  4. How to Navigate Route as a Track?
38 Posts 11 Posters 9.5k Views 7 Watching
  • LennyO LennyO
    @Corjan-Meijerink Corjan, does the option to navigate a Route as a Track have anything to do with the Membership Level?
    Thanks!
    @Lenny-O no, definitely not 🙂
    • Thomas Neumeyer Thomas Neumeyer
      @Corjan-Meijerink I was sitting on the couch 🙂
      @Thomas-Neumeyer, that maybe, but you started the navigation module 😉 In cannot be changed while navigation is running.
      • LennyO LennyO
        Thanks!
        @Lenny-O, no, it does not. Its a just an extra feature of the existing subscription 😉
        • Martin Kjell
          Martin Kjell
          Martin Kjell
          Maybe I'm doing it wrong. But if I deviate from the route (as a track) with some shaping points, it still wants to reroute me back. I was stubborn and after around 10 km it told me it skipped that waypoint. Is it expected behavior. Tomtom for instance just tells me closest way back to the track in case I deviate.
          • Martin Kjell Martin Kjell
            @Martin-Kjell, Yes that's expected behaviour, if you keep being stubborn and don't follow the suggestion... 😉 What you need to do in such a case, is long-press your own chosen point of re-entry. Then it will guide you to there, insead of back to a point you obviously don't want.
            Martin Kjell 1 Reply Last reply
              Martin Kjell
              Martin Kjell
              Martin Kjell
              @Con-Hennekens Ok Thanks! But reading the manual states that shaping points will be ingored during "route as a track". And Waypoint (via points) is never ignored. A bit contradictaional to me, or (trying to be humble) I'm probably misinterpreting the instructions. In other words, route as a track does not seem to ignore shaping points.
              E.g. I would like to point out a route with say for instance 10 shaping points. But circumstances like weather, change of mind, road work etc. makes me pick another route and needed to ignore shaping point #4. Since Ive passed it I would no longer be interested in that one since it's just a shaping point. But MRA "Route as a track" tries to guide me back and after a few tries gives up. For me, theres no difference from normal route. What am I missing? Eager to learn and understand.
                But it does. Instead of leading you back to a shaping point, it leads you back to the track. Depending on the density of your shaping points and the layout of the roads, the difference can sometimes be not so obvious.
                The way you describe sound perfectly logical. Navigation will lead you back to the track, sometimes that can be through a previous route point, but that does not mean it took it into consideration. Since MRA is a scenic navigation app, it tries to have you drive as much of the preplanned route as possible and only skipps parts of it after multiple redirections.
                • Herman Veldhuizen
                  #21
                  MRA prioritizes points over the track (or route), also if the point is (just) a shaping point and you have specified that you want to use all points. So it sends you back if you missed one, even if you are already back on the track.
                  Corjan wrote this about the release following 5.1 (and I hope that a solution for the issue above will be found, as it is my biggest issue):
                  • Rework some internal algorithms such as searching for fuel stations and skipping waypoints
                  • Generic track navigation improvements
                    This is inherently wrong. Back on track, is back on track and no sending back to missed shapingpoints. This is very confusing for users.
                    You are deviating and you're guided back to the track/route. When you're near the route you see the blue routeline on the crossing ahead but it goes in both directions (left and right). The navigation tells you to go right. But why is the blue routeline also going left?
                    But okay, I turn right and after a mile I reached a shappingpoint. Then the navigation tells me to turn around and go back. So taking the left direction was the right one after all. What was the point to send me back to that point?
                    Did i miss something, besides a shapping point?
                    A must see?
                    A basic principle of a shapping point it shapes the route nothing more and because of that it is allowed to be missed. The navigation should use this principle and not sending me back to a missed shapping point.
                    MotoCon coupe_vs 2 Replies Last reply
                      A must see?
                      @M.-Schrijver, we are not starting that discussion again.
                      coupe_vs 1 Reply Last reply
                      • LennyO
                        #24
                        I think at this point there is still no clarity in understanding the process and setting the expectations. Maybe a good detailed write up from the mothership is in order to cover all the questions asked and clarifying misunderstandings.
                        I navigate route as a track and have had situations where my next way point is North of me, so I should turn left at the intersection, but the Nav sends me to the Right (South) just to do a U-turn a mile down the road (at the SHAPING POINT I MISSED) and then head North to the next way point. That is wrong no matter how you look at it. A Shaping Point should not be forced so hard, right?
                        Of course I can long press the next way point and get around the issue, or skip the one I missed, but should I have to do that?
                        Using Navigation should make my life easier, not to be second guessing every instruction it gives me to see if it still makes sense.
