use.
    Motorola has a large lineup of these military specced high brightness phones. The Edge 60 Neo for example can be bought for around 225 euro, and is perfectly fit to be used as a daily phone. If you are a high-end phone user perhaps it is not your thing, but choosing a Zumo also means an extra device. I bought my motorola dedicated for navigation alongside my daily pixel.
    But yes, a Zumo can be, under specific conditions, be preferable. It would be very bad if it could not... 😉 I did not mean to start a flame war, thanks for your motivation in favor of an XT3.
    @Con-Hennekens said:
    But yes, a Zumo can be, under specific conditions, be preferable. It would be very bad if it could not... I did not mean to start a flame war, thanks for your motivation in favor of an XT3.
    Con, no flame war. 😊 I don't have stock ownership in Garmin, and would stop using Garmin devices in a minute if I felt there is a superior (for me) alternative.
    At a practical level, a military grade phone (as you pointed out) would meet durability standards. I'm not sure that I could personally live with that kind of a phone as a primary everyday device, given the added weight/bulk, and a less than highest end camera. At least that what I've read about this class of phones. And of course, it's not Apple. 😀
    HW aside, there are the many functional differences between a phone app (MRA or otherwise) and an XT3. I outlined many, and they're features I wouldn't want to live without leaving an XT3.
    I respect your loyalty towards the MRA phone app. I have the same allegiance towards MRA Routeplanner. I do hope the MRA app continues to evolve and someday reach a level of stability I could live with.
    • Mzokk Mzokk
      FWIW I have a Zumo XT but now use MRA for navigation. Part of the reason is that my honda Africa Twin adventure sports has a built in AA/CP screen (Made by Garmin!!) I can control the map and waypoint skipping etc from the bar buttons on the Honda. I've found the app to be reliable for me for over a year and 5 multi day trips. I still use the Zumo XT and have it mounted on the Honda as I still have a use for proximity alerted POI's and I use it as a backup with all of my planned routes on the Zumo and I also run the track of the route on the Zumo. I had a look at the XT2 when It came out and a couple of things Garmin did put me off it. Number one was that you can't bluetooth routes to other Garmin devices on the XT2 and I often lead groups and this facility was important. For the XT2 and I believe 3 you can only share directly with Zumo's that can run Tread?? John would probably be able to correct me on this. For me this is not so important now as I can connect older Zumo devices to my phone and transfer routes via a Garmin Lead. In your scenario since you already have an XT give the routing app a go for a while and if you don't get on with it its no loss. I too used Garmin devices for over 20 years and their hardware is good and reliable. Unlike others I have no issue using Basecamp and still use it for POI handling along with POI loader. I also still use it to combine daily track files for tours and have no issue creating routes on it. For me the USP of MRA is the ability to create routes quickly on the fly when I'm on tour and the ability to access them on any device anywhere. Garmin's software support and the routing algorithms they use for their devices after the 390/590 range no longer suit my needs. Its good that we are now spoilt for choice though.
      I understand your points regarding the XTs and the sharing of routes. It's definitely a weak point in Garmin world. I don't know what Tread can or can't do in this regard, because I don't have external storage (Explore DB) activated in the app. My "neutered" version of Tread provides me traffic alerts and control of music on my phone -- that's it. When I lead rides, I distribute GPX files the old-fashioned way, which as you know is cumbersome, and doesn't always work as planned.
      Back in late 2024, I actually did make an honest attempt to learn and use the MRA Phone app. I think I did achieve some proficiency. I certainly liked the Sync function for seamlessly transferring routes through the MRA cloud from Routeplanner to the phone. But I ran into a few problems that frustrated me and tempered my enthusiasm. The primary issue was finding that off-line vs on-line doesn't necessary calculate the same. I posted a topic at the time, outlining in detail how the two versions differed and contrasted with the XT calculation. Corjan responded (I'm paraphrasing) with "What do you want me to do about it"? I was a bit shocked to get a response like that. But his message was that it's a HERE issue and his hands were tied. It's the same response we get to many of the outstanding problems today. It simply not acceptable to me that I couldn't trust consistency of route calculation at all layers of MRA.
      Regardless, with my overall testing, it always went back to my XT having navigation functionality that didn't (and currently doesn't) exist in the app. As I mentioned to Con, I hope the app does evolve to a point where I can re-consider it in the future.
