  4. WunderLinQ: BMW Wonderwheel to the left for a long time does not work
10 Posts 3 Posters 1.8k Views 1 Watching
  • Mopetenpit
    Mopetenpit
    Mopetenpit
    I use WunderLINQ X on a BMW R 1250 GSA and have only one problem:
    -Scrolling with the BMW Wonderwheel works.
    -Pressing the BMW Wonderwheel to the right (short and long) works.
    -Pressing the BMW Wonderwheel briefly to the left works (MRA menu is called up).
    -Pressing the BMW Wonderwheel to the left for a long time does not work. (previous app is not opened)
    I normally only use the scroll function and the function for skipping waypoints. Therefore, I cannot say when ‘pressing long to the left’ stops working.
    Is this more of an MRA or a WunderLINQ problem?
    Peter Zehentreiter Chudy 3 Replies Last reply
    • Mopetenpit Mopetenpit
      @Mopetenpit I do have a similar issue with another kind of controller... Everything works but just one function has a failure.
      As soon as I change the app to the english language it works
      I do not know which language settings do you use.....
      Just in case you are not using english, please be so kind and give it a try in english and let us know whether it works with the english language.
      Thank you
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      Mopetenpit 1 Reply Last reply
        Thank you
        Mopetenpit
        Mopetenpit
        Mopetenpit
        @Peter-Zehentreiter
        Thanks for the tip. I'll give it a try.
        • Mopetenpit
          Mopetenpit
          Mopetenpit
          @Peter-Zehentreiter
          I checked, but there is no option to change the language in the WunderLINQ app.
          Are there any WunderLINQ users here who can do this (long press to the left) without any problems?
            @Peter-Zehentreiter
            @Mopetenpit I meant you should check the language settings in the MRA App.
            If I set German as language, my controller does have a limited function.
            If I set MRA into english language...the controller works without any limitations.
            Peter
            BMW R 1250 GS
            DMD-NOR7E 7"
            SPC Universal mount
            Sena SLR 3
            Sena 50 R
              Peter
              Mopetenpit
              Mopetenpit
              Mopetenpit
              @Peter-Zehentreiter
              I have set the MRA app to English, but the problem persists.
              In the meantime, I have checked the codes sent by WunderLINQ using a key press tester. Everything is correct here, including the long left press.
              Yesterday, I created a support ticket – I'm sure they will be able to help me.
              Thanks for the tips!
              Peter
              • Chudy
                Chudy
                Chudy
                I have problem with open menu. Single left on wonderwhell shows complete route but lastest version open menu. Any solution ? mapping or something like that >?
                  Chudy
                  Chudy
                  Chudy
                  OK You want back to wunderlinq app ? If yes and you want back to wunderlinq app You must start MRA from Wunderlinq app then long left working fine.
                    Chudy
                    Chudy
                    Chudy
                    @Mopetenpit OK You want back to wunderlinq app ? If yes and you want back to wunderlinq app You must start MRA from Wunderlinq app then long left working fine.
                    • Mopetenpit
                      Mopetenpit
                      Mopetenpit
                      @chudy
                      I haven’t been using WunderLINQ for a few months now. I’m currently using a RiderNav CarPlay device and I’m very happy with it at the moment.
                      Thanks anyway for thinking about my problem!
                      Mopetenpit
                      Mopetenpit
                      Chudy
                      Chudy
                      • test Myroute APP
                        1.9k
                        Jörg Neudert
                        Jörg Neudert
                        690
                      • How to plan correctly
                        Christian Feurstein
                        Christian Feurstein
                        531
                        LE DIZES Freddy
                        LE DIZES Freddy
                        8.1k
                        Hubert Thori
                        Hubert Thori
