  2. Export assistance
  3. [Export] Garmin
gpx 1.1gpx 1.2garmin xt
196 Posts 22 Posters 64.0k Views 5 Watching
  • Steve Jarrell Steve Jarrell
    @Carl-Lee I'm not sure what's going on, but as I've said before, I personally take Tread and other intermediate apps out of the mix and get down to the basics that I can see and understand.... Directly upload the 1.2 .gpx file via USP to the Garmin's /.gpx folder, import it, then look at the results.
    Using the 1.2 format, the Garmin (XT, XT2 or 3) should not be able to (will NOT in my testing) create a route that deviates from the route that you see in MRA as the Garmin route WILL be forced to follow the .gpx file's embeded track's "breadcrumb" to create the route and disregard the Garmin's own routing logic.
    If you choose to use Tread, Drive, Basecamp, MRA or any other file transfer method other than a direct USB transfer to copy your .gpx file from your computer's hard drive to your Garmin device's /gpx folder, then you are choosing to accept the ambiguity of not knowing whether or not that the file was properly transferred to the device.
    If you can't see that the .gpx file that's located on your local drive was successfully copied to the Garmin's /gpx folder YOU CANNOT know for certain that it has been transferred properly.
    Before anyone slams me with "the xyz app has always worked perfectly for me" believe me..... I understand!
    Even though you may not be having an issue with your particular configuration and apps (GREAT! keep doing what you're doing!), for anyone who is having issues this is where troubleshooting should begin. Eliminating variables one by one is the first step in troubleshooting a technical problem. Direct transfer of the .gpx file eliminates many of the variables. That's a fact!
    @Steve-Jarrell I finally got around to playing with 1.2, and I'm impressed. Here is a screenshot of one of the most troublesome routes I've recently created, and it passed my 1.2 test perfectly:
    It's a single very rural road that partially crosses the southernmost Sierra Nevada. It's a challenging road to route because it requires precisely positioned shaping points (using 1.1) to Import into a Garmin. I probably have more overall shaping points than needed, but 2 WPs in particular (23&24), as they are exactly placed, are absolutely necessary. It's a unique jog on the road that messes up recalculation on my Zumo otherwise.
    Initially, it took a lot of iterative back-and-forth between MRA and my Zumo to finally solve the puzzle. I literally spend hours playing with different shaping point scenarios before solving the mystery. Now with 1.2, I can delete WPs 23&24 and the route recalculates on the Zumo correctly. I'm finally going to able to achieve "what you see on MRA is what you get in the Zomo".
    1.2 is definitely going to make life easier for trickier situations like this.
    • John S Parry John S Parry
      Steve Jarrell
      Steve Jarrell
      Steve Jarrell
      #38
      @John-S-Parry Yep, the concept behind 1.2 is brilliant.... include the track inside of the route information so that the Garmin has no choice but to follow it. I used to have to also include a LOT of shaping points to make my Garmin calculate its route match MRA's route, but no more!
      Thanks for the information!!
      Steve Jarrell
      Western North Carolina US
      2025 BMW R1300GS
      2025 Can-Am Spyder
      DMD T865-X 8" Tablet
      Garmin XT3
      • Simon James Hancock
        Simon James Hancock
        Simon James Hancock
        I have been reading up on all of your post and trying to lean as much as possible.
        I created a route with all via points and when I set off it did not take me to via point 2 which is just a couple of hundred meters down the road from point 1, It kept trying to send me back to via point 1. Attached is a foto of the firts waypoints. Any help would be much appreciated. I saved the route as 1.2.
        • Simon James Hancock Simon James Hancock
          #40
          @Simon-James-Hancock It is always advisable to position the first waypoint 100+ metres from the actual start point, this ensures that the first point is registered as being passed. You were being directed back because the first point was missed.
            Simon James Hancock
            Simon James Hancock
            Thanks Nick for all of your help and work.
            Even when I passed the second via point it was sending me back to the first.
            Will it always try and send me back to the first via poin regardless on how far down the route i am?
            I would like to upload my GPX file for further inspection but I am still not allowed.
              @Simon-James-Hancock Yes, you’ll always be sent back to missed via points, via points are never automatically skipped you would need to manually skip a missed via point.
                Simon James Hancock
                Simon James Hancock
                How do I manually skip a missed via point.
                In the situation I found myself was their anyway I could have carried on my route without having had to go back to the first via point?
                Steve Jarrell Nick Carthew 3 Replies Last reply
                  Steve Jarrell
                  Steve Jarrell
                  Steve Jarrell
                  @Nick-Carthew Exactly. I think we all learn that the hard way! 🙂
                  Steve Jarrell
                  2025 BMW R1300GS
                  2025 Can-Am Spyder
                  Garmin XT3
                    Steve Jarrell
                    Steve Jarrell
                    Steve Jarrell
                    #45
                    @Simon-James-Hancock Refer to this help page for this answer and many others...
