  4. Export waypoints to Google Maps on mobile
14 Posts 5 Posters 2.2k Views 4 Watching
  • BFG
    BFG
    BFG
    I use myrouteapp.com for creating storing and managing road trip routes. I have a lifetime subscription so I'd really like to keep using it. I have the MRA app on my android mobile, which allows me to access my stored maps.
    I use Google maps on my bike. I used to use tomtom, but I've recently switched. I like to use waypoints, so on tomtom I exported itn files rather than gpx. Worked perfectly, and I could do this on the road using a sdcard.
    So MRA > TomTom could be done in a few minutes.
    I'm seeking a similar workflow MRA > Google Maps. Which to my mind if all on the same mobile, should be super easy. But I can't find an option - hence my suggestion, can there be an export direct to google maps.
    I have tried the optional turn-by-turn navigation from MRA, but it's not for me. Will try again in the future. But even if that's good for me, I like to have multiple options.
    Brian McG Con Hennekens 2 Replies Last reply
    • BFG BFG
      unfortunately I do not think MRA > Google maps is going to work for you
      I used a similar workflow to you when I had a TomTom 410, it worked very well
      Google navigation is pretty much an start position A > destination B navigation system
      you can add in the odd Via point in Google maps but the system does not accept import of GPX/KML files that can be navigated
      I totaly agree with having a second back navigation option, I use MRA navigation as my main app & Osmand as the backup
      Osmand is clunky but it does function reasonably well
      • BFG BFG
        @BFG, What do you dislike about the MRA Route Navigation, and what do you like better on gMaps for a feature that it does not even have (scenic routing, navigating many route points)? Given the many features asked for in this forum, I do not understand what anyone could prefer on gMaps to be honest (besides A2B navigation that is).
        • BFG
          BFG
          BFG
          wrote on last edited by BFG
          The last time I tried the app, its instructions were completely wrong. I had it running in parallel with TomTom, and was testing it on a very well known route. No milestone / waypoints, just a single destination set. NN make 10 mistakes in the first 30 miles, telling me to take the wrong road each time. Many times I could see it wanted to take me into a car park, turn around and come out again. Stopped and double-checked destination and settings. Set it going also in parallel on my partner's phone. Set off again and it failed almost immediately. It felt like it was a pre-Alpha release. OK, I could keep it running in parallel, but then it was doing very strange things with the display which became a distraction.
          This was Mar last year. https://forum.myrouteapp.com/topic/8980/first-time-navigation-next-on-android-auto-strange-display-rotation
          I didn't try it again. If another free trial was offered I'd have given it another go after a few months.
          Maybe I should try again.
          • Marinus van Deudekom
            If you’ve that many faults it must have something to do with your navigationsettings
            • BFG BFG
              @BFG, Who is to say your TomTom didn't get it right all that time instead... 🤣
              I don't recognize anything you say...
              • BFG
                BFG
                BFG
                You asked. If you don't like the answer, it's not my problem.
                • Bouke Ent
                  does export route in kml not work with google mymaps.
                  BFG 1 Reply Last reply
                  • Bouke Ent Bouke Ent
                    BFG
                    BFG
                    BFG
                    It does! they come in as pins. Thank you. This is a step closer. There are android apps that allow navigation from My Map pins.
                    • Bouke Ent
                      is it not so that routes made in mymaps can be used in google maps... i am not in it but it is just a idea. you also can try kmz...
                      Bouke Ent 1 Reply Last reply
                        Bouke-Ent said:
                        is it not so that routes made in google mymaps can be used in google maps... i am not in it but it is just a idea. you also can try kmz...
                        • Bouke Ent
                          i use comaps when i use osm maps and that app uses kml or kmz. with import it is not always the same. so maybe export kmz will give better result.
                          • BFG
                            BFG
                            BFG
                            I have a workflow. AI tools will do this easily. Tested with both chatgpt and claude.
                            A prompt such as the following works perfectly, and loads to google maps navigation (not to google my maps), so turn-by-turn is working. It does this by creating a single URL containing lat-long co-ordinates. I've only tested with .itn but it will work with gpx etc.
                            The prompt I used is:
                            Please prepare a google maps navigation route, using latitude and longitude, and provide me with a re-usable link to the navigation, using the attached .itn file as a source
                            Also, prompted by this thread, I've decided to give NN another go and purchased a subscription.
                            • Bouke Ent
                              i do not use AI... the fun is half to play arround with routes and then try to find solution for navigation. it can be use off a lot of shaping points or use OSM but then use a OSM navigation app. sometimes i just use a track and then also NN but with some tracks it is better to use other app. i never use google maps for planned routes. for planned routes i use NN, Comaps(track), osmand (osm) and komoot for walking or bike. i am now also looking at bmaps, android app working alone with tracks and osm maps. As long as Here maps are supports the roads i use NN. If road support is better in OSM then i plan in OSM and export track to what ever i like to use.
                              BFG
                              BFG
                              • New beta! 6.0.0 (514)
                                peha
                                peha
                                801
                              • Using tracks
                                351
                              • Kan keuze voor voertuigbeperking worden ' onthouden' ?
                                Kirsten De Weerd
                                Kirsten De Weerd
                              • Frozen marker.