      • John S Parry John S Parry
        I cannot deny that some fellows became friends 😉 (or I would not dare...🤣 ), but it is not about loyalty. At the time I was really struggling many years already with Mapsource as well as Basecamp, looking at the same videos trying to find out how it works again. It did never stick. When I learned about MRA planner I was still using a zumo (I went from Streetpilot 2610 to Zumo 660 and Zumo 390). The planner was a real nobrainer compared to the Garmin alternatives. Then MRA came With Navigation (which in our circle we call "Previous" by now 😉 ) I tried it for a few rides, and I never felt the need to pick up the Zumo again. So not just loyalty, but also the genuine belief that it works great as an ecosystem. And you are right to add "for me", because that's actually what it is. I am a tourer, I don't do off road, make most of my own routes. We just have different use cases or methods I think.
          You are comparing the app from 2 years ago to a brand new XT3. You leave out that the app has had a couple of major make overs since then.
          What functionality do you find in that XT3 that you dont find in MRA Next anno 2026.
          That would be a fair Comparison
            You never did answer my question asking if you have extensive (or any) XT experience. If you don't, much of what I describe isn't going to make much sense or have the impact that it should. Regardless, I outlined some of the major differences in post#3. if you dispute any of those or want clarification, I'm happy to have a discussion.
              @John-S-Parry Yes I did use an XT device for a couple of years and the main reason for me to switch to the T865X was the multiple attempts of that XT to mess up my ride. This is due to way Garmin devices handle routes that are not made with Garmin. I've written a couple of post back then discribing how Garmin is discriminating route not made with Garmin devices and ofr software. Branche protection you could say.
              The screen of that XT and the visibility made decide to search for a rugged tablet wit h at least the 1000 nits like the XT has. I also wanted such a device to handle MRA routes like they were intended. Thus quiting the Garmin algorithme.
              The few advantages you mentioned in post #3 to me are more user prefered gadgets. I tend to plan my trips carefully and thus there is no need to ad different peaces of other routes along the way.
              In the end I've found the T865X more capable to fill my needs. MRA runs perfect on it with all it's features and om top of that a 1300 + nits screens witch is even better than the XT's screen.
              I hope this answers your questions.
              John S Parry Mzokk Travellexxie 3 Replies Last reply
                #23
                I don't know what to say about this. I've spent the last few years using MRA Routeplanner to create routes for the XT, and now the XT3. I've used both the HERE and OSM base maps for creating GPX files imported into the Garmin. I sometimes even use inRoute (Apple Maps) to create GPX files for XT import. We're talking literally hundreds of routes. That seems like a lot, but I lead rides that span weeks and sometimes crisscross the USA. Being retired and having time is great. 😊 I've NEVER encountered what you described. There isn't a Garmin conspiracy to tank routes not developed with Basecamp. You seem experienced, and I mean no disrespect, but there is something on the user side here. Besides my own experience, I ride with many who develop routes in Kurviger, Scenic and Calimoto for import into the XT, our most used group device. Again, I'd know if Garmin was playing games. I wouldn't be able to avoid it. They're not.
                I plan carefully too. And I'm a firm believer in following a route as planned. But none of us are so perfect that we know exactly where we're going to be at all times during the day, and with crystal ball vision for planning accordingly. Sometimes you have to make a diversion for reasons unanticipated, especially when riding with a group. That's the nature of life. And the "Look Ahead" feature in the XT/XT2/XT3 handles it eloquently. You not only locate where you need to go (sometimes well off the main route), but you can automatically add this diversion as a via point to your route. Maybe it's a USA thing where we have vast open spaces, but it can be a life saver under certain circumstances.
                We can go on. I can expand on the other items I mentioned, but it's not necessary at this point. The message is that the XT series is incredibly competent if you understand it and know how to manipulate its advanced functions. It's not perfect, and of course there are things I'd like changed. But its core navigation functionality is solid. I wouldn't use it otherwise.
                  @Marinus-van-Deudekom I'd have to say I use Basecamp routes and MRA routes interchangeably on the XT my other Zumo's without issue and have transferred many Basecamp routes to MRA without issue and used them via the navigation app. The only point of note is that MRA prepared routes transferred to Garmin devices do not transfer Via points to Zumo favourites as they are imbedded in the routes rather than separate entities as they are in Basecamp prepared GPX files.
