  4. App restarting when Bluetooth keyboard connected (WunderLINQ)
11 Posts 4 Posters 2.7k Views 3 Watching
  • Andre Trudeau
    Andre Trudeau
    Andre Trudeau
    wrote on last edited by Andre Trudeau
    @stuart-marritt Let me guess, you have an Android device? I have the same issue..
    I also bet that if you connect your 2nd keyboard with the USB dongle and then repeat the test, connecting/disconnecting Wunderlink keeping the USB dongle/Keyboard connected, you will not see the issue...
    From my testing it does not occur on Apple devices...
    • stuart marritt
      stuart marritt
      stuart marritt
      Yes I have a android device
      I will try the second keyboard trick and see what happens although it's not ideal
      • Andre Trudeau
        Andre Trudeau
        Andre Trudeau
        @stuart-marritt Indeed not ideal.. It is more to confirm my suspicions regarding this bug. The second Bluetooth keyboard "trick" seems to prevent the cycling of the app because there is at least 1 keyboard available. The issue occurs when MRA goes from no keyboard to 1 and vice-versa. I have a ticket open on this but no mouvement so far.
        stuart marritt 1 Reply Last reply
        • Andre Trudeau Andre Trudeau
          stuart marritt
          stuart marritt
          stuart marritt
          @Andre-Trudeau as you said with another keyboard attached via the USB the Bluetooth keyboard when connecting and disconnecting has no affect and works as it should
            I am fairly confident this issue will be resolved in the 5.0.1 release this week!
            Please let me know 😃
            • stuart marritt
              stuart marritt
              stuart marritt
              Once the release drops I will test it and report back
              • Robert Laudensack
                Robert Laudensack
                Robert Laudensack
                I had to stop using my small keyboard I wanted to use to start stop music as MyroutApp was crashing when I pressed the buttons
                  That will definitely be an issue of the past when 5.0.1 becomes available to you!
                  • Andre Trudeau
                    Andre Trudeau
                    Andre Trudeau
                    The restart when bluetooth keyboard has been fixed in the new release. I just confirmed it on 2 android devices. Thank you!!!
                      Great to read that! Thanks for confirming 🎉
                      stuart marritt
                      stuart marritt
                      Andre Trudeau
                      Andre Trudeau
                      Robert Laudensack
                      Robert Laudensack
                      • MRA Studio export speed
                      • Hiya from UK
                        Russ Nattrass 1
                        Russ Nattrass 1
                      • geeft routepunt niet weer
