  3. BDR Route GPX Support
9 Posts 6 Posters 1.6k Views 3 Watching
  • Kerry Lebelundefined Offline
    Kerry Lebel
    I was having trouble uploading the GPX file for the Southest BDR so I came to the forum to search for other posts on the topic. It looks like the last time this was addressed was almost 4 years ago. BDR routes are gaining in popularity significantly more every year. It would be a real shame to have to spend hours fixing an import that should be pretty straight forward. The GPX files work perfect in both Osmand and OnX. I haven't tried any other nav apps yet. While routes are awesome for onroad riding, the vast majority of offroad navigation is still via tracks, at least here in the US.
    Is there anything on the roadmap to improve the import functionality? I love MRA but find that migrating everything over has been painful. I will probably have to stick with OnX or Osmand for BDR routes which is a shame.
    You can see here the track imports but none of the waypoints.
    https://www.myrouteapp.com/en/social/track/883802?mode=share
    • Kerry Lebelundefined Kerry Lebel
      @Kerry-Lebel if you import a track in MRA it will never have waypoints
      If you share the gpx file I will try to help you out
      • Rob Veermanundefined Offline
        Rob Veerman
        For those who are not familiar with 'BDR'. It means Backcountry Discovery Route.
          Kerry Lebel
          This is still an issue. If we can figure out a way to address this is would be great. BDR's are extremely popular in the US. The GPX files that the organization provides has tracks and POI data for interesting stops and view points along the way. When you import the GPX file, it will convert the tracks into 'Route-Track' and the POI data is not imported. Any thoughts on how to address this would be great. I tried to to attach the file but got a message I don't have the privileges.
          Brian McGundefined Guzzistundefined 3 Replies Last reply
            Brian McGundefined Offline
            @Kerry-Lebel attachments require reputation points, have an up vote to help you along
              Guzzistundefined Offline
              @Kerry-Lebel said in BDR Route GPX Support:
              ...When you import the GPX file, it will convert the tracks into 'Route-Track' and the POI data is not imported...
              Yes, that's the current situation in MRA: if a gpx contains a track - and POI - then MRA will only import the track. But not the POI.
              It's also common in Europe, to share rides by a track, not by route. Because routes are mostly different after importing in different devices. It's the nature of a track, it has only 2 points visible: the start and the end point. Therefore creators of such tracks includes often POI to support the navigation (p.e. gas stations, restaurants, view points, monuments, check points, etc.)
              It's often discussed here by several users, but there is no "official" statement by developers, if they will include it in future...
              Kerry Lebelundefined 1 Reply Last reply
              • BertMundefined Offline
                @Kerry-Lebel this is still an issue as @guzzist mentioned.
                Send me the file in a PM, I have made a tool to filter waypoints out off GPX files
                  Hi @Kerry-Lebel not sure if this will fit exactly what your after but it may be a bit of a work around the issue
                  if you upload the GPX file with the route/track/poi's as normal
                  you should end up with a route or track of the path you want to follow
                  now in the route file click the 3 hamburger menu next to "Waypoints" to expose the menu & select the POI tab
                  on the POI tab select "Library" & then "Add"
                  if you select the same GPX file to upload I think this will load the POI's
                  you just need to place a tick in the selection box for the POI's to always show for this route in MRA
                  it will only be the POI name, no other details, as MRA does not cater for detailed info within POI's
                  MRA prefers to have detailed info in the Waypoint > Notes field
                  these POI's will not be exported if you save the route out of MRA as a GPX
                  they will only be displayed within the
                  • Guzzistundefined Guzzist
                    Kerry Lebel
                    @Guzzist thank you for clearing that up for me. I will hold tight and hopefully this will get updated. MRA is my go to in 70% of my riding but I cant use it at all for BDR trips or any local ADV trips because everyone is sharing tracks with POI data for lockouts, etc. If MRA managed data with collections like OnX, Osmand and Garmin, it would definitely be the only tool I would need.
                    Kerry Lebel
                    Rob Veerman
                    BertMundefined
                    • 3 Devices and only 1 using NN.
                      Big Al 1undefined
                      Big Al 1
                    • Segmentation
                      Nick Carthewundefined
                      Thomas Neumeyerundefined
                      Thomas Neumeyer
                      1.6k
                    • Onbekende fout, 3 problemen
                      Klompenmaker1undefined
                      Klompenmaker1
                      372
                      supergundefined
                    • erratic routing instructions
                    • Route opslaan op Pc vanuit telefoon MRA app
