  4. V5.0.0 : map remain on screen, hiding menu
26 Posts 9 Posters 7.1k Views 5 Watching
  • Forest
    Forest
    Forest
    Hi everybody.
    First thing : english is not my mother language so ...
    Instead of a long text trying to describe the problem I have with 5.0 version I put a video.
    https://youtube.com/shorts/nJGBJYLHWoM?feature=share
    The problem I have is that the map remain visible even when I select a page with parameters (see video).
    Moving my finger on the screen I can see some part of the texts/menus almost completely hiden my the map.
    Am I alone with this problem ?
    Help will be greatfully appreciated.
    Christian
    LG-H930
    Android 9
    BMW R1200RT LC (K52) 2015
    Samsung S24+
    Android 16
      That is a very clear video!
      Never seen this issue, no clue what's going on 🙂
      I'll discuss it internally and investigate what the cause could be.
        Yesterday, while updating the offline maps, I somehow ended up in this situation too. After many attempts, I managed to get back to the configuration screen by using the "back" button on the phone.
        So you're not the only one!
        • Forest Forest
          Hi everybody.
          Christian
          LG-H930
          Android 9
          @Forest, is this easily repeatable? I have been moving menus a lot lately ( 😉 ) but have not seen this at all. Can you please reboot your phone and see if it comes back? In the past, with earlier versions also, I have seen some quite strange things after updating a running app. This might be one like that perhaps.
          • Forest
            Forest
            Forest
            @ Con Hennekens, easily repeatable ? YES it comes each time I press the top left button (see video).
            Of course several reboots of my phone have been done, same behaviour.
            I also download MyRouteApp to the LG30 (also Android 9) of my wife, same reaction.
            Not tested to deinstall ans reinstall the App from my phone but as I tested on my wife's one with no success, I think it is not a hope.
            A suivre
            Samsung S24+
            Android 16
            • Forest Forest
              A suivre
              @Forest said in V5.0.0 : map remain on screen, hiding menu:
              What happens when you use the "back" button on the bottom line right on you phone. In my case it brought me back to the correct screen! I tried to reproduce but did not succeed!
              • lluis Castells
                lluis Castells
                lluis Castells
                On my Blackview BV9600 Pro, which worked perfectly with the previous version, I'm experiencing the same issue as Forest. When I press my profile icon, the map always stays on top, obscuring the menus.
                Brian McG 1 Reply Last reply
                • Forest
                  Forest
                  Forest
                  @white.house Same as you.
                  Pressing the "back" button bring me back to the menu I came from (map of current location, menu, choice of layout ... ).
                  When I press the 'menu' button (top right) the screen shows a map (that's wrong) but the list of options are valid under the map and sometime I can select an option (e.g location), option hiden by the map ! and go back with the 'back' button.
                  Samsung S24+
                  Android 16
                  • lluis Castells lluis Castells
                    @lluis-Castells I tried to recreate the issue on my blackview by7100 & could not get it to happen
                    as a matter of curiosity if you go into the android settings & turn off the "navigation" buttons, so remove the back/home button panel & enable gestures, what happens?
                    lluis Castells 1 Reply Last reply
                    • Con Hennekens
                      I took out an older phone with Android 10, and it seems to have a similar problem. One of the other Alpha testers experienced it also after pulling out an old phone with Android 9. So it seems to depend on older Android versions. I think action has already been taken by devs.
                        My Android version is 12 and my phone is a Samsung S10e!
                          We are indeed working on it 🙂
                          • Brian McG Brian McG
                            lluis Castells
                            lluis Castells
                            lluis Castells
                            Thanks for the suggestion. It does exactly the same thing.
                            • Forest
                              Forest
                              Forest
                              Menu button (top right of the screen) is not the only choice to get this effect.
                              In the list at the bottom there are 7 possible choices but only one freezes the screen.
                              See new video : https://youtube.com/shorts/JIXdgY1VJ-Y?feature=share
                              If it can help.
                              Samsung S24+
                              Android 16
                                I am pretty sure this is has been resolved!
                                Update 5.0.1 will provide the solution.
                                We will test it now internally and roll out a beta as soon as possible.
                                Also trying to resolve the "disappearing keyboard" issue
                                  Fixed in 5.0.1
                                  Expecting release early next week.
                                  In beta tomorrow probably.
                                  • Forest
                                    Forest
                                    Forest
                                    5.0.1 downloaded.
                                    Seem (I am careful) to solve the issue.
                                    I can finally access to the navigation.
                                    Many thanks to everyone involved in the fix.
                                    Samsung S24+
                                    Android 16
                                    • Forest Forest
                                      5.0.1 downloaded.
                                      @Forest great!
                                      Otherwise on the home screen tap the map layer icon > scroll all the way down > open the advanced settings.
                                      You can then change the map configuration to help you in solving any issues. This setting is only available on older Androids.
                                      • lluis Castells
                                        lluis Castells
                                        lluis Castells
                                        Problem solved on my BV9600 Pro with update 5.0.1. Thanks
                                        • Bouke Ent
                                          #20
                                          501 433 gives on samsung active 2 and samsung S8 no solution. I think both android 9. on my main navigation phone ulefone x10 with android 11 it works ok. did use setting in map layers and virtual display and it seems to fix it for active 2
                                          Nick Dawson
                                          Nick Dawson
                                          Forest
                                          Forest
                                          lluis Castells
                                          lluis Castells
                                          • Recent trip made hard !
                                            165
                                          • best format to download
                                            Guzt
                                            Guzt
                                            282
                                            577
                                          • How do you download maps
                                            Mike wiruth
                                            Mike wiruth
                                          • Frozen marker.
