  4. Imported POI files visible in App
9 Posts 5 Posters 916 Views 2 Watching
  • Keith Hofgartnerundefined Offline
    Keith Hofgartner
    I have created and imported a POI file into the Route Lab. Is it possible to see these or any of the POI categories in the MyRoute App.
    • Brian McGundefined Offline
      Hi @Keith-Hofgartner I dont believe any form of adding or editing POI is available within the App (or at least I can't find it)
      The only POI functions I know are those via the website / route lab
      • Keith Hofgartnerundefined Keith Hofgartner
        Nick Carthewundefined Offline
        @Keith-Hofgartner Your imported list of POIs can be seen if you click the Library tab in the POI section.
        Click the square tick box to activate them or tick the profile icon (arrowed) to see them in all routes and while using MRA Navigation Next.
          Keith Hofgartner
          Thank you, I now see how it works but I seem to have an issue... when ticking (selecting) the POI (either in the Search or Library tab) sometimes the POIs appear and then they disappear as I zoom in or out.. (Also impressed with all your POI Lists is there a general website to download these??)
          Nick Carthewundefined Travellexxieundefined 2 Replies Last reply
            @Keith-Hofgartner POIs from the MRA library are only visible from 1km zoom level or closer. POIs from your library are visible from 5km zoom level. Yes, sometimes they disappear, you just need to jiggle the zoom for them to appear again.
            I use (https://www.pocketgpsworld.com/) for POI lists.
              Travellexxieundefined Offline
              @Keith-Hofgartner Yes, I understand what you mean. When you are planning, that is quite annoying sometimes. And with zooming in and out, it also happens regularly that you lose focus on the area you were planning.
              Ducati Monster 1200 met Garmin ZΓΌmo XT
              MRA Lifetime Gold
                Keith Hofgartner
                Thanks, now I see (no I dont πŸ™‚ ) It is annoying to say the least.
                  @Keith-Hofgartner, The whole map covered with POI and not being able to see through them is also very annoying... πŸ˜‰
                    Keith Hofgartner
                    Point well made!
                    Keith Hofgartner
                      Massimo Cardoneundefined
                      Massimo Cardone
                      -3
                      20
                      413
                    • Waze warnings...
                      nomkoundefined
                    • Testrit met AA ivm tracklog
                      Tom Balmerundefined
                      Tom Balmer
                    • Fout in route bibliotheek
                      Peter Zehentreiterundefined
