  4. Older Android versions
14 Posts 7 Posters 3.5k Views 3 Watching
  • Gijs Jonker Offline
    Gijs Jonker Offline
    Gijs Jonker
    Unfortunately the v5.0.1 release hasn't resolved the (Android 9) issue I mentioned.
    Bouke Ent 1 Reply Last reply
    • Con Hennekens Offline
      Have you tried each of the new "advanced" settings in the map layer settings?
      Gijs Jonker 1 Reply Last reply
      • GEORGIOS PANTELIDIS 0 Offline
        I believe they need to find a solution. It's not acceptable to have to buy a new phone running Android 15 or later just for the application to work correctly. As I understand it, the issues begin with Android 14 and older versions, according to their announcement for the new release 5.0.1.
        Brian McG richtea999 2 Replies Last reply
        • GEORGIOS PANTELIDIS 0 GEORGIOS PANTELIDIS 0
          Brian McG Offline
          Brian McG Offline
          @GEORGIOS-PANTELIDIS-0 I am using Blackview BV7100 running android 12 & have not seen any issues with 5.0 or 5.1, so I would expect android 13 & 14 to also be fine
            richtea999 Offline
            richtea999 Offline
            @GEORGIOS-PANTELIDIS-0 said in Older Android versions:
            It's worth noting that Google forces developers to update their apps at least once a year, to keep up with the latest 'target' SDKs. This regularly causes support for older Android versions to drop off, or some older features to become 'broken', withdrawn, etc.
            Furthermore if developers don't move up ... 'Out-of-date apps are unavailable to new users of devices that run newer versions of Android.'
            So - do I p*ss off the older device users, or do I lose the newer device users?
            Catch-22.
            Realistically it's not an option to ignore Google's updates, and (depending on the change, and technology used) it's no fun for the developer having to update everything either.
            In summary that dropping of older Android versions isn't really in MRA's control, it's in Google's, so place the blame squarely in their court!
            Offering some settings to try and support older devices is a good solution - probably the only solution in fact, I would guess.
              I don’t want to say anything bad about the app — I absolutely love it — but since I have two phones, a Motorola G32 with Android 13 and a Ulefone X12 Pro that I use for navigation, I noticed that the Motorola had an issue. I think it might have been fixed with the settings offered for older phones, though I’m not 100% sure yet, but it seems like it’s resolved.
              However, since I also use other apps from time to time, those don’t have any issues with older Android versions. How that happens, I honestly don’t know.
                Gijs Jonker Offline
                Gijs Jonker Offline
                Gijs Jonker
                @Con-Hennekens Thanks for the suggestion. I tried a lot of settings and finally Map Style > bottom 'Advanced Settings (older Android) > 'native view mode' on Virtual Display (automatically does a restart of the app) seems to do the trick!
                I changed this setting on another Android 9 device (after update, advanced setting seemed to not be available in the 5.0.0 version) and worked too.
                I see all my routes again, makes me really happy!
                • Corjan Meijerink Offline
                  There’s a reason why we introduced this setting 🙂
                  • Gijs Jonker Gijs Jonker
                    Bouke Ent Offline
                    Bouke Ent Offline
                    @Gijs-Jonker same on samsung s8 and active 2
                      Bouke Ent Offline
                      Bouke Ent Offline
                      @Gijs-Jonker with this solution it seems to work on active 2
                      Gijs Jonker
                      Gijs Jonker
                        Michele Skipper
                        Michele Skipper
                      • POI naming/text display
                      • NC500 glitch
                        Tenmill 0
                        Tenmill 0
                        Rezzonico Mauro
                        Rezzonico Mauro
                      • Android TTS question
                      • Scenic routing en rondrit generator
                        erik de laat
                        erik de laat
                        2.5k
