  4. Na 5000km MyRoute-app: helemaal klaar met deze Bugware
36 Posts 21 Posters 3.6k Views 8 Watching
  • Massimo Cardone
    Massimo Cardone
    Massimo Cardone
    No system is perfect, and I’ve tried out various sat-nav devices and software, from TomTom to Garmin Zumo, from Kurviger to Calimoto, and so on.
    And I have to say one thing: MyRouteapp is the BEST of them all.
    Planning on the PC is simply sensational, with the various maps and map layers. I could write so much more. I’d just like to give a big shout-out to the MyRoute team here.
    The fact is that my problems started after the update to 5.1.0-462. I’ve described them objectively in this post: https://forum.myrouteapp.com/topic/11068/issues-since-the-5.1.0-462-update-crashes-and-lag/21
    Sometime around 11 June, there was another update (5.2) with brilliant new features. The problem is that a friend of mine was on the road from 6 June to 27 June and was able to test the MRA extensively, including the new update to 5.2.
    Although the crashes have become less frequent, they’re still happening and they’re just plain annoying. Above all, this always happens when you least need it – in heavy traffic, rather than on the motorway or anywhere else where the next junction isn’t for another 10, 20 or 40 km.
    I used to have practically no problems. The issues started for us (me and two friends) from update 5.1.0-462 onwards. Do read through the post. And we use different mobile phones running Android and iOS. That can’t possibly be a coincidence.
    The navigation should run smoothly wherever possible. I need to be able to rely on it. It’s quite possible that some people really don’t have any problems, but if you read the various replies to my post, it’s clear that quite a few people are affected.
    And following my post, other threads were started reporting similar issues: crashes and tracklogs not being recorded.
    Kind regards,
    Massimo
    Translated with DeepL.com (free version)
    • ATLast
      ATLast
      ATLast
      wrote on last edited by ATLast
      #21
      I understand your frustration—I've had my share of problems with the app in the past, see my posts in this forum—but I think your opinion, probably written in the heat of the moment, is a bit excessive: the program has indeed improved significantly.
      I also notice that we probably use it in the same way—as a route planner from point A to point B—and that doesn't seem to be how most users use it. When I go on a trip, I don't plan the whole trip on the website but set a destination for the end of the day and let the program do its job. I want the flexibility to visit places that aren't on the itinerary but that I find appealing.
      This requires recalculating the route, which is still not the app's strong point, even though it has also improved considerably, thanks to the developers.
      And the recalculation problem is amplified when the internet connection is weak or nonexistent: unfortunately, it's often impossible to change this while driving because you don't always notice it, and it's not always easy to stop and switch to offline mode. From my past experience—though I haven't tried this in a while I must say—offline mode has never helped me; otherwise, I would always travel "offline." For your information: I download maps of all of Europe and take care to keep them up to date.
      I adjusted the route calculation by enabling all the avoidance options, which the app seems to handle less well than before: I too have been sent onto a highway, through a village to avoid 400 meters of main road, or via a parking lot… I also find that here in Belgium, the program makes much less effective use of smaller roads than in version 4: there are also fewer winding road options (3) than before (5). And the difference between level 2 and level 3 is, most of the time, imperceptible.
      A few weeks ago, I took a 2200 km trip in France, and the app worked very well: almost no crashes, and I was able to cross France to and from the Dordogne region with very few two-lane roads. This might even require extra attention because, in rural France, there are very few places to refuel.
      Did you specify what type of phone, system, and Android Auto/CarPlay connection you're using? It can also affect how the app works or behaves.
      As for me, and I've been a user since version 1 of the program, I'm confident that with a little more patience, the app will have eliminated the biggest flaws that sometimes affect my journeys. I don't just use it when traveling, but also in Belgium: I've already discovered many places that were previously hidden from me.
      I've already tried other apps: OSMand, Calimoto, etc., but none of them appealed to me because they all offer far fewer features than MRA. And while it's true that the menus are sometimes unclear, with practice you get the hang of it. It's also important to remember that the complexity of navigating the menus is partly due to the sheer number of options available.
      In any case, if you find an app with as many features that works better, please let me know.
      Ride safe.
      • Marinus van Deudekom
        Most of the problems start with users that use CP & AA. Do you use one of them.
        If that's not the case Create the logfiles by long pressing in the version number and send them with a ticket so the devs van have a look at it.
        If you are using CP & AA, it one of them. Some users dont experiance problems, me for instance, and others do. Depending on their configuration of is minor of major.
