  2. MRA Café
  3. New group for MyRoute-app users on DMD2 systems
38 Posts 13 Posters 14.8k Views 5 Watching
    @Thomas-Neumeyer Just one question from my side...
    Which Silvefox controller do you use?
    Do you have iOS or Android?
    In case you are using Android, I would like ask you another question....
    @Peter-Zehentreiter said in New group for MyRoute-app users on DMD2 systems:
    ...before you buy a Silverfox, please consider if you are driving only onroad, or also offroad. To operate the Nav device by controller, on bumpy roads (offroad) it's difficult to do it without mistakes by the 4-way mini joystick. Especially quick zoom in an out.
    Because the remote controllers are not cheap, I recommend a test in a shop or an exhibition, if you can reach all joysticks and buttons with our fingers on handlebar comfortably... 😉
    • Guzzist Guzzist
      @Guzzist Thanks for your comment...
      I already have one (C1) and used it throughout the entire 2025 season (on the road).
      There's just one thing that bothers me!
      The controller worked perfectly at first.
      But since the option to set or change the language was implemented in the MRA app, I can no longer zoom in with the setting “German language or German cell phone, everything in German.”
      However, as soon as I switch to English in the MRA app, the controller works perfectly...
      When I use an older phone, e.g., Android 12 (where the language cannot yet be set in the MRA app), it works perfectly in German.
      Personally, I believe the error lies with MRA, but unfortunately, no one has been able to find the annoying error yet.
      That's why I keep asking other people for clues as to why this error occurs.
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
        @Peter-Zehentreiter have you got the latest update from SilverFox for your remote. Bevatte they have made some changes. Dit me since then it works perfect
        • Guzzist Guzzist
          @silberfuchs67 said in New group for MyRoute-app users on DMD2 systems:
          Could someone please update the link for the group?
          ...I belive, the mentioned group is no longer existent, because the DMD-Forum became obsolete. They are now using a discord server for discussions. May this channel is relevant:
          https://discord.com/channels/1009485004268654683/1460233394033266731
          Niek 4
          Niek 4
          Niek 4
          @Guzzist dsdasdadadad
          The link is not working get a error. Do you have the group name or new link?
          Thnx!
          Guzzist 1 Reply Last reply
          • Thomas Neumeyer
            Thomas Neumeyer
            Thomas Neumeyer
            Hello, I have the B8J controller and I use Android 13. Did not encountered this issue.
            Thomas
            • silberfuchs67
              silberfuchs67
              silberfuchs67
              wrote on last edited by silberfuchs67
              #23
              I‘d Like to ask the following question: in case you want to navigate within DMD2 a new route or track you will be asked if you would like to navigate with DMD2 or an external app. If I choose the external App, MRA the app won‘t start. This issue is only valid for MRA. Does anyone know about this issue?
              In case this should not be a topic here, please close or delete. Thanks.
              Marinus van Deudekom Guzzist 2 Replies Last reply
              • silberfuchs67 silberfuchs67
                @silberfuchs67 what do you Megan exactly. That you’ve receiver a route or track and didn’t”t import that in MRA Or that a route in MRA won’t start on your DMD device
                The first is normal the second a problem
                • Niek 4 Niek 4
                  Thnx!
                  @Niek-4 said in New group for MyRoute-app users on DMD2 systems:
                  Thnx!
                  Sorry @Niek-4 I double checked the link, and it worked.
                  But I have installed the Discord App. So, if I click the link, instantly the app will be started.
                  Alternatively, I copied the link into the address field of an browser; it also worked.
                  So, maybe it worked for me, because I do have an account there. Please try again, maybe with the basic part of the link: https://discord.com - I'm pretty sure, this leads you to the homepage of Discord. There you need to register yourself to get an account.
                  If you have got an account and logged in, you can search:
                  If you tap in the field an start writing, a popup window comes up:
                  Type in "DMD Navi" - immediately you will see down the main page of "DMD Navigation" with the icon. Tap on it - now you are in the right corner - and you will see seceral sub categories:
                  Tap on the bell icon, to receive messages about new threads.
                    ...in case you want to navigate within DMD2 a new route or track you will be asked if you would like to navigate with DMD2 or an external app...
