  4. unable to dismiss "Resume Navigation?" overlay with remote
5 Posts 3 Posters 429 Views 2 Watching
  • Andre Trudeauundefined Offline
    Andre Trudeau
    wrote on last edited by Andre Trudeau
    Hi,
    When I terminate a route and confirm, the "Resume Navigation?" overlay appears with the "No" and "Navigate" choices. In the past(a fair bit ago) it was possible to navigate with the Up/Down/Right/Left Arrow (Hat/Joystick) to this overlay to select a choice. Maybe it was highlighted by default and using the Hat/Joystick able to select one or the other option, I can't remember.
    As it stands now, the only way to select one of the option is by touchscreen.
    Is this a bug? Or could this be re-implemented if not?
    Thank you!
      This is not a bug. The remote is not meant to be a full substitute for screen operation. But you are right that it used to work in earlier versions (I believe prior to v5.x). To be honest, the flow for remote operation could be improved a bit. But as I understand developers, it is intended for basic operation like zooming, panning and the sort.
        Andre Trudeau
        Thank you for the quick reply.
        It would be a great addition at some point 🙂 Since we can pretty much do everything else with the remote at this time.
        Cheers!
          Guzzistundefined Offline
          @Con-Hennekens said:
          ...This is not a bug ... as I understand developers, it is intended for basic operation...
          yes @con-hennekens I have got the same answer by development - but I'm not happy about; I disagree. Because in the described situation, we now have to confirm twice. I understand why confirmation is twice - but it is still basic operation, if we want to stop a running navigation! So, I really want to get this developed to be operated by remote controller too.
          It's more secure to do this by a remote controller than by tapping on the screen, during riding.
          • Guzzistundefined Guzzist
            @Guzzist, I think if you re-read the rest of my comment, you will find that I agree 😉
            Andre Trudeau
            • erratic routing instructions
              215
              Peter Zehentreiterundefined
              5.2k
            • Adding a waypoint in the middle while navigating?
            • Imported gpx File has errors when converted to Here map.
              Rob Veermanundefined
              Rob Veerman
              Aiello antoninoundefined
              1.8k
            • Herberekenen werkt niet.
              Adrian Avramundefined
            • App stürzt bei aktiver Route immer wieder ab
            • Route opslaan op Pc vanuit telefoon MRA app
              AWDC LAOundefined
