  4. Route violation
Route violation
14 Posts 10 Posters 2.9k Views 4 Watching
  • Mike wiruthundefined Offline
    Mike wiruth
    Hello, I'm wondering if when you are designing a route, will it warn you if the route you design goes against your avoidances you have selected? For instance "unpaved roads" I recently designed a route and had chosen to avoid unpaved roads. When on the route, i turned a corner and a warning came up on my phone saying route violation. Maybe this already is something you can see on the routeplanner, if so, I missed it. If not, it would be cool if you chose a route that violated your choice of avoidances, that it would warn you, or color the route red or something. Please help as I don't want this to happen again as I was leading a group ride and it's an unpardonable sin, lol, to lead others down gravel when on Harley's and Goldwings.
    Thanks for your help. I love the app.
    Mike W
    2013 Honda Goldwing
    Bushtec Trailer
    Garmin Zumo XT
    Nebraska
    Con Hennekensundefined Brian McGundefined 2 Replies Last reply
    • Mike wiruthundefined Mike wiruth
      @Mike-wiruth, no, currently there is no warning in the web-planner. But of course you can use different map-layers to check the roads you will ride. Also, tricking armchair-riders into a bit of dust is quite hilarious, when not overdone 😉
      Mike wiruthundefined RetiredWingManundefined 2 Replies Last reply
        Mike wiruth
        @Con-Hennekens Thanks Con
        Mike W
        2013 Honda Goldwing
        Bushtec Trailer
        Garmin Zumo XT
        Nebraska
          @Con-Hennekens I love tricking my HD riders into a little gravel on almost every ride! 😊 😊
            Brian McGundefined Offline
            Hi @Mike-wiruth unfortunately its not something that I see as within MRA's control
            The surface condition on a road/track is part of the map data which is supplied the exterior map data suppliers, Here, TomTom & OpenStreetMap, all MRA can do is plot a route relying on that data
            I can tell you now that the Here data, which is what MRA use for their navigation app, is by far the worst for routing down unpaved tracks, taking shortcuts where roads don't even exisit, even when there are perfectly good roads that are just a little bit longer/slower nearby.
            The only way I think you can reduce the chance of such surprises is by switching between the routing profiles/& the overlay maps, & by comparing the different paths each profile generates
            I find very often the Here routing profile will route down a path, which when inspected by viewing the OSM overlay map, it turns out to be designated as a track & not a road at all
            If your using an XT as suggested by your signature that will introduce a whole level of other surprises, I found after 2 years of meticulously careful planning could I prevent it from doing something completely unexpected
            Normaly navigate Routes in Offline mode with Offline Maps
            • Donovan Smithundefined Offline
              Donovan Smith
              OK, forget unpaved route avoidances, replace unpaved with toll roads! Too late when you start your route and on the ramp to the motorway...It would be so much better to get that violation warning in the planning stages.
                To avoid such surprises, you can view the route, or any questionable sections of it, in Street View. It's very convenient that MRA offers this option.
                This has allowed me to identify problems in many routes I have driven and adjust the route accordingly.
                  I agree that the planner should advise the planner of possible route violations during the planning process. Hopefully will be included in the future major update.
                    This would be nice if it could be implemented!
                    • Alex redsundefined Offline
                      Alex reds
                      You need to have the Gold option, but with it you can check your route planning by comparing the paths suggested by OpenStreetMap and TomTom. This usually solves most issues, and when there are differences, you can verify them using Street View.
                      That’s the method I use, and it’s always worked well for me.
                      Oh, and I almost forgot — you can also choose whether to include or exclude seasonal road closures.
                      • Erdnaundefined Offline
                        Erdna
                        The route violations are also an issue when using Navigation Next. It tells you, that there are violations, but it won´t show you - at least not w/o zooming in and controlling every inch of the route.^^
                          Today while following a circle route, there were a couple of violations. They did show up when looking at the complete route. I was able to tap on them to see what the violations were.
                          • Robert Laudensackundefined Offline
                            Robert Laudensack
                            I agree. I had many situation where the Road violation warning only pops up during the ride, wheras it should pop up during the planing where it is easy to correct a planing mistake. Comparing different routing options is a nice feature, but I use MyRoutApp for navigation why would I see what TomTom does...
                            Of course this warning only pop up when there is no internet reception and the detour will cost hours .... I remember a situation in Georgia where I had to turn after 2 hours of riding .....
                            Henk de Wit 1undefined 1 Reply Last reply
                            • Robert Laudensackundefined Robert Laudensack
                              Henk de Wit 1undefined Offline
                              Henk de Wit 1
                              @Robert-Laudensack Tomtom has the best traffic information there is. So if you compare your route with Tomtom is you will have less trouble when you driving.
                              The traffic info from Here maps is not so good and would not tell you why you can not pass that road.
                              Erdnaundefined
                              Erdna
                              Henk de Wit 1
                              Alex redsundefined
                              Alex reds
                              Donovan Smith
                              Robert Laudensack
                              Mike wiruth
                              • Gpx naar mra-route gaat fout
                              • MyRouteApp - Carpuride W712D - Silverfox Bluetooth Controller
                              • Radar alert
                                benet_73undefined
                                benet_73
                              • Voice instructions low
                                Aiello antoninoundefined
                              • MRA V5.0.3 (449) iOS Gebührenpflichtige Straßen Autobahn ??
                                Peter Zehentreiterundefined
                                15.5k
                              • "Resume navigation?" message appears frequently
                                Sven De Rockerundefined
                                Sven De Rocker
                              • Add screen lock to free drive
                                Nick Carthewundefined
