  2. MRA Café
  3. New group for MyRoute-app users on DMD2 systems
38 Posts 13 Posters 14.2k Views 5 Watching
  • silberfuchs67
    silberfuchs67
    silberfuchs67
    Hi @Guzzist thanks for your support but I think it was a misunderstanding. I meant, if you decide within DMD2 to navigate the route with MRA the MRA App won‘t open. There is an error message. This issue happens only with MRA, Not with other naviagtion apps, e.g. Kurviger or ….
    • GHPA
      GHPA
      GHPA
      Same problem at my side. Mra start up but then message: this is taking longer than expected! And that is it. Other nav apps work like google maps. Reported problem at dmd2 but get answer that it is a mra problem also because other nav app works.
      • silberfuchs67
        silberfuchs67
        silberfuchs67
        Thanks @infohagentb.nl - this is exactly the issue I have.
        • Guzzist
          ...hmmm understood - but...
          Unfortunatelly I only remember slightly about this function. There is a option in the GPS-Settings of DMD2 app, which asks for.
          Long time ago, I have switched this option "off" because if I'm just using the DMD2 app (so, I'm inside the app) it seems pointless to me, to open then another app. If this would be my intention, I could open the other app directly upfront...
          • silberfuchs67 silberfuchs67
            martin-phogel.de
            martin-phogel.de
            martin-phogel.de
            #31
            @silberfuchs67
            Hmmm..., can't confirm this issue.
            I tried it several times, and it worked flawlessly. Are you sure you selected a routable destination?
            Guzzist 1 Reply Last reply
            • silberfuchs67
              silberfuchs67
              silberfuchs67
              I‘ll give it a try and keep you informed!
                @silberfuchs67
                #33
                @Martin-Wilcke ...thank you Martin, by the help with your Screenshots, now I remember by which action the question about "external app" occurs.
                And yes - after I have switched on this question in the settings - I can confirm: routing by external app (in this case MyRoute-App) works correct as expected.
                But I stand by my opinion: searching for a destination in the app – only to then be navigated by another app – is strange in my view. I might as well use the other app for searching and navigation.
                • Guzzist Guzzist
                  martin-phogel.de
                  martin-phogel.de
                  martin-phogel.de
                  @Guzzist
                  DMD2 does not support using traffic data for calculation/navigation, whereas MRA does (under certain conditions).
                  Therefore, I use this feature when I have the following use case:
                  • I navigate a track with DMD2
                  • I would like to “shorten” a part for some reason by travelling as quickly as possible (also using traffic data)
                  • I select a destination point on my track and transfer this location to MRA using the method explained here
                  • This initiates an A-B routing in MRA, calculating the fastest route, and taking traffic data into account
                  • Once I have reached my destination point, I switch back to DMD2 to continue navigating my track
                    @Guzzist
                    @Martin-Wilcke ahhh got it - and I learned something new again 😊
                    But I have never used such a possibility, because where I'm usually riding - there is no traffic 😜 😜
                    • Guzzist Guzzist
                      martin-phogel.de
                      martin-phogel.de
                      martin-phogel.de
                      @Guzzist
                      I completely agree - trees don't move 🙂
                      But it's always good to have a few tools and solutions at hand, just in case...
                        @Guzzist
                        @Martin-Wilcke 😊 😁
                        • silberfuchs67
                          silberfuchs67
                          silberfuchs67
                          @Martin-Wilcke just tried your example starting the route via external app (MRA) and it didn‘t work. Got the same error message like @infohagentb.nl mentioned. This seems only to be valid for MRA.
                          martin-phogel.de
                          martin-phogel.de
                          Thomas Neumeyer
                          Thomas Neumeyer
                          silberfuchs67
                          silberfuchs67
                          Huibertus
                          Huibertus
                          GHPA
                          GHPA
                          Rob Kilbourne
                          Rob Kilbourne
                          Niek 4
                          Niek 4
                          • Download club route folders
                            Òscar
                            Òscar
                          • Passwords
                            Captain Haddock
                            Captain Haddock
                            Ed Lauwerens 0
                            Ed Lauwerens 0
                            960
                            381
                          • Live tracking problem on Android tablet
