  4. "Route as Track" wird nicht wie geplant navigiert
42 Posts 8 Posters 9.7k Views 4 Watching
    MRA NN verwendet die HERE-Karte, daher werden Ihnen dieselben Straßen angezeigt. Dies gilt auch für die Navigation als Track, da der HERE-Algorithmus sich vom OSM-Algorithmus unterscheidet.
    MRA NN uses the HERE map, this is why you see the same roads used. Even when navigating as a track because the HERE algorithm is different to the OSM algorithm.
    MartinW
    MartinW
    MartinW
    Hi @Nick-Carthew,
    I used this feature a lot, and it always worked this way:
    • I create a route using OSM, which creates a (simplified) trackline that is stored along with the route
    • When opening for navigation "Route as track", MRA NN shows this trackline (white) and calculates an additional route with HERE (blue) on top of the original trackline
    • As long as the original trackline is calculable with HERE, white and blue have the same shape.
    Do you agree?
    However, in this example, I can't see a white line, and the blue line is the "native" HERE route, ignoring the original trackline calculated with OSM.
    And when I export ("save as gpx 1.1 track, POI") the OSM route from the web planner, the "native" HERE route is exported instead of the OSM version.
    So, what's going on here?
    P.S.: Sorry for writing in German initially; this post was meant for "Self Service DE."
    • MartinW
      MartinW
      MartinW
      Could someone please change the title to “Route as track" isn't navigating as planned?
      Thanks.
      • Jörgen
        Warum wechselst du jetzt auf Englisch?
        MartinW 1 Reply Last reply
        • Jörgen Jörgen
          MartinW
          MartinW
          MartinW
          @Jörgen said in "Route as Track" wird nicht wie geplant navigiert:
          Mein Verständnis der Etikette hier ist, dass man in den "allgemeinen Kategorien" nach Möglichkeit Beiträge auf Englisch verfassen sollte und für Beiträge in anderen Sprachen die jeweiligen "Self Service" Kategorien verwenden sollte. Ich hatte diesen Beitrag ursprünglich in "Self Service DE" posten wollen, habe mich dann aber bei der Auswahl der Kategorie vertan.
          Oder mache ich das zu kompliziert? Ist es grundsätzlich egal, welche Sprache man verwendet?
          • Jörgen
            Ja, eigentlich ist es egal, welche Sprache. Es gibt aber die (scheinbar nicht allseits bekannte) Regel, die Antworten in derselben Sprache fortzuführen, in der der Themen-Ersteller angefangen hat.
            Damit Beiträge nicht Englisch, Niederländisch, Deutsch und Französisch enthalten.
            • Jörgen Jörgen
              MartinW
              MartinW
              MartinW
              Ahh, ok, Danke! Das war mir tatsächlich nicht bekannt. Wieder etwas gelernt!
              • MartinW
                MartinW
                MartinW
                Ich habe heute noch einmal einen Test mit einer anderen Route durchgeführt – dasselbe Ergebnis.
                https://www.myrouteapp.com/en/social/route/12968571?mode=share
                Könnte bitte jemand ausprobieren, diese Route, so wie in OSM geplant, in MRA NN mit "Route as Track" zu navigieren (graue Linie)?
                Ich bekomme das nicht hin,es wird immer die Strecke über die A7 gewählt; also offensichtlich die Route, die mit HERE berechnet wird. Das ist auch das Ergebnis, wenn ich meine mit OSM geplante Route als (gpx 1.1 track, POI) exportiere (blaue Linie).
                Danke für eure Hilfe.
                Peter Zehentreiter 2 Replies Last reply
                • MartinW MartinW
                  @Martin-Wilcke Wenn ich im Routenlabor vermeiden AB auswähle , dann kann ich Deine gewünschte Strecke teilweise als Track navigieren.Screenshot_20260320-183532.png Screenshot 2026-03-20 183443.png
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Motorola Edge 40 "offline"
                  Sena SLR 3
                  Sena 50 R
                  • MartinW MartinW
                    @Martin-Wilcke Bei diesem Beispiel habe ich "keine" Vermeidung der AB eingestellt, jedoch die Kurvigkeit der Segmente geändert.Navigation Kurvigkeit geändert Screenshot_20260320-184738.png Kurvigkeit geändert_Screenshot 2026-03-20 184814.png
                    BMW R 1250 GS
                    DMD-NOR7E 7"
                    SPC Universal mount
                    Sena SLR 3
                    Sena 50 R
                      MartinW
                      MartinW
                      MartinW
                      @Peter-Zehentreiter
                      Ja, das geht. Aber das ist nicht der Punkt.