                    I slightly remind about this question. In the settings, you can disable this question.
                    But the usual way to start is - like in MyRoute-App:
                    if you have received a gpx file from anybody
                    • transmit it to a data folder of the DMD device
                    • may open DMD2 app, goto GPX-Manager and import the gpx into the app
                      (that's similar to MRA-Routeplanner)
                    • make the imported route or track visible on map
                    • if start of route or track is close to your location, start to ride, navigation will start automatically
                    • silberfuchs67
                      silberfuchs67
                      silberfuchs67
                      Hi @Guzzist thanks for your support but I think it was a misunderstanding. I meant, if you decide within DMD2 to navigate the route with MRA the MRA App won‘t open. There is an error message. This issue happens only with MRA, Not with other naviagtion apps, e.g. Kurviger or ….
                      • GHPA
                        GHPA
                        GHPA
                        Same problem at my side. Mra start up but then message: this is taking longer than expected! And that is it. Other nav apps work like google maps. Reported problem at dmd2 but get answer that it is a mra problem also because other nav app works.
                        • silberfuchs67
                          silberfuchs67
                          silberfuchs67
                          Thanks @infohagentb.nl - this is exactly the issue I have.
                          MartinW 1 Reply Last reply
                          • Guzzist
                            ...hmmm understood - but...
                            Unfortunatelly I only remember slightly about this function. There is a option in the GPS-Settings of DMD2 app, which asks for.
                            Long time ago, I have switched this option "off" because if I'm just using the DMD2 app (so, I'm inside the app) it seems pointless to me, to open then another app. If this would be my intention, I could open the other app directly upfront...
                              MartinW
                              MartinW
                              MartinW
                              #31
                              @silberfuchs67
                              Hmmm..., can't confirm this issue.
                              I tried it several times, and it worked flawlessly. Are you sure you selected a routable destination?
                              • silberfuchs67
                                silberfuchs67
                                silberfuchs67
                                I‘ll give it a try and keep you informed!
                                • MartinW MartinW
                                  @silberfuchs67
                                  #33
                                  @Martin-Wilcke ...thank you Martin, by the help with your Screenshots, now I remember by which action the question about "external app" occurs.
                                  And yes - after I have switched on this question in the settings - I can confirm: routing by external app (in this case MyRoute-App) works correct as expected.
                                  But I stand by my opinion: searching for a destination in the app – only to then be navigated by another app – is strange in my view. I might as well use the other app for searching and navigation.
                                  • Guzzist Guzzist
                                    MartinW
                                    MartinW
                                    MartinW
                                    @Guzzist
                                    DMD2 does not support using traffic data for calculation/navigation, whereas MRA does (under certain conditions).
                                    Therefore, I use this feature when I have the following use case:
                                    • I navigate a track with DMD2
                                    • I would like to “shorten” a part for some reason by travelling as quickly as possible (also using traffic data)
                                    • I select a destination point on my track and transfer this location to MRA using the method explained here
                                    • This initiates an A-B routing in MRA, calculating the fastest route, and taking traffic data into account
                                    • Once I have reached my destination point, I switch back to DMD2 to continue navigating my track
                                    • MartinW MartinW
                                      @Guzzist
                                      @Martin-Wilcke ahhh got it - and I learned something new again 😊
                                      But I have never used such a possibility, because where I'm usually riding - there is no traffic 😜 😜
                                      • Guzzist Guzzist
                                        MartinW
                                        MartinW
                                        MartinW
                                        @Guzzist
                                        I completely agree - trees don't move 🙂
                                        But it's always good to have a few tools and solutions at hand, just in case...
                                        • MartinW MartinW
                                          @Guzzist
                                          @Martin-Wilcke 😊 😁
                                          MartinW
                                          MartinW
                                          GHPA
                                          GHPA
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          silberfuchs67
                                          silberfuchs67
                                          Huibertus
                                          Huibertus
                                          Rob Kilbourne
                                          Rob Kilbourne
                                          Niek 4
                                          Niek 4
                                          • Online map settings
                                            975
                                          • MRA-pictogram
                                            BMcG
                                            BMcG
