  4. Black screen during navigating
6 Posts 4 Posters 464 Views 2 Watching
  • Ed Lauwerens 0undefined Offline
    Ed Lauwerens 0
    I am using MRA (latest version) with Apple CarPlay to a RiderNav 7, now travelling in Norway.
    In general all works fine, but once in a while the MRA screen turns black, that is, all buttons are shown, the CarPlay menu on the left side of the screen is shown as well, but the rest of the MRA screen is black. Other applications function ok, so this seems to be an MRA specific issue. Shutting everything down and restarting and all is fine again. This happens once a day. Does anyone recognise this and knows what to do to prevent this, or is it a bug?
    • nomkoundefined Offline
      I sort of recognized the issue and knew there were some topics in the past about this that might give you an answer:
      https://forum.myrouteapp.com/topic/3528/zwart-scherm-in-peugeot-2008
      https://forum.myrouteapp.com/topic/10733/zwart-scherm-here-kaart
      https://forum.myrouteapp.com/topic/10715/carpuride-zwart-scherm
      | MRA Gold Member |
      | MRA Next + Kawasaki Z650 |
        Ed Lauwerens 0
        I get the feeling it has to do with zooming in and out. If I enter the button right under, the buttons with + and - appear. If I leave it this way and zoom in and out every now and than, sometimes the map turns black (buttons still visible). But if I leave the zoom-mode, the problem does not seem to occur
        • Ed Lauwerens 0undefined Ed Lauwerens 0
          Rob Verhoeffundefined Offline
          Yes, I also encountered that during the alpha test. I can no longer determine from the communication with the developers whether this has already been fixed in the public version. In the beta version that is currently being tested, I have not experienced it anymore. And since it is now the developers’ holiday period, it may take a while before a response comes in.
            Ed Lauwerens 0
            wrote last edited by
            I think I have the reason why this occurred as well as the solution. I was unaware of the possibility to download maps and run navigation in the off-line modus, using the downloaded maps. So whenever the on-line connection of my iPhone stopped, I guess the map on my CarPlay display went black. I have now downloaded offline maps for the countries I drive in and selected the option ‘navigate in offline mode’ and this black screen issue has not reoccurred. Case closed as far as I am concerned.
              Just to add:
              Offline maps and offline navigation are two seperate things. For offline navigation of course you need to have offline maps. Offline maps on the other hand are also used for online navigation (as a measure of data reduction).
              nomkoundefined
              Ed Lauwerens 0
              • Manual 'Compare Route calculation'
                Nick Carthewundefined
              • A few observations
                Thomas Miklundefined
                Thomas Mikl
                Herman Veldhuizenundefined
              • Hull to Rotterdam ferry not recognised
              • Color of Via points issue
                Peter Zehentreiterundefined
                Steve Jarrellundefined
                Steve Jarrell
                1.7k
              • Hoe een kaart met bepaalde plaatsen als POI aanmaken.
                nomkoundefined