                    "When navigating, you can skip a waypoint by clicking on the next waypoint (top right button - screen 4). When pressing briefly, you must confirm the choice; when pressed for a long time, it is skipped immediately;
                    You can also skip multiple waypoints by going to the list of waypoints (three dots at the bottom right - screen 4) and clicking on the waypoint where the navigation should go directly;
                    Just like when starting up, you can also hold down the waypoint/point on the route line during navigation on the map to navigate directly there."
                    Steve Jarrell
                    2025 BMW R1300GS
                    2025 Can-Am Spyder
                    Garmin XT3
                      Simon James Hancock
                      Simon James Hancock
                      My route is saved as 1,2 and all od my points are via points.
                      I do not see the top right button.
                        Steve Jarrell
                        Steve Jarrell
                        Steve Jarrell
                        @Simon-James-Hancock I'm sorry.... I wasn't thinking. Those instructions are for the MRA app, not the Garmin. I need to pay closer attention!!
                        As @nick-carthew said, ideally you will avoid this situation by placing your starting location at least a couple of hundred yards/meters beyond where you actually want to start and that way you'll always past through your starting point. That will completely eliminate this issue in the future.
                        However, as a workaround you can try this.....
                        When you press "Go" to start a route in the Garmin, you're given three options as to where you want to start..... The beginning point, closest point (shaping point) or the destination. You had no doubt selected the beginning point and as far as I know there's no way to skip that once you've told the Garmin to go there
                        Since you don't have any shaping points in your route to select as your "closest" point, I THINK in this situation the only way to skip the beginning point if you had entered the route beyond it would be to stop the route in the Garmin, re-enter it and when asked where you want to start tell it the destination.
                        I'm not 100% sure that would work but I just created a test route of a couple of hundred miles from my house without any shaping points in MRA, saved the route in 1.2 format and imported it into my Garmin XT3 and told the Garmin to make the starting point the destination, and it followed my planned 1.2 route exactly as it was shown in MRA, so I'm fairly certain that will work.
                        I thought about suggesting turning off auto-recalculation, but since your starting point is a via point and you've told the Garmin that's where you want to start, I don't think that's going to work.
                        I'm sure there are others here with far more experience with MRA and Garmin than I have, so if there are other methods I'm sure they'll let us know and we'll all learn something new! 🙂
                        Steve Jarrell
                        2025 BMW R1300GS
                        2025 Can-Am Spyder
                        Garmin XT3
                          @Simon-James-Hancock I think @steve-jarrell has explained how to deal with a missed via point on a Garmin device. But to be clear about the positioning of your first waypoint. I’m not familiar with the hotel where the route starts from, but let’s say that you leave from where I have placed the red cross, this is clearly in front of waypoint 1 which is why you are sent back. Better to position the start point where waypoint 2 is.
                            Steve Jarrell
                            Steve Jarrell
                            Steve Jarrell
                            #49
                            @Nick-Carthew Yes, and I would add for @simon-james-hancock's information.... there's absolutely no need for the Waypoint 2 (via point) in this route. A via point means to MRA and to the Garmin unit "I really want to stop here or go past this particular point", and that's clearly not the intent in this route.
                            If you're trying to force the route in a certain direction you should use a shaping point, not a via point. If you need help in understanding the differences there are a LOT of really good threads here, and help documents here that explain the differences and their pros and cons.
                            The bottom line is that this is a self-inflicted problem (I'm not criticizing.... I've done it myself) that can easily be avoided as @nick-carthew pointed out by the proper placement of the starting via point, and the proper use of via points vs shaping points.
                            The question shouldn't be "How do I skip my initial starting point after I skipped it?" but rather "Where should I place my initial starting point to avoid navigation issues?".
                            Steve Jarrell
                            2025 BMW R1300GS
                            2025 Can-Am Spyder
                            Garmin XT3
                              Simon James Hancock
                              Simon James Hancock
                              The Hotel is my place where I started from. I will Place the start point where via point 2 is and try that.
                              After having read many of your articles on the subject I came to the conclusion that in order to make sure that the route passes over a certain section you have to use via points and that shaping points can be skipped by the navigation device. If I want to put a petrol station on the route for reference but mot necessarily to stop do I make it a via point or a shaping point?
                              Thanks for the help.
                                Simon James Hancock
                                Simon James Hancock
                                I have also only placed the points I want to stop at as via points and changed all the others as shaping points. I will give it a go this afternoon.
                                  Simon James Hancock
                                  Simon James Hancock
                                  wrote on last edited by Simon James Hancock
                                  #52
                                  Ok , I have just come back from a test ride where I had one Garmin xt and one Garmin xt2 connected to the bike.
                                  On the Xt i loaded 1.1 file and the Xt2 a 1.2 file Obviuosly both the same route.
                                  Both routes had the first and last points as via points and all the others were shaping points.
                                  After placing the first via point further down the road from where I started both units came up immediatly with a messag if I wanted to recalculta the route. I said no to both of them. As soon as i reached the first via points both units navigated successfully my loaded route.
