  3. [Beta] Announcements
  4. Update 5.0 - major app overhaul!
65 Posts 22 Posters 555 Views 11 Watching
  • Jörgenundefined Offline
    #21
    I can confirm, the iPad planing e.g. waypoint setting in landscape is not working properly. The waypoint is not set at the button of the icon, it is set with the top (the fingertip) of the icon.
    Portrait mode is ok for WP setting.
    I thing the crosshair was better for positioning a WP on tablet/smartphone.
    Why are the waypoint icons that big? (See pic)
    I used the simulation for testing. After stopping the route and the simulation, the position point (icon) is still moving over the map (as in the simulation).
    Looks like simulation is still on.
      Indeed, the placement of waypoints is way off in planning mode. I (we) missed that completely in our alpha testing, because we were unaware that anything concerning the changed GUI would impact the (as we thought unchanged) planner module. This proves the value beta testing 😉
        #23
        Tablets will be optimised before release for sure! 🙂 @Peter-Schiefer
        Edit: not so much tablet as indeed some landscape mode improvements but tablet are almost always landscape
          #24
          @Corjan-Meijerink :
          Thanks for the user UI update, I will test it extensively, the first impression is Bund and some functions you have to look for.
          Attention ⚠️ 1.) Question
          I have already noticed that the route A to B is calculated directly after a destination search and only the curvy variants can be selected, how do I select the fastest direct route if I don't like the three possible curvy routes (TrackRoute)?
          Or do you have to see it that way the 1.) Navigate = fastest route etc. s. Picture below
          Old version :
          1.) Route Fast connection
          2.-4.) Routen Track
            @Corjan-Meijerink :
            Old version :
            2.-4.) Routen Track
            Nick Carthewundefined Offline
            @Hubert-Thoring said in [Update 5.0 - major app overhaul!](/
            After entering your destination tap Navigate for the fastest option, if you want curvy tap the Scenic button.
              Display problem!
              The German word for quickest is not displayed.
              I would change the translation from "Am schnellsten" into "Schnellste".
              Then it would be displayed correctly, as well as "Kürzeste" (shortest)
                CarPlay start, the arrow is not centred correctly.
                It will move later, after 1-2km to correct position.
                • richtea999undefined Offline
                  Very nice! Good work, MRA dev team.
                  Minor irritations:
                  1. Android Back button doesn't exit the app.
                  2. Forcing users to step through all the features on first starting is unnecessary. A single popup asking if they want to see the latest changes is sufficient.
                    #29
                    It is not possible to move the menu more up, to see more options.
                    You also do not see a bar on the side, to make you aware that there are more options.
                    Only if you move your finger at this area, you see more options and a bar.
                    • Steve 2vundefined Offline
                      Steve 2v
                      Loving the new UI, same minor issues as others have posted about. In relation to the options piece in the post above, it would be great if we could change the travel mode here as well as part of the navigation options. I frequently swap between bike and car and forget to swap it over in the settings.
                      • Dave J 0undefined Offline
                        Great work with the new UI - top job. A couple of issues I experienced today on a quick test route I made with the new planner on the phone (worked well).
                        Same Point Navigation. The route was deliberately planned with only Via points to see what would happen with recalculation etc. The navigation worked well apart from how the app managed a return to the same point (Waypoint 1 and Waypoint 3) after navigating elsewhere. Regardless of what I did to route to Waypoint 3, the app said Waypoint 1. Videos show me selecting Waypoint from the Waypoints’ list and also manually skipping the Waypoint to 3 with the top right Waypoint Icon. Each time the app went back to showing Waypoint 1!
                        Car Play Manual Zoom Button. Tested on 2 different devices with the first screenshot on my car’s system through wired connection showing overlapping icons for zoom in and zoom out. Moreover, selecting these buttons made no change on the CarPlay screen.
                        When trying the same on me Chigee on the bike through wireless connection, the same thing happened but I noticed that the zoom was changing on the iPhone but not on the CarPlay Screen until exited the manual zoom function and then reselected the manual zoom again. This may have also happened on the wired connection:
                        Exit and re selection of manual zoom:
                        iPhone 15 Pro
                        • Edwin_Mundefined Offline
                          Edwin_M
                          De app is op Android niet te stoppen vanuit de App zelf. Een quit app optie zou wel prettig zijn. Of na een paar keer terug drukken de App af kunnen sluiten
                            #33
                            Sorry: 🫣 but through Hamm nobody drives voluntarily with his motorcycle !!!