                      Bis vor Kurzem konnte ich eine mit OSM geplante Routen mittels “Routes as tracks” exakt so navigieren. Das scheint nicht mehr zu funktionieren.
                      Und es war auch ganz sicher möglich, eine mit OSM geplante Route genau so als Track zu exportieren. Das geht auch nicht mehr.
                      Wird OSM gerade sukzessive in MRA abgeschaltet?
                      • MartinW MartinW
                        @Peter-Zehentreiter
                        @Martin-Wilcke said in "Route as Track" wird nicht wie geplant navigiert:
                        Kann ich leider nicht beatworten........
                        BMW R 1250 GS
                        DMD-NOR7E 7"
                        SPC Universal mount
                        Sena SLR 3
                        Sena 50 R
                        • Jörgen
                          Ich kann dein Problem noch nicht so ganz nachvollziehen.
                          Wenn ich deine Route nehme und das letzte Segment (was ja nur in OSM geht) kurvig gestalte und diese dann auf HERE-Karte umstelle, wird diese mit WP gefüllt und entspricht in etwa deiner Planung. So kann ich die dann auch in der Navigation Next abfahren.
                          • MartinW
                            MartinW
                            MartinW
                            Ja, alles richtig. Mann kann durch verschiedene Maßnahmen, insbesondere das Setzen von zusätzlichen SPs, die Route so bearbeiten, dass der mit HERE gerechnete Verlauf dem mit OSM gerechneten entspricht.
                            Aber das alles ist nicht notwendig. Wenn man „Routes as Track“ bei der Navigation verwendet, kann man einfach eine Tour mit OSM planen und die dann genau so navigieren. Das ist ja das geniale an diesem Feature, dass man bei der Planung nicht auf HERE Rücksicht nehmen muss!
                            Genau das geht jetzt nicht mehr. Und ich kann die mit OSM geplante Route auch nicht als Track exportieren, um diesen dann z.B. mit DMD zu navigieren.
                            Es sieht so aus, als ob der mit OSM gerechnete Verlauf auf dem Bildschirm angezeigt, aber nicht in der Datenbank gespeichert wird. Also entweder ein Bug - oder das Feature ist abgeschaltet.
                            • MartinW
                              MartinW
                              MartinW
                              Ich habe noch ein bisschen weitergeforscht.
                              In dem Beispiel mit der A7 hatte ich OSM verwendet und "Curves = Average" eingestellt; dadurch wurde die Autobahn automatisch vermieden - aber diese Route wird, wie geschrieben, bei der Navigation nicht verwendet, sondern der Weg über die Autobahn.
                              Wenn ich aber "Avoid = Motorway" hinzufüge, klappt es: Die Route wird dann exakt so navigiert. Sehr seltsam.
                              Genauso seltsam ist, dass auch bei "Avoid = Toll Roads" ( ohne "Avoid = Motorway") der Weg nicht über die Autobahn genommen wird, obwohl die A7 keine "Toll Road" ist. Ich glaube, den Fehler hatten wir schon mal beschrieben.
                              Noch seltsamer ist, dass sowohl bei "Avoid = Motorway" als auch bei "Avoid = Toll Roads" die Autobahn vermieden wird, aber ein unterschiedlicher Streckenverlauf berechnet wird.
                              Ganz ehrlich: Die OSM-Implementierung im MRA Web-Planer ist nicht zu gebrauchen, und HERE ist für die Planung schöner Motorradstrecken überhaupt nicht geeignet.
                              Das ist schon ziemlich frustrierend. Ich werde meine Touren baw. mit anderen Apps planen - hoffen wir mal, dass der neue MRA Webplaner die ganze Wartezeit wirklich wert ist.
                              • Jörgen
                                Hi, ich benutze zu 90 % meinen Instinkt und die Michelin-Karte, um schöne Streckenabschnitte zu finden. Die ganzen Automatismen funktionieren nie perfekt.