                                  However when I stopped and turned the bike off and the units off for a drink at a bar on the route and then turned them back on again I had problems carrying on back along the route. I have to point out that the route is an out and return along the same road.
                                  Any suggestions on how to get back on the route after stopping?
                                    Steve Jarrell
                                    Steve Jarrell
                                    Steve Jarrell
                                    @Simon-James-Hancock Use via points for any spot where you want to either stop OR pass by. They basically mean "unless I manually skip this point go to it". I think of them as "mini destinations" on my route. On the Garmin after you press "Go" you can use any one of these via points as the starting point of your route.
                                    Shaping points are just that.... they shape your route, and if you do get off route for any reason and do go past them you do not have to skip them manually and you won't be routed back to them. In other words, they're not mandatory points in your route like via points are.
                                    With .gpx 1.1 you have to use a LOT of shaping points to ensure that the route that the Garmin calculates is the same as what you're seeing in MRA as the Garmin uses it's own logic to route (fastest, shortest, etc.) between the via and shaping points.
                                    With 1.2 MRA creates a track that's included in the route information which forces the Garmin to ignore its own logic and follow the route exactly as you intended.
                                    I personally use Via points to indicate the points that I don't want to bypass unless I manually skip them, and I use shaping points to shape the route. When I am happy with the route that I see on my computer screen, I export it in 1.2 format, import it into my Garmin and the route will be JUST LIKE it was in MRA.
                                    Steve Jarrell
                                    2025 BMW R1300GS
                                    2025 Can-Am Spyder
                                    Garmin XT3
                                      Simon James Hancock
                                      Simon James Hancock
                                      Thanks Steve that is all clear now.
                                      On an out and return route in order not to have any problems when restarting the route is it best to put a few via points that you can use to get started in the right direction again, and if so how to you tell garmin to go to a selected via point?
                                        Steve Jarrell
                                        Steve Jarrell
                                        Steve Jarrell
                                        @Simon-James-Hancock I replied earlier that you'd need to stop the route then restart it to skip the first via point. That's not completely true.... I hereby correct myself! 🙂
                                        On the bottom right corner of the Garmin you'll see three lines. Press this area and it will bring up a menu that will allow you to skip the next via point. On my Garmin 595 there's simply a "Skip" option on that menu, and on my XT3 there's an "Edit Route" option that will allow you to select a "Skip Next Destination" option. It may be a little different on your Garmin but you'll find it.
                                        I haven't ever used this option myself (hence the reason why I forgot that it was even there) but based on my testing here it looks like if you're not on your route already and you delete the next via point that the Garmin then uses its own logic to get to the following via point.
                                        I'm ASSUMING (but I very well could be wrong, so I'm going to test it for myself and verify) that if you are on your route and you simply skip the next via point that the Garmin will continue to follow your desired route. That's easy to verify if you're showing your route and track simultaneously, and you can also watch and see if your distance and / or time changes when you make the change.
                                        Perhaps someone with more experience skipping via points with the Garmin with the 1.2 .gpx format can verify or refute my assumption. I will report back with what I find.
                                        Steve Jarrell
                                        2025 BMW R1300GS
                                        2025 Can-Am Spyder
                                        Garmin XT3
                                          Simon James Hancock
                                          Simon James Hancock
                                          #56
                                          Ok I have just managed to find the Skip option on my Xt2 under edit. I also made my tracke wide and yellow to make it visible when navigating.
                                          I am trying to get the hang of this before I take the wife on the bike to Marocco in September. The My Route app is fantastic for planning everything. I just don't want to be faffing around trying to find out what to do when I am there.I have a friend coming with his Nissan pickup and I will give him my XT. He is even less of an expert than me and I was thinking of loading just a track for him to follow, to make it easier if we get seperated.
                                          As I will not be connecting the Garmin to my phone or headset I could just use a track too, what do you think?
                                          Simon-James-Hancock said in GPX Versions 1.1 vs 1.2 for Garmin Visually Explained:
                                          g![alt text](image url)725574430_10241779165406180_6164259261667789319_n.jpg
                                          Mzokk Steve Jarrell 3 Replies Last reply
                                          • 4
                                          • 5
                                          • 9
                                          • 10
                                          Stevedo 6 0
                                          Stevedo 6 0
                                          Andy Beviere
                                          Andy Beviere
                                          smfollen 0
                                          smfollen 0
                                          Will Brooks
                                          Will Brooks
                                          Steve Jarrell
                                          Steve Jarrell
                                          Carl Lee
                                          Carl Lee
                                          Simon James Hancock
                                          Simon James Hancock
                                          Phil Ellis
                                          Phil Ellis
                                          Jim Foster
                                          Jim Foster
                                          Sam Ellis
                                          Sam Ellis
                                          Papasmurf2
                                          Papasmurf2
                                          OkayJim
                                          OkayJim
                                          • Webapp-icoon
                                          • My feedback on the AI planner
                                          • Trip - 🌙 Where do you sleep?
                                          • Groeten uit Alphen aan den Rijn