                            The update should also please make the topic of routing (curvy route without driving through cities) better or why is routed with the MRA directly through Hamm to get from Winterberg to Münster via Curvy route from A to B.
                            Unfortunately or why other apps can do that better, or are more successful on route from A to B in curvy ...
                            Sorry: 🫣 aber durch Hamm fährt keiner freiwillig mit seinem Motorrad !!!
                            Das Update sollte auch bitte das Thema Routing (kurvige Route ohne Städte zu durchfahren) besser machen oder warum wird mit der MRA direkt durch Hamm geroutet um von Winterberg nach Münster über Kurvige Route von A zu B zu kommen.
                            Leider oder warum können andere Apps das besser, bzw. sind bei Route von A zu B in kurvig erfolgreicher …
                            Curvy example same A to B task!
                            Kurviger Beispiel gleiche A zu B Aufgabe !
                            An Hamm vorbe !!
                              Guzzistundefined Offline
                              On my tablet (Samsung Galaxy Tab S8 5G, Android 15, One UI 7.0) it's working perfect to place waypoints by MRA-Routeplanner - in portrait orientation. But in landscape orientation, I recognise same issues.
                              • Bart De Medtsundefined Offline
                                Really put the MyRoute-app beta to the test today: 315 km ridden and every single instruction was spot on.
                                This one’s going to be a winner! 💛
                                • Guzzistundefined Offline
                                  It's not an issue of new app version 5.0.0 - 418 - it's also in app version 4.4.1 - 410:
                                  Now, route planning and navigation is going over a street, which is actually closed for roadwork. The map does not longer show the icon for road closed, but only for roadwork!
                                  I'm sure some months before it was correct: route planning and navigation was using a detour. By the way: GoogleMaps is presenting as road closed and is navigating by detour.
                                    Because now, the selection buttons on start page of MRA-Routeplanner are organised as flat list (before, the buttons were in 2 columns) - now I need to scroll down to enter a target destination. It's at 4th poition.
                                    Ok, to scroll is not a big thing - but if developers wanted to make it more easy (less clicks) to start navigation - it could be shorter.
                                    It would be more than nice, if developers could make, the position of list entries could be rearranged in list by user.
                                      I use both Android and iOS versions. There is a difference between Start and Finish icons. Really like the Android version with the flags instead of via icons:
                                      iOS 26 - iPhone 15 Pro
                                      Android 16 - Pixel 6 Pro
                                      iPhone 15 Pro
                                      • Dave J 0undefined Dave J 0
                                        @Dave-J-0 that’s probably a setting on your side. I guess you enabled track navigation on the Android 😉
                                        • Guzzistundefined Guzzist
                                          @Guzzist it’s actually there already, the search icon which is literally the first option 😆
                                          • 4
                                          Rob Verhoeffundefined
                                          Dave J 0undefined
                                          M. Schrijverundefined
                                          Travellexxieundefined
                                          Edwin_Mundefined
                                          Edwin_M
                                          AWDC LAOundefined
                                          Peter Schieferundefined
                                          Peter Schiefer
                                          Giuseppe Marinoundefined
                                          Giuseppe Marino
                                          CD130undefined
                                          richtea999undefined
                                          Stefan Hummelinkundefined
                                          Erik Plaggenborgundefined
                                          Erik Plaggenborg
                                          Steve 2vundefined
                                          Steve 2v
                                          PeterKerkhofundefined
                                          PeterKerkhof
                                          • Back from vacation
                                            Gerard Wullinkundefined
                                            Gerard Wullink
                                          • Waze warnings...
                                            Leike Lodiersundefined
                                            Gerard Wullink
                                            -3
                                            27
                                            720
                                          • Moving the map
                                            Dave J 0undefined
                                            333
                                          • Route stuurt mij terug naar start punt bij Android Carplay
                                            jhawijnandsundefined
                                            jhawijnands
                                          • Routenpunkt platzieren
                                          • Planner slows down with Google Maps
                                          • Route wijkt af van de geplande route
                                            Marc R 0undefined
                                            Marc R 0