                        Agree / DIsagree?
                        Thank you!
                          A must see?
                          coupe_vs
                          coupe_vs
                          coupe_vs
                          @M.-Schrijver I completely agree with you... we're talking about the same issue repeatedly in several different posts on this forum, and they all boil down to the same question from users... why does it redirect to previous points that are just passing through (not mandatory stops)...?
                          (As you mentioned, hopefully these things will be fixed in the next update)... it's essential that a navigation system takes you forward on your route as a general rule... and only as an exception should you select to be taken to a previous point on the route you've planned...
                          • LennyO LennyO
                            Agree / DIsagree?
                            Thank you!
                            coupe_vs
                            coupe_vs
                            coupe_vs
                            @Lenny-O I completely agree with what you're saying... it's not normal to be using a browser and constantly be asked... (should I zoom out and press skip points) or wait?? I'm sorry, that solution could be much better
                              coupe_vs
                              coupe_vs
                              coupe_vs
                              @Con-Hennekens When several users in different posts keep bringing up this discussion again, it's for a reason... it's not just a coincidence... perhaps there are things that can be improved...
                              • LennyO
                                These discussions are a valuable tool for the development crew to get information.
                                All in all the product is the BEST on the market hands down, but we still need to appreciate the fact that it is a living and developing product, unlike most others who produce it and never improve it. There will be growing pains and they will eventually get resolved. Corjan an the whole crew are working very hard on the next release, which will be BIG! And, of course, priorities, priorities, priorities.
                                Coming from 40 years of IT back office programming servicing Wall Street I can totally relate. So, yes, some issues are frustrating at times, but let's all keep the positive attitude and feed constructive criticism down the pipe!
                                Ride on and smile inside your helmets, folks!
                                • coupe_vs
                                  coupe_vs
                                  coupe_vs
                                  I think the same as you... that we, the end users, can use this forum to give suggestions and contributions so that they can continue improving the best navigation app. With what we've discussed about starting the route forward here and in other posts, plus what other people on the forum have suggested for improvements in how speed camera notifications are handled, I would honestly be satisfied...
                                  • coupe_vs coupe_vs
                                    @coupe_vs, It is already explained many times why things are as they are. That's why I am not going into that specific discussion again. I have no doubt that when HERE adds track awareness to their platform, the MRA team will embrace it. Until then it is no use to keep bringing it up, especially by people who already know about it. This is one of those things that cannot be improved until HERE improves it.
                                    For the rest I completely agree with you. This forum is where many ideas have started. Some of my own. And that is certainly valuable and appreciated al lot by the dev team too.
                                    Is this meant as an analogy? I don't understand it.
                                    LennyO coupe_vs 2 Replies Last reply
                                      @Con-Hennekens Let's not get frustrated, my friend!
                                      We all appreciate your help in so many posts and so many ways! Great job!
                                      A couple of things I'd like to mention on the subject.
                                      • I, for one, had no idea that the issue really is with HERE until you just mentioned it above.
                                        My ignorance? Maybe... as I do not follow the Forum closely enough to be aware of many things, and I suspect many others do not either.
                                      • As MRA membership is growing and more people are using the product (Yay!) it is inevitable that the same questions will pop up. Even if new users read the manuals, check the Forum and most importantly REMEMBER and RETAIN the info from time to time they actually use the Nav.
                                      • So, MAYBE there is a way to make some posts with explanations a "sticky" or create a "Most popular questions" section and have the explanation of common issues placed there.
                                        This way you or anyone else trying to help out can just give the requester a link to the appropriate place with explanation.
                                      • Even if a user (new or existing) is doing their best to search for answers to their question in the Forum, unless the search criteria is worded "just so", there is a good chance that no answer will be found. (don't ask me how I know...)
                                      Hope I did not take too much of your time, folks!
                                      • LennyO LennyO
                                        @Lenny-O, it takes more than this to get me frustrated 😉 I understand that you (like most users) were not aware, but you were not targeted by my comment 😉
                                        Thanks for your suggestions. That's food for thought for the forum admin.
                                        LennyO 1 Reply Last reply
                                          @Con-Hennekens All good, my friend! Keep up good work! 👍
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          coupe_vs
                                          coupe_vs
                                          Martin Kjell
                                          Martin Kjell
                                          Volker Lattauer
                                          Volker Lattauer
                                          • Testroute segmenten
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            105
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Tegel Werner
                                            Tegel Werner
                                            Andy Smith 5
                                            Andy Smith 5
                                          • Lane view in Android Auto
                                            denWINNE
                                            denWINNE