                    @John-S-Parry let's agree to disagree. Have fun riding
                    • Don Stauffer Don Stauffer
                      I appreciate your enthusiasm for the DMD / Android solution. I've already worked out the mechanical, electrical and software requirements for the Garmin. It's old fashioned, I admit. But it fits my old school BMW very nicely, and I'm not very keen on starting over with a new system. I'm not sure you appreciate how limited the cockpit area is on an older RT. I'm now in my 5th decade of touring, and I value simplicity over new features. Navigation assistance with minimal distraction is my ultimate goal.
                      @Don-Stauffer / @john-s-parry ...at the point to share routes (p.e. as group leader) with other participants - there is one point more, I see an advantage for MyRouteApp: it's not needed any longer to share gpx files cumbersome wireless, or by cable or mail, or...
                      Simply use an Event in MRA Routeplanner and share your route with participants. If they use MyRoute Navigation Next too - the route(s) will be synched immediately wireless. With no hassle, any of the participants Navi calculates a different route layout!
                      And because I said: at the moment, where MyRouteApp isn't good enough for offroad riding - and therefore I use DMD Hard- and Software parallel. The DMD2 app can do the same: share the route with other participants, simply by synchronise. This group ride function can additionally share the position of each rider on the map of each! Incl. SOS button to send "help please" to the other participants. That are incredible higher levels in navigation; it's more than pure navigation.
                      Compared with GARMIN, it looks like GARMIN simply failed to recognise the signs of the modern times and is effectively selling outdated solutions. And more, almost every new device came with a new subsystem for loading GPX files onto the sat-nav or managing routes. That’s not just a nuisance – it’s infuriating!
                      I’ve been riding motorbikes and driving cars for 50 years – new ones from time to time. And every time, I’ve had to learn a new system. But as the saying goes: ‘Learning – or riding a motorbike – keeps you young’! 😉
                      • Guzzist Guzzist
                        In a perfect world, this would be great. Unfortunately, the reality is that we live in a mixed world of riding. Not everyone uses MRA NN, much less a phone for navigation. But even in this ideal MRA bubble your fantasizing, MRA NN is not guaranteed to calculate routes the same in online and offline usage. You'd have to guarantee that everyone has their Functional nav settings configured exactly the same. Good luck with that. 🙄 In the nutshell, it's a rare situation where GPX files can be avoided. It's the world we live in.
                        There is too much wrong here to unpack and attempt to fix. I'm not going bother trying. I will say it's misinformation on par with the previously outlined Garmin conspiracy theory. Regardless, you seem enthusiastic and love motorcycle riding. Keep it going.
                        Stevedo 6 0 1 Reply Last reply
                          Stevedo 6 0
                          Stevedo 6 0
                          Stevedo 6 0
                          Well said.
                          • Marinus van Deudekom
                            If you don't want to use MRA that's fine by me. Please keep the Garmin discussion on a Garmin forum.
                            • Don Stauffer
                              Don Stauffer
                              Don Stauffer
                              I think my original question was answered; there are no functional differences between the XT models when downloading GPX files from MRA Route Planner. That question seemed appropriate for the Route Planner forum.
                              It seems that there is a lot of emotion tied to the choice of an archaic bit of hardware for navigation, instead of migrating to a multi-purpose device using MRA Navigation. I had no intention of stepping into that debate.
                              To each his own, and I hope everyone enjoys the late summer riding season!
                                @Marinus-van-Deudekom you should really gain some routemaking skills. I have never ever had one problem, with the routes I made either wit Basecamp nor with MRA. Therefore, my XT stays on my bike. Unbeatable: XT with MRA 1.2. In the camper and cabrio I work with the MRA-app on a tablet.
