  4. Battery life
Battery life
12 Posts 9 Posters 3.4k Views 6 Watching
  • Jan Smerke
    Jan Smerke
    Jan Smerke
    Since the MyRoute-app upgrade and HERE map upgrade has anyone had a chance to do a decent trip to assess the battery drain on their phone whilst navigating a route? About 6 months ago I found whilst using my Samsung android phone it got pretty hot. Shortly after that, the battery expanded and failed. Not sure if it was due to prolonged use of the app or not? Anyway, the power consumption was visibly significant compared to Google maps for example.
    Not really the time of year for long rides but anyone out there formed any early impressions on the performance of the new app?
      The v5 update barely influenced battery life 🎉
      Since the 4.4.0 update, late June, we have a very decent battery usage!
      Still more than Google Maps, which is not weird, but we haven't received many complaints after that version.
      Battery condition of the device itself is obviously also quite important. I recently renewed by iPhone battery from ~75% health and I am now extremely happy with the battery life while navigating without charging.
      Since the 4.4.0 update all devices should definitely be able to charge normally with simple chargers while using the app 😉
      Dave J 0 1 Reply Last reply
      • Hubert Thoring
        I have never had any problems with an iPhone Xr on the BMW Cradel and the inductive charge. If possible, you should start with an almost full battery. I know in the past the battery always stayed at its start % power.
        For really longer breaks, it is recommended to stop the app and restart it later because it does not load during a break.
        VG 👋
          @Corjan-Meijerink Battery life has been great for me on both iOS and Android with V5. With iOS, I run the MRA app with multiple apps running In the background (including RadarBot) as well as CarPlay (wireless and wired); the battery slowly charges if need be or remains at full charge. Batteries on my devices are in good health. Top job.
          iPhone 18 Pro
            Newer Android Phone can have an option for leaving the battery on 80% under use. This also means that the power from the powersupply only is used by phone. The battery will disconnected so to speak.
            https://allthings.how/how-to-limit-your-androids-charging-to-80/
            I use this option for a while now and i'm very pleased with the results. My phone is mounted on the bike in open air. The phone stays cool even in the hottest moments of the year. On colder moments (spring/fall), the phone is just cold in my hands.
            • Veetwin
              Veetwin
              Veetwin
              I have started using MRA as the navigate app with a Carpuride system, I used the map / route planning before. I have noticed that it uses a lot of battery when doing the Navigation. What settings in MRA can help with extending the battery life when using the app to navigate. Other than that the Navigate is very good.
                Nothing. Navigation (all apps) drains the battery
                • Jan Smerke
                  Jan Smerke
                  Jan Smerke
                  Presumably your phone screen is off and you are using Bluetooth connection to send data to the Carpuride device. I would suggest you navigate offline so your phone is doing less work.
                  In case you don't know where the setting is: click on the 3 dots lower right, then Settings icon, then Functional, then slide the button at the top of the page to Offline Navigation.
                  • Rob Kilbourne
                    Rob Kilbourne
                    Rob Kilbourne
                    wrote on last edited by Rob Kilbourne
                    This post is deleted!
                    • Marinus van Deudekom
                      If Ikm using AA , I can navigate all day long with my phone online but the screen Off. At the end Off the day the battery is empty
                        It is not just the app that uses battery life, also the wireless AA connection wears heavily on the battery. Not much you can do about that, other than using a charger and cable that sustain at least 15 Watts.
                        No AA involvement, but last weekend I forgot to switch on my charger. My ThinkPhone ran all day from about 10am to 5pm. without charging. In bright sunlight, so bright screensetting also. I'd say that's pretty good!
                        • Rob Kilbourne
                          Rob Kilbourne
                          Rob Kilbourne
                          This is the only app where this occurs. HereWeGo? Fine. MagicEarth? Not a problem. OsmAnd? Again, all good. The dreaded Google Maps obviously works fine. It's fine. I've got alternatives, I just need to remember to transfer the GPX files to something else.
                          Rob Kilbourne
                          Rob Kilbourne
                          Jan Smerke
                          Jan Smerke
                          Veetwin
                          Veetwin
                          • Audio cuttet via Bluetooth
                            Haug
                            Haug
                            35.5k
                          • One crash today
                          • Download club route folders
                            134
                            peha
                            peha
                            Mosimann
                            Mosimann
                          • Elektrisch rijden
                            John mq
                            John mq
