  4. Offline Navigation
Offline Navigation
7 Posts 4 Posters 961 Views 1 Watching
  • pjwood249undefined Offline
    pjwood249
    Hi there, QQ from a newish user on 'offline navigation'. (When in offline mode - offline maps downloaded and no mobile signal (or data turned off)). How does MRA know where you are in relation to the route you are navigating? ergo; if the route says turn left, how does the app know I have turned left and not deviated from the route? Feel free to point me at an existing post/folder.
    • pjwood249undefined pjwood249
      Nick Carthewundefined Offline
      @pjwood249 You also need to sync your routes and select offline navigation. Then the GPS chip in your phone does the rest.
      pjwood249undefined 1 Reply Last reply
        pjwood249
        @Nick-Carthew Thx Nick, much appreciated. 👍
        • coupe_vsundefined Offline
          coupe_vs
          Besides having downloaded routes, downloaded maps, and synchronized routes... does the app automatically switch between areas with and without network coverage? I've noticed that if you activate offline mode, you're always offline. So, for this automatic switching to work, does the offline option need to be turned off (red)?
          • coupe_vsundefined coupe_vs
            @coupe_vs said in Offline Navigation:
            Yes. With ALL the offline maps required for the route and synced routes, the app will use these if the network data signal is lost.
              coupe_vs
              Ok Nick thanks for your answer
              • Bouke Entundefined Offline
                and you have to use a route and not track. offline track calculation is not what you want
                Bouke Entundefined
                coupe_vsundefined
                coupe_vs
                pjwood249undefined
                pjwood249
                • Is It Me?
                • RX routes
                • Most basic introduction for a newbie group
                  Anonymouseundefined
                  Herman Veldhuizenundefined
                • Tablet screen lock
                • Can I Merge Multiple GPX Files into One Route?
                • Allowing Highways
