  4. Older Android versions
14 Posts 7 Posters 3.2k Views 3 Watching
  • Gijs Jonker Offline
    Gijs Jonker Offline
    Gijs Jonker
    Wonderful to see the 5.0 version released. But what Android versions are supported?
    I am hesitant to use my expensive new smartphone as navigation on my motorbike. I have an older smartphone that is still working fine for that purpose, but it has Android 9 (and can't be updated). In 5.0 the 'Routes & Tracklogs' menu item gives a map on the screen but you can't do anything anymore but go back. Any chance that this can be fixed?
    ~ Gijs Jonker, Westland
    • Gijs Jonker Gijs Jonker
      @Gijs-Jonker, that's probably related to this issue, we see on older Android versions indeed:
      https://forum.myrouteapp.com/post/71353
        Gijs Jonker Offline
        Gijs Jonker
        Thanks for the quick response! It looks a bit like the other issue but not exactly.
        From the main menu everything works fine except two menu items: Routes & Tracklogs and Activity Feed. They both give the map on the full screen (portrait and landscape mode) and nothing is possible anymore, no scrolling, absolutely nothing. Only the Android back button goes back indeed and everything else seems to work.
        I have 3 Android 9 devices and they all react the same; device reboot doesn't help. On Android 11 all the (main) menu items work as expected.
        • Corjan Meijerink Offline
          I expect a fix rather soon for that issue!
            Gijs Jonker Offline
            Gijs Jonker
            Unfortunately the v5.0.1 release hasn't resolved the (Android 9) issue I mentioned.
            Bouke Ent 1 Reply Last reply
            • Con Hennekens Offline
              Have you tried each of the new "advanced" settings in the map layer settings?
              Gijs Jonker 1 Reply Last reply
              • GEORGIOS PANTELIDIS 0 Offline
                I believe they need to find a solution. It's not acceptable to have to buy a new phone running Android 15 or later just for the application to work correctly. As I understand it, the issues begin with Android 14 and older versions, according to their announcement for the new release 5.0.1.
                Brian McG richtea999 2 Replies Last reply
                • GEORGIOS PANTELIDIS 0 GEORGIOS PANTELIDIS 0
                  Brian McG Offline
                  Brian McG Offline
                  @GEORGIOS-PANTELIDIS-0 I am using Blackview BV7100 running android 12 & have not seen any issues with 5.0 or 5.1, so I would expect android 13 & 14 to also be fine
                    richtea999 Offline
                    richtea999 Offline
                    @GEORGIOS-PANTELIDIS-0 said in Older Android versions:
                    It's worth noting that Google forces developers to update their apps at least once a year, to keep up with the latest 'target' SDKs. This regularly causes support for older Android versions to drop off, or some older features to become 'broken', withdrawn, etc.
                    Furthermore if developers don't move up ... 'Out-of-date apps are unavailable to new users of devices that run newer versions of Android.'
                    So - do I p*ss off the older device users, or do I lose the newer device users?
                    Catch-22.
                    Realistically it's not an option to ignore Google's updates, and (depending on the change, and technology used) it's no fun for the developer having to update everything either.
                    In summary that dropping of older Android versions isn't really in MRA's control, it's in Google's, so place the blame squarely in their court!
                    Offering some settings to try and support older devices is a good solution - probably the only solution in fact, I would guess.
                      I don’t want to say anything bad about the app — I absolutely love it — but since I have two phones, a Motorola G32 with Android 13 and a Ulefone X12 Pro that I use for navigation, I noticed that the Motorola had an issue. I think it might have been fixed with the settings offered for older phones, though I’m not 100% sure yet, but it seems like it’s resolved.
                      However, since I also use other apps from time to time, those don’t have any issues with older Android versions. How that happens, I honestly don’t know.
                        Gijs Jonker Offline
                        Gijs Jonker Offline
                        Gijs Jonker
                        @Con-Hennekens Thanks for the suggestion. I tried a lot of settings and finally Map Style > bottom 'Advanced Settings (older Android) > 'native view mode' on Virtual Display (automatically does a restart of the app) seems to do the trick!
                        I changed this setting on another Android 9 device (after update, advanced setting seemed to not be available in the 5.0.0 version) and worked too.
                        I see all my routes again, makes me really happy!
                          There’s a reason why we introduced this setting 🙂
                            Bouke Ent Offline
                            Bouke Ent Offline
                            @Gijs-Jonker same on samsung s8 and active 2
                              Bouke Ent Offline
                              Bouke Ent Offline
                              @Gijs-Jonker with this solution it seems to work on active 2
                              Gijs Jonker
                              Gijs Jonker
                              • Carpuride scherm vast
                                De Ploey Georges
                                De Ploey Georges
                                1.2k
                              • How can I change the verbal navigation directions from male to female?
                                Carl Lee
                                Carl Lee
                                14.1k
                              • Apple Carplay - navigatie instructies zichtbaar, maar kaart niet??
                              • Camperroutes
                                De Ploey Georges
                                De Ploey Georges
                              • Not a great route choice
                              • (Android Auto) Zoom/Steuerung blendet aus und lässt sich nicht per Lenkerschalter reaktivieren.