          Had just a frustrated experience. It was a sum of things. Not all can be lead back to MRA. But the behaviour of MRA frustrated me the most
          Currently I'm on holiday in Ireland. That means little knowledge how the traffic flow in Ierland is build . I was on the M4 heading Dublin. The idea was straight through Dublin. It was a pre-planned route with multiple points in Dublin. But because the directions MRA gave me and the lack of knowledge of the road structure. I landed on the M50. This was my starting point of my frustration. And once on the wrong highway. Turning back is not an option. But the recalculation tries to go back to the missed waypoint. Which is normal for MRA. But not logical in this situation. After some more wrong turns (also partially because of the given directions) and keep sending back to the missed waypoint (point 5). I was almost boiling of frustration. Finally I found a place to stop the bike and look at the route. Skipping to point 13 was the most logic thing to do to get back on the route.
          MRA is a good tool but there are situations where things are getting meshed up pretty well.
          Just like some other postings tell. MRA is good but not flexible enough. At least that is my opinion.
          • Herman Veldhuizen
            #24
            @PieterG is niet er diplomatiek maar heeft natuurlijk wel een paar issues. Waar ik het meeste van schrik zijn de reakties van de "experts" hier. Waarom vraag ik mij af . De app is niet van jullie als ik het goed begrijp. Dus geen reden om terug te blaffen. Het eninge wat hier mee bereikt wordt is schade aan de reputatie van de app.
            • Mzokk
              There are so many configurations with different phones different OS's and now different AA and Carplay capable devices and vehicles. I use the app in three ways Via AA on my Honda Africa Twin. Via AA in my VW ID3 and as a native app on the phone in my wifes Mazda MX5. I generally use the same phone and don't use the tracklog facility (I still have my ZumoXT mounted on the Honda and use this for tracks and proximity alerted poi's) I always navigate "Offline" with loaded maps and use one Motorola phone in all cases. I tend to follow pre-planned routes (if I want A-B routing I use google maps). For the 18 months I have used MyRoute app as my primary navigation tool (taking over from the Zumo XT which is used as a backup) and can honestly say that I have not had an issue with crashes or the app failing to restart navigation after a break during that period. That includes leading 4 multi day trips In Scotland and France during the period and using the app on the Canary Islands in a hire car. During multi day bike trips I tend to put in optional loops that get bypassed if time becomes pressing (which it can with 6-10 riders) and skipping these has caused no issues) So I don't use the app online or for A-B journeys or use "curvey" routes created by the app. So if these things cause issues I'd never know.
              ATLast 1 Reply Last reply
              • Cleo
                wrote on last edited by Cleo
                #26
                Wel apart dat iemand zijn ervaringen beschrijft en de app niet vindt bevallen dat de hele horden zich op de boodschapper richten en deze bijna afbranden en Myrouteapp flink beginnen te verdedigen. Je hoeft niet eens te zijn met de ervaringen van een ander maar dan zeuren over de toon van het bericht omdat er kritiek op de app wordt gegeven siert de rest ook niet, ga gewoon op de inhoudt van de boodschap in.
                En ja Myrouteapp wordt beter maar is nog niet perfect.
                Verder heb ik zelf met een recente tocht naar en door Frankrijk toch redelijk veel problemen ervaren, zoals het crashen waar de app helaas niet verder gaat waar gebleven en me weer terug stuurt naar WP1 en ik weer langs de kant moet staan om weer op WP's doorklikken moet drukken
                Ook lijkt er een geheugen lek te zijn omdat na een dag de app actief te hebben gehouden de presentatie op het scherm van de kaart in het geheel verdween en ik fijn naar een wit scherm met een blauwe pijl keek en ik niet kon stoppen om te herstarten.
                En zoals bij vele navigatie app, dus NIET uniek voor Mrouteapp, vindt ik de getoonde informatie vaak te groot en daar door teveel real estate innemen van het scherm terwijl de icoontje op de kaart in de standaard instellingen weer te klein zijn, de ikoontjes kan ik oplossen maar de grootte van de informatie niet,
                Ik kan me voorstellen dat mensen emotioneel reageren als ze vertrouwen op 1 app voor een tocht, ik heb door schade en schande altijd meerdere navigaties bij me.
                Vooral in bergen en bij slecht ontvangst van mobiele data en slechte GPS door een dicht bladerdak of smalle kloven wordt je niet vrolijk met navigeren met een mobiele telefoon.
                En het rigide gedrag dat een WP precies op de weg moet staan of juiste weghelft is nog steeds een onprettige ervaring, een acceptatie cirkel om een WP moet toch mogelijk zijn of de gebruiker helpen om aan te geven dat een WP verkeerd is geplaatst.
                Overigens heb ik geen warme mobiel ervaren en kon de hele dag rijden op een acculading. Nieuwste versie van Myrouteapp.