                                MRA Lifetime Gold
                                • Travellexxie Travellexxie
                                  @Travellexxie I've send you a PB
                                  • Thomas Neumeyer
                                    Thomas Neumeyer
                                    Thomas Neumeyer
                                    wrote on last edited by Thomas Neumeyer
                                    #33
                                    Hello all, quite interesting discussion here. I gave up with Android devices and navigation and changed to XT3. So far very happy for my use. I plan routes with the MRA route planner and use GPX 1.2. So far no issues with changes of the planned route. Garmin is just sitting above the dash and it's there. No hazzle with offline or online maps. No overheating of the phone if using CarPlay and no battery drain of the iPhone. I had several issues during my last rides with outdoor phones and tablets and found MY, maybe a bit old school, solution. The screen of the XT3 is great and serves my requirements. However MRA-App is a great software but a Garmin is a navigation system and a phone is a phone :).
                                    Don Stauffer 1 Reply Last reply
                                    • Thomas Neumeyer Thomas Neumeyer
                                      Don Stauffer
                                      Don Stauffer
                                      Don Stauffer
                                      @Thomas-Neumeyer It sounds like your situation is much like mine. I started using MRA after buying the Garmin, and like you, I appreciate the fit of the XT in the motorcycle instrument space. I did carry a tablet one one extended trip for the sole purpose of creating or modifying routes using MRA, but I found it slow and cumbersome. On later trips I carried a laptop. The tablet now lives in the kitchen as a recipe server, I've owned three or four and never found them particularly convenient.
                                      One Garmin feature that I appreciate is weather radar, using the Drive app. The traffic notifications are useful as well. The phone stays tucked in the tankbag. Can you comment on those features in the XT3? I'm assuming the Tread app has similar features to Drive.
                                      I'm curious, how do you transfer the GPX files, hardwired connection or phone app?
                                        I too would like to hear from @thomas-neumeyer regarding his XT3 perspectives. I love mine, and it's always good to read other perspectives.
                                        When I initially configured my XT unit years ago, I only used the Drive app briefly. I loved the ability to use the app to transfer routes, but I had BT conflict problems using other Drive functions. I'm going to attribute that to user error (me 😊 ) with the setup I had using multiple Cardo/Sena connections. At the time, weather and traffic didn't have much value to me, so I deleted the app. Basecamp file transfer was good enough.
                                        The XT3 uses the Tread app, which covers what the Drive app provides to the XT. My first thought was not to install Tread at all, given all the horror stories of destroyed/altered routes. But I found that you can install Tread without enabling external storage (i.e. Explore) and still get full weather/traffic/music/phone functionality. As you would expect, Tread is a more refined than Drive given that its 6-years newer. It works very well. I especially like the traffic alerts which have saved me more than once from getting stuck up ahead.
                                        The downside of not enabling Explore is that you're on your own transferring routes into the XT3. I use Window File Explorer to copy the GPX into the XT3. It's a simple drag-and-drop process. You're already in MRA Routeplanner on the computer anyway. Plugging the XT3 into a USB port to be seen as a file system is not rocket science, and the process is quick to perform. I copy into a Garmin/GPX folder on an inserted SD card within the XT3. It's a different subject, but there are advantages to using a card vs. XT3 internal storage for route storage.
                                        Some users seem to get away with using Tread/Explore and not report problems, and that's great. It's just something I don't want to get caught up in.
                                        • Thomas Neumeyer
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Hello, I am using Tread but I do not sync the routes. I just connect it to the PC and transfer the GPX to the SD card. Weather radar works and traffic information. All good. And the route planner on the Garmin is not too bad either. When I plan my trips/routes I use the planner of MyRoute on the computer. Save it and drive. I anyway spend time to generate the routes and after they are ready they will be pushed to the XT3. I do not let the Tread app sync because there can be surprises but I do not need to do this often. And in case I have no option to transfer data I use the Garmin route planner.
                                          Don Stauffer
                                          Don Stauffer
                                          Stevedo 6 0
                                          Stevedo 6 0
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Glenn.B
                                          Glenn.B
                                          MTC-Zeilberg
                                          MTC-Zeilberg
                                          • Online map settings
                                            392
                                            Jack 13
                                            Jack 13
                                          • Navigatie met DMD tablet
                                            Arjan de Vries
                                            Arjan de Vries
                                          • No skip waypoint on an A to B route
                                          • Myrouteappstay
                                            Bé Jeuring
                                            Bé Jeuring
                                          • Map met routes Offlne zetten lijkt het niet te doen
                                            Marcel Versluis
                                            Marcel Versluis