                                Eigen gesetzte WP sind immer noch besser.
                                • Jörgen Jörgen
                                  MartinW
                                  MartinW
                                  MartinW
                                  @Jörgen
                                  Ich weiß genau, was du meinst. Das ist wie früher, wo man eine hochwertige Papierkarte hatte und darauf eine Linie eingemalt hat. Das mache ich heute manchmal auch noch so, nur digital. Da brauche ich dann nur eine Software, die meine gemalte Linie auf die Straßen einrastet (oder manchmal eben auch nicht). Das ist für mich dann Trackplanung und da brauche ich überhaupt keine Routing Engine.
                                  Manchmal liegt mein Fokus aber auf POIs, die ich ansteuern will, und den Weg dazwischen lasse ich mir durch eine gute Routen Engine ermitteln, wobei ich meine Präferenzen über Optionen einstellen kann. Das ist für mich dann Routenplanung. Ich dem Fall erwarte ich aber auch, dass die Routen Engine gut funktioniert und die Optionen halbwegs nachvollziehbar sind, sonst wird das ein Lottospiel. Und vor allem erwarte ich, dass ich die geplante Route dann auch so navigieren kann, wie ich mir das bei der Planung vorgestellt habe. Und genau das funktioniert mit OSM in MRA leider überhaupt nicht gut, das geht in anderen Apps erheblich besser.
                                  Mein Eindruck ist, dass sich MRA immer mehr auf HERE konzentriert und möglicherweise für die Routenerstellung für Wohnmobile / Camper optimiert wird. Wir werden sehen, welche Möglichkeiten der neue Webplaner bietet und vor allem, wie das dann mit der Navigation zusammenspielt.
                                  • Hubert Thoring
                                    @Martin-Wilcke : Hey Martin,
                                    versuche es mal mit der GuRu Maps - App, nach etwas einarbeiten kannst Du dem Track knallhart folgen bzw. die Route wählen … geht auch sehr gut mit der Remotek One zusammen zu bedienen. VG 👋
                                    iPad 9. G iOS 27.2.0/iPhone 16e iOS 27.2.0/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
                                      MartinW
                                      MartinW
                                      MartinW
                                      @Hubert-Thoring
                                      Danke für den Tipp!
                                      Es gibt einige gute Trackplanung-Apps, hauptsächlich aus dem Bereich hiking & biking, die auch Planungen für Motorrad/Auto ermöglichen. Hier ist Locus Maps mein Favorit; unter anderem auch deshalb, weil es einen recht guten WebPlaner bietet.
                                      MRA ist für mich eine klassische Routenplanungs-App, also eher in Konkurrenz zu Kurviger & Co.
                                        I did not read the full thread and did not test anything concerning this, but want to give these tips:
                                        • When a route that has the OSM (or TT) map set as basemap is opened in NN, it will always be opened as track, so there is no route recalculation on basis of the HERE map (but of course a track calculation is done, but distances between trackpoints cannot lead to these kind of differences).
                                        • could it be possible when you still have the compare to HERE function active, a save from the webplanner leads to a route based on HERE instead of the basemap? Maybe that's the difference. I never saw anything like this, but I seldomly use compare functions. This might explain perhaps.
                                        MartinW 2 Replies Last reply
                                          MartinW
                                          MartinW
                                          MartinW
                                          Thanks for your hints!
                                          It's not about comparing OSM and HERE or any other interaction between them; it's a pure OSM issue.
                                          Here are three simple steps for a check:
                                          • open and use this route; the goal is to avoid the A7 Motorway
                                          • turn on Toolkit > Curves > Average. The route line changes accordingly; however, if you open this route for navigation, the A7 is used anyway
                                          • turn off Curves > Average and set Avoid > Highway instead. This works as expected when opening for navigation
                                          MartinW
                                          MartinW
                                            98
                                          • Route exporteren uit beta
                                            Rob Veerman
                                            Rob Veerman
                                            74
                                          • Startpunt wijzigen
                                            BMcG
                                            BMcG
                                          • V6 - Track Navigation
                                          • Add the last visited folder to "Routes and Tracklogs"
                                            Thomas Schäfer
                                            Thomas Schäfer
                                            1.7k
