  3. Why Won't MRA Follow the Beartooth Highway
9 Posts 5 Posters 107 Views 2 Watching
  • Sam Kramerundefined Offline
    Sam Kramer
    wrote last edited by
    I can't figure out why MRA is not allowing me to make a direct route entirely along the Beartooth Highway from Red Lodge, MT, to Cooke City, MT, and including the portion in Wyoming. I can only guess that MRA knows there is a road closure which doesn't allow the direct path. I created this route about two months ago, and back then, MRA did follow the Beartooth Highway, but today it does not.
    I can not find any road closure information on the MT or WY DOT websites.
    Any ideas?
    Sam
    • Sam Kramerundefined Sam Kramer
      Any ideas?
      Sam
      Nick Carthewundefined Offline
      @Sam-Kramer In the overlay maps select the traffic overlay and zoom into the area of road that the map will not route on. If there is a red/white line this indicates a road closure. You could try turning on the Disable seasonal closure tool in the toolkit if you are using the planning map from HERE.
      Stevedo 6 0undefined 1 Reply Last reply
        Stevedo 6 0undefined Offline
        Stevedo 6 0
        I just tried the suggestions. There are no road closures indicated. Neither the Montana (https://www.511mt.net/#zoom=7.550255906688425&lon=-109.13842246235015&lat=45.015493985482095&events&road-cond&rwis) or Wyoming (https://map.wyoroad.info/511-map/) departments of transport report closures on Beartooth Pass (US Highway 212). Turning on Disable seasonal closures does allow routing along the Beartooth Pass which is confusing because the road is usually open from the end of May to some time in October. I assume that this is a HERE maps issue.
        Nick Carthewundefined Brian McGundefined 2 Replies Last reply
        • Stevedo 6 0undefined Stevedo 6 0
          @Stevedo-6-0
          I was able to route on the Beartooth Highway without using the Disable seasonal closure tool, I just added some extra route points.
          LennyOundefined 1 Reply Last reply
            Brian McGundefined Away
            wrote last edited by Brian McG
            @Stevedo-6-0 said: I assume that this is a HERE maps issue.
            Use the "Compare" tool & you will see that TomTom & OpenStreetMap route without a problem
            I would then go to Google maps & simply try to route from Red Lodge to Cooke City
            If Google, TomTom & OpenStreetMap say its passable, then you can be pretty confident you are correct in saying yet again the Here map data is bad
            In this case the Here map data seems to only be bad / out of date for MRA as the HereWeGo site seems to route through with no issue
              @Stevedo-6-0
              LennyOundefined Offline
              wrote last edited by LennyO
              @Nick-Carthew Nick, that's interesting...
              As soon as I saw the post come out, I tried to create the same route and it would not let me. I started adding waypoints and found 2 spots where it wanted to create a bypass. (WP6-WP7 and WP8-WP9)
              One of the roads to be used as a bypass was seen as blocked by the gate on Street View (WP8-WP9).
              I did not disable seasonal closures, of course and no avoidances selected.
              I also searched the Internet and was not able to find any closures posted anywhere.
              TomTom and OSM Navigate straight thru the bypasses on HERE.
              https://www.myrouteapp.com/route/open/14020487
              So, I wonder what made you able to do ut without a problem...???
              You must have this thing in total submission to you! 🤕
              I noticed that you did your route on the phone, so I thought hmmm... maybe that's where it is somehow different. So, I just tried my phone and encountered the same issue as on the Route Planner.
              • LennyOundefined LennyO
                Hi @Lenny-O it is not magic, it is just old / out of date map data
                I think the Here map data that MRA is using for this road still has its winter setting, so it set as closed
                if you try to route along this road it will always try & look for an alternative that is not set as closed
                at your points WP6-WP7 and WP8-WP9 there are alternatives, even if they are not practical because of gates etc, & the Here routing opts for the alternative that is not closed rather than the closed road
                you can make it route along the closed road between WP6-WP7 and WP8-WP9 just by adding additional points
                  @Brian-McG You are correct!
                  I was able to force it to go straight thru by adding waypoints!
                  But that brings in another interesting point.
                  I know for sure that when HERE knows some road as "closed", there is no way you can force it to use it, no matter how many waypoints you try and add, unless you activate "disable seasonal closures".
                  So, the fact that by adding more points I am able to force it to stay on tells me that these spots are NOT designated as "closed" on HERE maps.
                  Then, in this example Bear Tooth is the main road and with no avoidances selected why in the world would the HERE algorythm start taking you off the main road?
                  What am I missing here?
                    @Lenny-O-R-Xpert I think it depends on how the closure is set in the map data
                    sometimes a closure can be set as a single point on the road like a waypoint, other times it can be set as hundreds of points more similar to a track
                    the routing algorithms are not that clever, it is just a case of is this path greater than or equal to the alternative path
                    if a closure is set as a single point you can fool the algorithm into routing past the closure by placing your waypoints near/close to the closure point so the calculation is approximately equal to or shorter than the alternative path
                    if the closure is set like a track you would need to add hundreds of waypoints to overcome all the points in the closure
                    another way to confirm if a route is actually passable & prove that the Here map data is poor/bad is to turn on the "Traffic" data & zoom close in, you get a nice green confirmation that the route is open / flowing
                    LennyOundefined
                    Stevedo 6 0
                    Sam Kramerundefined
                    Sam Kramer
                    • Why Won't MRA Follow the Beartooth Highway
                    • inconsistent travel times
                    • Compass is not working properly
                      Thomas Schäferundefined
                      Thomas Schäfer
                    • Updated beta! 5.2.1 (486)
                      white.mouseundefined
                      367
                      PieterGundefined
                      PieterG
                      7.3k
                    • Creating routes on HERE versus TomTom
                      Will Brooksundefined
                      Will Brooks
                      295
                      M. Schrijverundefined
                      8.0k
