  3. Mode warning?
Mode warning?
8 Posts 5 Posters 2.3k Views 3 Watching
  • Michael Doherty 0
    Michael Doherty 0
    Michael Doherty 0
    When i switch my preferred map to: Default (Open Street Map) selection, i receive this warning: "The selected mode only works with the HERE / TomTom map." I can click ok and continue on to plan my route. The reason i change my map from HERE to OSM is because the device i navigate by uses OSM and the accuracy seems better and the route lines up with the map better. My question, is why am i getting that warning message? What "mode" setting is it referring to?
    Thanks,
    MD
    • Michael Doherty 0 Michael Doherty 0
      Thanks,
      MD
      @Michael-Doherty-0 Change your transport mode. Only Car works with the OSM map.
      Michael Doherty 0 1 Reply Last reply
        Michael Doherty 0
        Michael Doherty 0
        Michael Doherty 0
        @Nick-Carthew Thank you ๐Ÿ™‚
        Guzzist 1 Reply Last reply
          @Nick-Carthew please excuse my silly question. But I have read a couple of issues by using the motorbike mode...
          What is the benefit/advantage of using the motorbike mode?
          Travellexxie Rob Verhoeff 2 Replies Last reply
          • Guzzist Guzzist
            @Guzzist it uses some smaller roads, but on the other nand, there are more problems, than benefits. No possibility to choose fastest/shortest, doesn't (or hardly) sees ferries, not visibil in your shared routes and so on. I might have forgotten some things. So, just take auto๐Ÿ˜‰
            Ducati Monster 1200 met Garmin Zรผmo XT
            MRA Lifetime Gold
            • Guzzist Guzzist
              @Guzzist Thereโ€™s no specific reason why the transport mode โ€œmotorcycleโ€ has an advantage. Some of us just want to see which routes weโ€™ve taken for motorcycling, cycling, or driving your car. You can then view that at a glance in your library. The only advantage I see is that you can now also choose the โ€œshortest routeโ€ option in the Toolkit-menu.
              • Travellexxie Travellexxie
                @Lex.Kloet.RX said in Mode warning?:
                Since version 5.0.1 it does ๐Ÿ˜‰
                  @Rob-Verhoeff ahnja, I was with my head at the planner ๐Ÿ˜‰
                  MRA Lifetime Gold
                  Michael Doherty 0
                  Michael Doherty 0
                  • Route wordt afgesneden
                    Wim Hompes
                    Wim Hompes
                  • Map colours and side roads
                  • OSM Routing with MRA
                    Pierre c
                    Pierre c