                • Gerard Wullink
                  Gerard Wullink
                  Gerard Wullink
                  @PieterG: Niet om vervelend te doen, maar waarom was je ook alweer overgestapt op MRA? Vast niet omdat Garmin zo prettig werkte. Mijn ervaring is dat als je de problemen goed kunt duiden, je het beste deze gewoon kunt melden. Je weet immers precies wat er niet goed ging en waarom. Dan draag je bij aan de verbetering. Er wordt echt naar gekeken. Anderzijds is het inderdaad wel zo dat navigatie niet zo simpel is als het lijkt. Misschien is een kleine basiscursus inderdaad niet gek, maar ik snap je frustratie ook wel. ik heb ook met Garmin gereden.
                  Cleo PieterG 2 Replies Last reply
                  • Mzokk Mzokk
                    ATLast
                    ATLast
                    ATLast
                    Hi.
                    No! Google Maps doesn't allow you to avoid residential areas, main roads, unpaved roads, etc;..
                    MRA does that.
                    Bu the way, I also use the Zumo XT as backup system and its "adventurous route" option are way less efficient than MRA.
                    Thanks for sharing anyway.
                    • Gerard Wullink Gerard Wullink
                      #29
                      Een van de beste reden lijkt me dat Garmin navigatie als LCM beschouwd en er weinig energie meer insteekt en om die reden er mensen overgestapt zijn naar oa MRA als alternatief.
                      Als Garmin toekomst had gezien in navigeren was Basecamp onderhouden, Explore is toch anders en hadden ze elk jaar nieuwe navigaties uit gebracht,
                      Kobutex Motorreizen 1 Reply Last reply
                        @M.-Schrijver said:
                        Navigatie software is er voor jou. Niet andersom. Dat is wat @pieterg eigenlijk zegt.
                        Dat komt dan anders behoorlijk rot z’n strot uit!
                        Banned
                        Nee @rob-verhoeff!!! Dat is precies zoals het is. Navigatie software moet voor jouw werken en niet andersom!
                        Je maakt een route, laad het in de tool en dan moet je van A tot Z geen enkel ellende mee hebben of onderweg weer van alles moeten aanpassen.
                        @m.-schrijver zegt het precies zoals het is..
                        • PieterG PieterG
                          Ongenuanceerd? Ik kan mijn ervaringen stuk voor stuk reproduceren en documenteren hoor. Lees nog maar eens, maar dan goed; het zijn gewoon voorbeelden van hoe dingen (fout) gaan en die 5000km ergernis, die ik met andere producten niet had, had ik me inderdaad kunnen besparen door MRA niet aan te schaffen.
                          Er zitten echt ontwerpfouten in die op basis van hedendaagse softwareontwikkelingsmethodieken nooit tot een release zouden zijn gekomen. (laat staan het niveau 'Gold' kunnen waarmaken) Rechtpraten wat krom is, staat gelijk aan ontkennen wat mij betreft: dit product is empirisch aantoonbaar verre van stabiel en consistent.
                          Hulp heb ik niet nodig maar dank voor je toegankelijkheid. Na 5000km MRA, staat mijn keuze vast.
                          Edit: nog een feitje, de app klapt er 6 tot 8 keer per dag uit en dat is de afgelopen 3 jaar zo geweest op meerdere Android en iPhone toestellen (en ik ben de enige niet die dit meld)
                          Banned
                          @pieterg
                          Trek je maar niks aan van die zelfingenomen en zelfbenoemde MRA goeroes.
                          Die zitten liever op een roze wolk MRA de hemel in te jubelen in plaats van de eind-gebruiker op z'n woord geloven.
                            Gelet op alle berichtgeving in deze post heb ik niet het gevoel dat hieraan deelnemen nog productief kan zijn voor wie dan ook.
                            Als de beheerders de post niet sluiten, beschouw ik hem voor mezelf als gesloten en zal hem ook niet meer openen
                            Mocht je nog naar mij willen reageren, zoals altijd reageer ik op chat berichten
                            Have fun
                            • Cleo Cleo
                              Kobutex Motorreizen
                              Kobutex Motorreizen
                              Kobutex Motorreizen
                              Garmin heeft net na de Motorbeurs de Zumo XT3 uitgebracht in 2 varianten, dus Garmin ziet daar wel degelijk toekomst in. Ook is het zo dat Garmin met Garmin Explore meer de kant op gaat van Tracks
                              • PieterG
                                PieterG
                                PieterG
                                wrote on last edited by PieterG
                                #34
                                Halo allemaal,
                                Bewust heb ik een paar dagen afgewacht wat er zou gebeuren na mijn post.
                                En ja, die was -ook bewust- behoorlijk ongezouten. (hier kom ik onderaan op terug)
                                Ik constateer het volgende:
                                • Er zijn mensen die zeggen tevreden te zijn met MRA. Ik geloof dat zeker!
                                • Er zijn ook mensen die zich op punten herkennen in mijn ervaringen. Waarvoor dank!
                                • Er zijn mensen die reageren op de man, i.p.v. de bal...
