  4. Gas Stations not displaying
9 Posts 4 Posters 579 Views 2 Watching
  • Lenny Oundefined Offline
    Lenny O
    Hello, all!
    Would anyone have a suggestion or a fix for gas stations just not displaying at all when navigating a route.
    Neither on or off lline. The selector in the navigation options is turned on for that (green).
    It used to work before....
    I am on version 5.1.0 - 462 using Samsung s25 Ultra.
    Thank you!
    • Marinus van Deudekomundefined Do not disturb
      In settings activatiecode search after gasstations. (In functionel, navigating functions
      Lenny Oundefined 1 Reply Last reply
        Lenny O
        @Marinus-van-Deudekom Thank you, but as I had mentioned, it IS selected (green).
        • Lenny Oundefined Lenny O
          Hello, all!
          Thank you!
          Rob Verhoeffundefined Offline
          @Lenny-O It works on my Samsung S24 (Android 16). 4.3 km to the next gasstation... same build 462. Clean install??
            Lenny O
            wrote on last edited by Lenny O
            @Rob-Verhoeff Thank you!
            It did work before the last update.... Maybe will just re-install the app. When I do that, I guess I need to reload all the off-road maps, ha?
              @Lenny-O said:
              I guess I need to reload oll the off-road maps
              Yep...
                Yep...
                Lenny O
                @Rob-Verhoeff Reinstalled! Does it how you the Gas station when you click Navigate, but did not start moving yet? Thx!
                  @Lenny-O, It does not show permanently at all. As far as I know it only shows when one is around, ahead in the route and close to the route. I am not sure about the parameters though.
                    Lenny O
                    Opened a ticket....not showing while navigating šŸ˜ž
                    Lenny Oundefined
                    Lenny O
                      M. Schrijverundefined
                    • Request login credentials
                    • Veekeersinfo en omleiden
                      marko 11 0undefined
                      marko 11 0
                      Yannick_van_Vugtundefined
                      Yannick_van_Vugt
                    • New beta! 5.2.1 (480)
                      233
                    • New roads visible in Google map but not Garmin Here
