  4. 7.5t restrictions not working
13 Posts 4 Posters 2.3k Views 2 Watching
  • Next Stop Offline
    Next Stop Offline
    Next Stop
    Hi there,
    Is anyone else having issues with the 7.5t restrictions not working, or am I missing something when setting up journey?
    Also, does anyone know what the difference is between the two different 7.5t restrictions (the one with the green box and the one without?)
    Cheers,
    Martin
    • Next Stop Offline
      Next Stop Offline
      Next Stop
      I'm not sure, but I think the logistics layer might be broken as I just tried the ol' clear cache/data and tried again and now the restrictions don't seem to be showing?
      • Next Stop Next Stop
        @Next-Stop, Whether the restrictions are showing or not, depends on this setting:
        and the actual chosen mode of transport. If you set this to car (arrow) the restrictions will always be shown. Clearing cache and data probably reset your settings to default.
        Next Stop 1 Reply Last reply
          Next Stop Offline
          Next Stop Offline
          Next Stop
          @Con-Hennekens ah, excellent thank you! That has brought them back on the map layer, the navigation is still choosing to ignore them though sadly, hopefully a fix will come soon!
          Cheers
          Martin
            Cheers
            Martin
            @Next-Stop, did you try that in transportmode "Truck"?
              Next Stop Offline
              Next Stop Offline
              Next Stop
              @Con-Hennekens Funny enough I have just tried that and it seems to be working, looks like there must be a bug with the Motorhome choice as it's not recognizing the restrictions. Strange?!
                @Next-Stop, I think if your motorhome is heavier then 7500, technically it is a truck. But since you are able to set a weight for a motorhome, it suggests that it will be used in route calculations... I think only @Corjan-Meijerink can comment on this.
                • Next Stop Offline
                  Next Stop Offline
                  Next Stop
                  wrote on last edited by Next Stop
                  Thanks @Con-Hennekens for your reply and sorry for my delayed response, I haven't been getting any notifications for some reason.
                  My MH is only 3500kg, but I've set it to 7501kg as I'd prefer not to travel if the road is tight and I feel that 7500kg limit fits better as I've come across loads of 3500kg roads that are no more than farm lanes!
                  hopefully @Corjan-Meijerink can clarify as I'd like to be able to use the correct configuration, I know the Truck one will work fine but the OCD in me wants to use the correct symbol, lol!
                  • Con Hennekens Offline
                    @Next-Stop, You would be surprised about the level of OCD in our alpha chat... (NOT me of course! ๐Ÿคฃ )
                    • Corjan Meijerink Online
                      I know the answer now ๐Ÿ™‚
                      A motorhome with a certain weight entered registers you as "big car" with a weight of something. Technically that road is only blocked for trucks of a certain weight.
                      So these really heavy vehicles should be entered as truck!
                      The real answer is that above 5000kg you aren't classifying as car anymore but you should be a truck. But as you selected a motorhome we just think of you as a big car ๐Ÿ˜‰
                        @Corjan-Meijerink, This is what (Dutch) law says about the C21 signs:
                        These signs are not targeted at trucks, but at vehicles in general. I understand that this is probably a HERE parameter, but you could discuss this with HERE maybe, or take matters into your own hand and use the truck calculation in the background whenever a camper has a weight > 3,5t.
                          Next Stop Offline
                          Next Stop Offline
                          Next Stop
                          @Con-Hennekens said in 7.5t restrictions not working:
                          @Corjan-Meijerink This sounds like a good idea if possible. as to the average user it looks like the weight isn't being registered. Or like myself want to ensure that I avoid any narrow restricted roads, as said before many 7.5t road around here aren't really suitable for anything larger than a small van!
                          • Matt Banks 0 Offline
                            Matt Banks 0
                            Another vote to have the app use the truck calculation in the background when setting motorhomes with certain parameters ๐Ÿ™‚
                            Next Stop
                            Next Stop
                            Matt Banks 0
                            Matt Banks 0
                              Michele Skipper
                              Michele Skipper
                            • NC500 glitch
                              Tenmill 0
                              Tenmill 0
                            • Feature Request: Map Contrast & Road Visibility in Navigationโ
                              Rezzonico Mauro
                              Rezzonico Mauro
                            • Tracklog correction
                            • Android TTS question
                            • POI naming/text display
                              Philippe Veys
                              Philippe Veys
                            • New Zealand Routes
                              Bull Tahr
                              Bull Tahr