                                • Er zijn mensen die op tamelijke hautaine manier reageren (burrrp)
                                • Er zijn mensen die mijn competenties in twijfel trekken
                                • Er zijn mensen die niet goed lezen en vervolgens een 'verkeerde afslag pakken'
                                • Er zijn mensen die aannames doen, zonder wederhoor
                                • Er zijn mensen geen kritiek op MRA verdragen en alles recht willen praten
                                • Er is zelfs iemand die aandringt bij de beheerders om deze post te sluiten... (Wat op mij overkomt als politiek gedrag van een bepaalde kleur: wat niet zint, wil men niet of anders horen.. Oeps daar ga ik weer)
                                • Niemand vroeg mij naar mijn set-up. (iPhone, Carplay, Ridernav R7M)
                                Nu de uitleg waarom ik deze provocerende post heb geplaatst.
                                Een tijd geleden heb ik posts geplaatst die gingen over het gebruik van MRA met Android auto en een Chigee AIO5 en verschillende Carpuride modellen. (Dus destijds: geen iPhone en geen Carplay)
                                Toen gebeurde, in zekere mate, het zelfde als deze keer: Het was niet waar, of het lag aan mij.
                                Er was zelfs een goeroe die beweerde dat een Chigee/Carpuride niets meer was dan een spiegel van je telefoon. (Die ging dus even in al zijn 'deskundigheid' voorbij aan het feit dat Android auto en Carplay tamelijk lastige integratieplatformen zijn tussen twee architecturen waar app-ontwikkelaars mee moeten worstelen.)
                                Destijds werd ik ook niet serieus genomen in mijn kritiek en de stelling dat MRA i.c.m. AA en ongeacht type 'head unit' totaal onbruikbaar was... Maar man man man, wat had ik gelijk - zo is later gebleken. Want er waren nog vele stappen nodig om het te brengen waar het nu is.
                                Mijn dank gaat uit naar de reageerders die wel in staat waren om goed te lezen, te begrijpen en op de bal te blijven spelen en ook hun eerlijke kritiek hier durfden te uiten.
                                Zo, dit gezegd hebbende zou ik er geen bezwaar tegen hebben dat mijn post nu wordt gesloten 😉
                                  PieterG
                                  PieterG
                                  PieterG
                                  #35
                                  @Gerard-Wullink Garmin? Wie had het over Garmin? 😉
                                    @pieterg Dan is dit het moment dat ik ook maar even wat zeg voordat ik de topic sluit 🙂
                                    Bedankt voor de feedback! Ik heb de app afgelopen tijd ook zeer intensief gebruikt en daar weinig problemen ondervonden. Ook hebben we gelukkig erg veel gebruikers die het zonder problemen kunnen gebruiken. Dat is niet vreemd want anders hadden we ook niet de beoordelingen die we hebben en de hoeveelheid gebruikers.
                                    Dat gezegd hebbende, daar heb jij niks aan! Dat begrijp ik ook.
                                    Mocht je de app nog willen gebruiken, maak dan gerust een support ticket aan als je problemen tegen komt. Wij zorgen dan dat daar naar gekeken wordt.
                                    CarPlay en Android Auto blijven een grote extra factor van complexiteit. Daar ben ik daadwerkelijk ook nu weer direct na mn vakantie weer mee bezig. We hebben de ambitie om op alle platformen perfect te functioneren.
                                    Jouw toon bij het begin van het bericht helpt niet, dat moet ik bekennen. Dat maakt je verdere valide punten en terechte feedback helaas minder sterk.
                                    De reacties van enkele community mensen is dan ook weer niet direct nodig.
                                    Maarja, zo gaat dat soms.
                                    Ik ga dit topic sluiten.
                                    Mocht je nog de behoefte hebben verder contact te hebben, stuur dan gerust een bericht via het forum. Voor concrete problemen verzoek ik je vriendelijk een support ticket aan te maken.
                                    Mocht je het nog eens willen proberen dan hoop ik dat toekomstige updates ook jouw problemen oplossen. Ik ben er echt mee bezig!
                                    Kobutex Motorreizen
                                    Kobutex Motorreizen
                                    PieterG
                                    PieterG
                                    Massimo Cardone
                                    Massimo Cardone
                                    Gerard Wullink
                                    Gerard Wullink
                                    ATLast
                                    ATLast
                                    Eric Bovelander
                                    Eric Bovelander
                                    • Statement on map spinning
                                      hawebo
                                      hawebo
                                      18
                                      25
                                      1.7k
                                    • New beta! 6.0.0 (514)
                                      Stanisław
                                      Stanisław
                                      188
                                    • Feature request to change colour of the route-line in My Route Web
                                    • Electric Car Travel Mode
                                    • MRA 6.0.0 (515) Night mode
